Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 02-20-2007, 12:56 AM   #241
diosagain's Avatar
diosagain is an unknown quantity at this point
I definitely am need of a custom case pretty bad right now. I just have a huge mess on my table. Joe, take a look at my build thus far. Anyway, let me know where to paypal the money to (I know you have posted this in your threads, but I don't want to send until you tell me to).
http://www.mp3car.com/vbulletin/fabrication/97197-first-time-fab-2003-ford-explorer-please-help-lot-pictures.html
diosagain is offline   Reply With Quote
Old 02-20-2007, 01:50 AM   #242
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
diosagain,
just checked out your thread, looks like your parts need a good grounded chassis to call home! as long as you double checked that the finish size will fit your application paypal is joe.shock@gmail.com $65 shipped. Be sure to include your address.
Sorry I have not been on the boards much this weekend, had a little but of mustang trouble on some black ice. All is ok but i need to get a couple scrapes and dents bumped out from the fender flares. Going in the body shop wed to have the repairs done. My poor baby got banged up
Anyway Im fast approaching a HQCT module purchase which will be the next major step on this project so stay tuned for some AM/FM RDS hardware/software
blk02si is offline   Reply With Quote
Old 02-20-2007, 03:10 PM   #243
diosagain's Avatar
Joe,
First off sorry to hear about the Mustang. I am sure they will fix her up as good as new. How do you think the best way to measure is? Should I pull out the factory radio and just take mesurements of every angle? Let me know what you think I should do. I am interested to know how the HQCT module turns out. Can you hack it to work with your exisiting car antenna? Also, you mentioned something about building a volume knob. When you do get around to it, it would be great if you detail how you go about that process as well. Thanks! I am going to send the money now.
-Ross
Old 02-20-2007, 04:28 PM   #244
High Voltage
blk02si's Avatar
Yup, measure the the OEM radio chassis. Height, Width, Depth, in inches. I will bend the chassis to match these dimensions unless you look into the dash opening and discover there is more room for a larger chassis. You can also use the autocad sketches posted earlier in the thread to determine if any modifications to my standard chassis are even necessary.
The volume knob i made buy gutting a USB scroll mouse. I basically did a little fab work to disconnect the buttons and only use the wheel sensor. I used a piece of 1/8" round aluminum stock to transfer the turning motion of the knob back to the PCB sensor. Works golden. For software I use a program called 'volumouse' Im going to try to dig up some pics of this while i was building it.
The HQCT module will be connected to my OEM antenna jack.
One more thing Ross, The paypal payment from 'xxx.' Is from you correct? It does not have your name on the receipt anywhere and just wanted to double check
Old 02-20-2007, 07:27 PM   #245
diosagain's Avatar
Yes, that's my company. Joe if at all possilbe can you just edit your last post to remove the company name. Thanks. With google indexing everything these days I just would rather my business name not be associated with my posts. Thanks!
-Ross
Old 02-20-2007, 09:19 PM   #246
High Voltage
blk02si's Avatar
Name Removed. I forget about google sometimes and you're right, it will always bring up mp3car in searches
Any word on when you will have the dimensions?
Old 02-21-2007, 12:38 AM   #247
diosagain's Avatar
Tonight I was working on the screen fabrication. What a pain; but you will definitely have them by the end of the day tomorrow. I think its the same as the Mustang Double din, but I might as well measure to be safe. See the thing is I am going to fab the LCD into the trim and try to sit the indash case your building using a grinded down fabricated metra kit right behind it. I hope it works; I would really like to get everything in the dash. BTW thanks for removing the name. These days we are all just one google search away from losing our privacy.
Also, I got a version of your chopped down Win XP, and everything was great except when I tried to get on the internet. I tried just about everything. I even ran my cable modem via usb, installed the drivers , and took a direct route bypassing my router; but still no luck. Just wondering your thoughts on it. I guess worse case I can download TinyXP or just nlite my own version of windows, but figured I would ask first.
Old 02-21-2007, 09:06 AM   #248
High Voltage
blk02si's Avatar
I would probably give nlite a try Ross, its easy to use and then you have an OS configured exactly for your system. My version has every driver stripped out and my own integrated in. If your not running the m10000 you will need your chipset drivers installed before you get on the net.
Im glad to hear the fabbing is going well! If you need any other brackets made for mounting the chassis let me know, i can bend you some 1" angles or something so you have some mounting tabs for the dash.
