Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 02-18-2009, 09:40 AM   #751
Kalenth's Avatar
Kalenth is infamous around these parts
I did have some heat issues in my F150 with the 702TSV. That thing produces enough light that it gets HOT. I ended up mounting the other hardware a bit away from the screen, and no more issues. In Texas, heat CAN kill this stuff in summer.
Kalenth is offline   Reply With Quote
Old 02-18-2009, 01:45 PM   #752
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
The CCFL back light of the original Xenarc does get pretty hot. That is why I chose to mount the LCD controller PCB horizontally, 90 degrees away from the screen. The parts run cooler when separated.
I am about ready to order a new LED backlit Xenarc or Lilli, because the LEDs are low voltage and run cool.
The CCFL technology is high voltage, like 20kv, I had the CCFL starter circuit throw a lighting bolt into my finger while feeling the chips for warmth.
blk02si is offline   Reply With Quote
Old 03-04-2009, 12:31 AM   #753
Xargon321 is an unknown quantity at this point
Sorry to Jack your thread for a sec but i have a machined Aluminum frame that i got from josh a while ago when i was building my car pc i never used it because the xenarcs touch screen glass was too long to fit into the frame. but if you blk02si or someone else needs it it would make mounting the lcd much faster the touch screen glass would have to be smaller then 4 1/4 inches wide by 6 5/8 long. it already painted black but will have to be touched up a bit. shot me a pm if if your interested
Xargon321 is offline   Reply With Quote
Old 03-08-2009, 02:21 PM   #754
High Voltage
blk02si's Avatar
Sorry Xargon,
I'm currently working on a Chrysler build which uses very different bezel mounting style. I am machining my own from aluminum.
Old 03-22-2009, 09:26 AM   #755
blbrchnk is an unknown quantity at this point
Anyone else using the factory amps (for subs) in their 05-09 mustang with the shaker notice much worse sound when using an onboard sound card in their car pc over the stock system? I notice that the bass is not nearly as pronounced and crisp like it was before. Is this due to using onboard sound? or am I not tuning it correctly?
Also to anyone with a 05-09 mustang, whar did you connect your antennae power to? I put mine coming from my m2atx 12v rail, but the more i think about that, the more i think it should come from either the switched power from the car or just the battery (afraid this method would drain battery).
Thanks.
blbrchnk is offline   Reply With Quote
Old 03-22-2009, 09:40 PM   #756
High Voltage
blk02si's Avatar
Sounds like you need to tune the audio more, you need a good line level out to your amps. Also, a lot has to do with the software you running as most players have software based equalizers that you will need to tune.
I would not run the power antenna from the m2, any electric motor will cause interference and high draw fluctuations on the line. Use the ACC line from the OEM radio harness.
Also, finally got a couple pics of carPC v2 for your enjoyment
The new LED backlit lilliput which I really like. Its very slim, lightweight, nice menu options, auto on, etc and just seems very well made. I purchased it manufacturer direct.
Also is the intel atom board which is amazingly fast paired up with a 266x read/write PNY flash module. I am a big fan of the atom after working with this board.
The new build is also going to have HDTV, I found a 5v tuner that works well with the lilli.
Last is the new industrial power supply I purchased/fabricated/wired for bench testing new setups. It provides 11a @ 13.5v. Yeah its a beast. Drives the m2 @ full load no problem. Just look at the caps on there! Heavy as heck though.
Old 03-22-2009, 10:09 PM   #757
What can I tune it with if all I am using is winamp inside of RR? I played with the winamp eq and even jacking the bass as much as I could, I still couldn't get that same thump that I got from the stock headunit.
Is the ACC line the switched power line that turns on with the battery? And just to double check since I lost my key to my harness, the blue line is the antenna power correct?
Thanks man, you have been such a giant help in this entire process of mine, and the case is still rocking hard. Take care!
