The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Fabrication
View Poll Results: What do you use to fill gaps?
Epoxy 6 37.50%
ABS sheets, balsa wood, ... 0 0%
Liquid plastic or plastic solvents 0 0%
Fiberglass and bondo 10 62.50%
Voters: 16. You may not vote on this poll
Thread Tools Display Modes
Old 03-31-2006, 08:48 AM   #1
My Photos: (0)
Epoxy used to fill gaps - good or bad?
I've been reading now and there seems to be some mixed reviews.
I epoxied a 7" screen bezel to a double-din bezel and there was a < 0.25" gap on either side. To fill the gap I taped off the front and poored epoxy glue into the gap. This created a very good mold of the front that will require little sanding.
I read about epoxy not being very strong to use as structural support. Also read about epoxy cracking when used in large quantities to fill. Should I be worried?
taylor192 is offline   Reply With Quote
Sponsored Links
Old 03-31-2006, 05:12 PM   #2
Ub312g0d's Avatar
Vehicle: 1996 Buick Regal GS
My Photos: (0)
I would not ever use epoxy just by itself. It seems to work alright sometimes but I've never had really good experience with it durability wise. Also if you live in a colder environment the epoxy WILL not hold. Like a trick to seperate objects joined with epoxy is to put them in the freezer.
Ub312g0d is offline   Reply With Quote
Old 03-31-2006, 05:17 PM   #3
Dracos's Avatar
Vehicle: 1995 Ford Fiesta Si 1.6 16v
My Photos: (0)
use epoxy to tack and offersupport - but use fiberglass to fill. works a charm (check out my installs for proof)
Dracos is offline   Reply With Quote
Old 03-31-2006, 07:34 PM   #4
Altimat's Avatar
Vehicle: 2002 Altima 3.5 SE
My Photos: (0)
Epoxy sticks best to a properly prepared surface. Use glass or carbon cloth with it for strength. Mix it with microballoons to make a filler.
2002 Nissan Altima 3.5 5 Speed Bose FM/6CD ED E12A P4 2.26 512 Ram Ti4600 CDRW DVD Lilliput 200mW 802.11b Trackman AutoTap GPS Opus 150 Carnetix 1260
2005 Nissan Titan SE Dell GX-150 P3 1.0 512 Ram 20G GF4 MX4000 USB 2.0 DVD/RW Xenarc GPS Trackman
Altimat is offline   Reply With Quote
Old 03-31-2006, 07:42 PM   #5
sebberry's CarPC Specs
My Photos: (4)
I got this epoxy putty stuff, picture a straw (only fatter) with the straw being the hardener and the stuff inside the straw the adhesive (it may be the other way around, I dunno...)
You break off what you need, mash it around and form it like clay or play-dough, and it hardens pretty well. I used it for the frame around my screen and don't have any problems yet. (http://community.webshots.com/album/400638837lHBGTW) for assembly pics
sebberry is offline   Reply With Quote
Old 03-31-2006, 10:18 PM   #6
Vehicle: 2000 Pontiac Sunfire GT Convertible
My Photos: (0)
fiberglass!
dmcdlrn is offline   Reply With Quote
Old 04-01-2006, 11:16 AM   #7
My Photos: (0)
I'm in Ottawa and we get -40C in the winter.
I'm going to put my bezel in the freezer to see what happens, if you're right I'll cut out the epoxy and replace with fiberglass.
Old 04-01-2006, 11:23 AM   #8
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (29)
Fiberglass cloth soaked in epoxy works extremely well.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 04-05-2006, 08:15 AM   #9
My Photos: (0)
Thanks everyone. The epoxy held even when frozen, so this is the path I have taken. Since the gaps are so small I used epoxy to fill them and am about 50% done.
Going to use a putty knife and the longer setting epoxy to fill aeas on the top rather than bondo. The epoxy seems easy enough to sand, and doesn't seem to leave pinholes like fiberglass, so bondo may be unneccessary if I can fill and sand well with the epoxy.
Hopefully have pics up in my worklog this weekend. Struggling with fitting a 7" screen and slot-load DVD drive within an over-sized double-din.
Old 04-05-2006, 03:34 PM   #10
BassBinDevil's Avatar
Vehicle: 1957 Ford panel delivery
My Photos: (0)
Marine bondo is made from something like epoxy mixed with fiberglass filler. It's much more waterproof than regular bondo, but harder to sand.
BassBinDevil is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Auto power off accord General Hardware Discussion 29 08-15-2004 07:08 AM
TFT LCD + Magnets = good or bad? lazynok LCD/Display 7 07-23-2003 01:17 PM
7" REDANT SCREENS (bad pixel) CHEAP dscustoms Classified Archive 20 06-26-2002 10:04 AM
Astec AA90304 DC/DC Good or Bad? mp3bobo General Hardware Discussion 2 01-17-2001 12:09 PM
Yamaha 740, good or bad? SexyCompGeek General Hardware Discussion 0 04-04-2000 05:28 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
