Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 05-03-2007, 01:36 PM   #271
AXm77 is on a distinguished road
Hey blk02si, can you built case like on the picture for me? If so please PM me estimate price. I have design in SolidWorks, but can have prints done in AutoCAD.
AXm77 is offline   Reply With Quote
Old 05-04-2007, 03:32 PM   #272
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
PM sent. Nice design BTW.
blk02si is offline   Reply With Quote
Old 05-04-2007, 04:28 PM   #273
PM sent and more pictures:
Old 05-06-2007, 03:46 AM   #274
It's not really that small...No, seriously.
judoGTI's Avatar
judoGTI is on a distinguished road
That is very interesting, can you print pics with some external measurements? Id like to see what the specs are on that.. Good work.
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
judoGTI is offline   Reply With Quote
Old 05-06-2007, 04:21 AM   #275
energiesource is an unknown quantity at this point
I hope someone knows, i have a 2000 mustang with the 2 single din slots and i wanna find out if i can somehow fab a double din bezel into it, any help is appreciated
energiesource is offline   Reply With Quote
Old 05-06-2007, 03:25 PM   #276
Thanks. I will post pictures with dimensions tomorrow, because I have them at work.
If I remember correctly case is ~7.15” wide, 4” high and 6” deep. I designed it to same dimensions as head unit it will replace in my Legend.
Pictures of bezel:
Old 05-06-2007, 10:59 PM   #277
High Voltage
blk02si's Avatar
Looking really good AXM. I must say that planning is what really determines whether your carPC will be successful or not. If you ask me, I'd have my money on your setup working perfect. I'm looking forward to seeing the autoCAD export and determining how the chassis can be made. I've added on-the-fly toolbit change support to my router so I can drill all the holes now before I cut/bend the final shape.
On another completely different note, I've released my frontend skin that runs this system. I know this thread is mostly about hardware but I needed a totally custom frontend to finish it up. You can check it out in this thread:
http://www.mp3car.com/vbulletin/rr-s...ml#post1059522
Old 05-06-2007, 11:01 PM   #278
High Voltage
blk02si's Avatar
The specs on my DD chassis are 7" deep, 7" wide, and 4.75" high. If you look at the design though the 7" depth is only for a small part of the chassis to hold the mobo. The rest of the depth is 6".
Old 05-07-2007, 02:01 PM   #279
..... On another completely different note, I've released my frontend skin that runs this system. I know this thread is mostly about hardware but I needed a totally custom frontend to finish it up.
I downloaded your skin and really like it, good job. I working on my own with a different control layout but same idea: simple and fast.
Pictures with dimensions:
Old 05-07-2007, 03:58 PM   #280
High Voltage
blk02si's Avatar
What motherboard are you using axm? looks like a picoATX or something with an external video card.
Old 05-07-2007, 04:57 PM   #281
1 – DSX12V 140W DC-DC Regulator
2 – LCD Backlight inverter
3 – AU OPTRONIC F2B LCD controller board
4 - TOUCH SCREEN controller
5 – COMMELL LS-371 motherboard. It is 3.5” SBC (footprint of 3.5” HDD), Intel 945GM chipset for Core and Core2 CPU.
LCD Screen is AUOptronic A070VW01 wit T.S.
Old 05-07-2007, 10:33 PM   #282
High Voltage
blk02si's Avatar
Looking well laid out and ready to run! Make sure you keep room for the cabling. One of the things i've been considering is, take a deep breath, hard-wiring the VGA connection between the m10000 and the xenarc controller board. It would involve tracing and soldering 15 wires directly to both PCBS and also hard wiring the LCD touchscreen controller to a USB header. This would clean up the 4' or so of VGA cable that is just in a coil on the side of the unit. All I need is about 5" of each wire to do this. I'm sure if solder connections were good the display would be even cleaner, crisper and brighter due to near 0% signal loss in the cabling. Would be risky as one wire in the wrong spot would mean possibly frying both the mobo and the xenarc. But on the plus side this would make for an insanely clean setup and OEM / aftermarket radio style internals.
Here is a quick sketch to help visualize what I want to accomplish.
Old 05-07-2007, 10:45 PM   #283
As you can see from pictures both VGA connectors are align to each other, so I thinking about something similar to SLI bridge: two male connectors on small PCB.
Old 05-07-2007, 10:50 PM   #284
High Voltage
blk02si's Avatar
Interesting, a PCB bridge. I really like this idea but I'm not sure where to source a connector for the xenarc board. A bridge would make servicing the parts much easier than the hardwiring, but I think hardwiring is the most efficient way to go with the least amount of signal loss.
Where did you get the
AU OPTRONIC F2B LCD controller board?
Will this run any 7" touchscreen?
I've got an extra screen laying around with a burned controller board, wonder if this would work? I like the optronic because it uses the standard VGA connector making wiring the thing much easier!
Old 05-07-2007, 10:58 PM   #285
I bought this as a open frame monitor (screen, controller board, backlight inverter and touch screen controller) here on this forum 3 months ago. I have no idea if it will drive different screen. If you need cable for Xenarc I have original one as a spare. I got longer one for MP3Car store for my first carputer. You can make shorter cable leaving Xenarc connector untouched and play on other side with regular connectors as they are easy to get.
indash touchscreen vga rca inputs mike86ttype Classified Archive 25 01-30-2005 10:30 PM
FS: Indash Unit from tm-701L BoraXP Classified Archive 9 01-15-2005 03:48 PM
Cheap indash monitor darkhavoq LCD/Display 11 11-21-2004 03:01 PM
FS: Complete Mini-ITX CarPC w/Xenarc Monitor + More DLe Classified Archive 23 10-19-2004 09:15 PM
Nissan Sentra 1996 GXE Complete Project. 14'' Screen criterzzz Show off your project 19 08-01-2004 01:07 AM