Old 03-27-2009, 10:13 AM   #758
Since there seems to be a good deal of mustang users in this thread, does everyone that uses a radio still get about the same reception? Mine seems to have gone down a little and now has a little bit of static on the channels that are further away yet still used to come in fine.
Old 03-27-2009, 06:11 PM   #759
TxAxZxZ's Avatar
TxAxZxZ is on a distinguished road
Blk,
Do you think that Intel Atom board will fit into the JKPC? I've been eye-balling this guy ( http://www.logicsupply.com/products/nc92_330_lf ). I just don't know if it supports dual monitors. My goal is to play movies (using headphones) on the back monitor while I listen to music on the main monitor. I'm not exactly sure what verbage to call that, but that's my goal. I'm also installing the rear sensors/backup camera soon so I need plenty more pc power for all this. You know anyone interested in the Pico-ITX PX10000G?
Jeeputer Project
- Design <<< 100% >>>
- Construction <<< 99.5% >>>
TxAxZxZ is offline   Reply With Quote
Old 03-27-2009, 11:16 PM   #760
High Voltage
blk02si's Avatar
The reception is all about the right antenna. I'm still messing with my visteon HD unit and it sounds about the same. Are your amp grounds and PC grounds the same?
- Hey Patrick! Good to see you on the boards! A ITX will fit in the chassis, on the top, just got to make sure the jeep has room for the cabling. The m3 will be fine with that setup too. How much do you want for the Pico? That's a sweet little board!
Old 03-27-2009, 11:33 PM   #761
TxAxZxZ's Avatar
How goes it Joe? I know, it's been a long time since I've showed my face. It's been a pretty busy few months! I see your project is coming along nicely. Have you decided if you're going to replace the OEM radio or add to it?
I'm looking to get around $225 each...I have 2 of them. That includes the 1Gb of RAM and shipping. I thought I had a problem with the board so I ordered another one. Turns out I had a problem with my USB hub. I fixed it before my board came in and I got too lazy to return it.
Jeeputer Project
Old 03-28-2009, 01:11 PM   #762
No, my amp grounds are closer to the amps in the back where as the pc ground is up near the pc
I was using a silabs unit and was having a horrid time with that. At least this Visteon unit gives me something I can listen to.
Old 03-28-2009, 03:06 PM   #763
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
I have a question and statement.
First off, what is the website for Lilliput directly? I see way to many sites claiming to be Lilliput. I currently order mine through Ebay, but I would think it would be cheaper direct.
Also I would not consider the HDTV tuner thing very reliable. I'm in Miami and they have the ATSC HDTV network in place now, but the quality is so bad with mobile applications. You need a powered antenna to get a good signal. I tried the HDTV thing with no success, so I went back to Sling Box and bought a new air card that works abit better. Now I watch my Sat TV with periodical buffering.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 03-29-2009, 01:51 AM   #764
High Voltage
blk02si's Avatar
I order mine through ebay too. I knew it was manufacturer direct when the UPS tracking # got emailed to me.
As far as the HDTV goes I build my own antennas Mobile is still in the works but I can tune an HD signal in a second when I am stopped. It's not going to be useful on a trip up north or something, but for waiting in line at the bank or something, perfecto.
@blbrchnk
Try grounding your amps and PC to the same ohm level. (run a ground wire to connect them) It may help out with some noise in your sys.
indash touchscreen vga rca inputs mike86ttype Classified Archive 25 01-30-2005 10:30 PM
FS: Indash Unit from tm-701L BoraXP Classified Archive 9 01-15-2005 03:48 PM
Cheap indash monitor darkhavoq LCD/Display 11 11-21-2004 03:01 PM
FS: Complete Mini-ITX CarPC w/Xenarc Monitor + More DLe Classified Archive 23 10-19-2004 09:15 PM
Nissan Sentra 1996 GXE Complete Project. 14'' Screen criterzzz Show off your project 19 08-01-2004 01:07 AM