Old 02-21-2007, 10:51 PM   #249
diosagain's Avatar
Sorry Joe, had a rough day but I definitly will have pictures and measurements tomorrow. Also, if at all possible can you snap a picture of your mouse scroll wheel you used for the volume? I am trying to make one and I think with a shot of yours I would have a better idea where to start from. Thanks again for all of your help.
Old 02-23-2007, 01:16 AM   #250
diosagain's Avatar
OK, all the measurements are done. I am going to upload them to my server and I will PM you the link. I kept them rather big so you can see the exact measurements. I didn't have as much room behind the radio as I thought so we are going to have to keep the case a little shorter then I intended. I also have to mount the LCD pcb board, m2-mtx, and the HQCT somewhere in the case, I guess sitting on top of MDF wood screwed into the case, kind of like you did. I just hope everything fits with all the wiring, but I think it will. I am glad I went with the 2.5 inch HD now.
Old 02-23-2007, 01:40 AM   #251
DaveWilliamsTX's Avatar
DaveWilliamsTX is an unknown quantity at this point
Well, I'm sitting here looking at a good looking case. Can't wait to mount it in...but I can hear the sandpaper calling my name...ugh, maybe tomorrow. If anyone is interested in my worklog, its here
Thanks for the quick turnaround on a solid chassis Joe!
Update: Its all together and working, I had to mod the chassis to fit my application, and everything fit despite having even less room than I origionally thought I would. Here it is all put together:
As you can see, its upside down, and I've trimmed what used to be the top off of it. The bottom corners had to be trimmed to fit the opening that I'm working with. Thanks again Joe, I'm glad its the stout .063 stuff, no worries about structural integrity.
It is no use saying, 'We are doing our best.' You have got to succeed in doing what is necessary.
Winston Churchill
DaveWilliamsTX is offline   Reply With Quote
Old 02-27-2007, 07:45 PM   #252
High Voltage
blk02si's Avatar
Chassis work looks nice Dave! I'm following your thread to see the final product.
I received an order for a shallow depth DIN and a half chassis from a member here named Ross. Its a special order and just wanted to share the design we came up with. The IO ports from the mobo are going to exit on the side of the chassis for clearance issues in his vehicle.
Also these are the outer chassis dimensions of an OEM DIN 1.5 opening.
Pic
Old 02-28-2007, 12:57 AM   #253
dyne is on a distinguished road
Thats pretty neat.
I made one for myself with a $5 sheet of steel and one of those bending machines this past summer. Yours look a tad bit nicer, though.
dyne is offline   Reply With Quote
Old 02-28-2007, 01:08 PM   #254
High Voltage
blk02si's Avatar
You could use steel for the same effect but i choose thick aluminum because its easy to work with, has better thermal properties than steel, is lighter weight, and with .063" you can tap threads into it so that you can screw bolts into it without using nuts on the backs. (less chance something will come loose)
I suppose you could bend a chassis with just about any type of metal if you have the right benders (think titanium)
-Back to my carPC i've been doing some research on the HQCT software and what its going to take to add it to my current embedded OS setup. It sould be pretty straight forward install. I've been so busy with work, school, and planning my wedding that I've had little free time to work on hobbies! Hopefully things will settle down here soon, so I can pull the PC to add more sweet sweet hardware. Also the detail shop had the mustang for almost 10 hours yesterday and there is not one SPECK of dirt to be found anywhere on it. I love when its this clean, just wish it was easy to keep it this clean during a michigan winter!!
Old 02-28-2007, 01:36 PM   #255
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
blk02si, you have to cut the middle bar in this double din kit (99-5807) right? In your pics, I don't see the cut mark. The result you have look more like a different kits (95-5812)
I'll fab one of these double din kit to my Supra bezel and then epoxy the screen to the bezel. I doing this way because if the screen screw up down the road, I'll just get a different screen, remove the old one and epoxy it in instead of redo the radio bezel everytime.
Also, you mention that you cut the bottom part of the lcd bezel, do you have to cut other part as well like top, left, right for it to fit?
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
indash touchscreen vga rca inputs mike86ttype Classified Archive 25 01-30-2005 10:30 PM
FS: Indash Unit from tm-701L BoraXP Classified Archive 9 01-15-2005 03:48 PM
Cheap indash monitor darkhavoq LCD/Display 11 11-21-2004 03:01 PM
FS: Complete Mini-ITX CarPC w/Xenarc Monitor + More DLe Classified Archive 23 10-19-2004 09:15 PM
Nissan Sentra 1996 GXE Complete Project. 14'' Screen criterzzz Show off your project 19 08-01-2004 01:07 AM
