Greetings! I've been lurking on here for a while, I have searched this and other boards in depth, but I have not found anything finished with a Dakota or Durango dash.
I picked up this dash off of ebay, and, while I am planning the rest of the project I have started relocating the A/C controls.
The problem is, I have a large flat area to work with, and I don't want the install to look ghetto.
I thought I knew what I wanted at first - To panel mount the LCD, like you would panel mount any display in a wall. Then I was trying to figure out what to fill in the rest of the area with. I went to trade school and am a trained machinist, so an aluminum plate was the obvious choice. I grabbed some scrap, placed it behind the dash and MAN was it bad looking. There is no aluminum accents anywhere else in the truck, so I have to go darker.
This is a mock-up of what I have in mind. I am unsure as to how to mount the LCD. I'm afraid a surface mount will look bad. If I do a recessed mount, I then have to fabricate my own panel, and there is a lot of flat surface area to show imperfections. If I go the surface mount route. I will use a black carbon fiber structural panel.
Complicating matters, if you notice the texture of the surrounding dash, it is almost impossible to reproduce, which I have to do along the cut to make it look like it is one long bevel.
Does anyone have any ideas or suggestions? Also if anyone has any pics of a finished dakota/durango dash, I would be very greatful.
--Jay
