Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 04-08-2006, 07:04 PM   #1
dsballer2000's Avatar
dsballer2000 is on a distinguished road
91 Toyota Supra Fabrication
After reading this forum for almost a year now I've decided its time to just go for it and start my fabrication. I've heard about all the hard times this bezel has been with other users so I wasn't really excited about trying.
The screen I decided to fabricate is the ever so popular xenarc 700tsv.
At first I was going to use the bondo method but decided to try something different because Matrix told me about his cracking in different weather conditions. I'm in Canada so we have crazy weather with hot summers and super cold winters. For this reason and after reading a lot of threads, I've decided to use a method mentioned by Turbocad which is the Plastic repair kit method.
I have never fabricated anything and I am new to this whole thing. I was told to get a professional to do it because I'm not experienced in this but I want to prove them wrong so it begins.
This is the bezel and screen and xenarc shell I'm working with. The bezel says PP+PVC on the back.
dsballer2000 is offline   Reply With Quote
Old 04-08-2006, 07:07 PM   #2
Supra fab
This is the Plastic Repair Kit I bought at Canadian Tire.
Contents:
1 Part A Semi-Flexible Epoxy Tube
1 Part B Semi-Plexible Epoxy Tube
1 Fiber Tape
1 CA Weld
1 Fast Cure CA Activator
Old 04-08-2006, 07:15 PM   #3
Cut bezel
Notice the rubber like outter material. This is the pain in the *** material that has been causing problems for most of the supra fabrications so I'm crossing my fingers
Xenarc shell fitting
Old 04-08-2006, 07:27 PM   #4
For some reason my camera didn't keep the pictures of the first layer of plastic. But after applying, sanding and sanding, and some more sanding and more applying. This is the results so far. I applied a little more over the imperfections but have yet to sand it down. It was getting cold outside so I had to clean up. I will sand this down tomorrow.
This stuff is very easy to use. It applies on thick and hardens in 10-15 minutes. Sanding is a breeze and very forgiving.
These are the results of about 2 hours worth of work. I'm pretty happy with it so far.
Filling in where the cig lighter was took the most applying and sanding. As you can see I have a lot more sanding to do tomorrow.
Old 04-08-2006, 07:29 PM   #5
Well that's it so far. Any critism would be greatly appreciated. I want this done right so I want to hear what people have to say. Thanks for checking out my thread and keep posted.
Old 04-08-2006, 07:56 PM   #6
skippy911's Avatar
skippy911 is on a distinguished road
Lookin good so far. I went with the abs sludge method and am waiting for my newest coat to dry. Seems to take about 12 hours to fully harden and I have no clue how hard it will be to sand. If I ever venture into this again im gonna try your method because I am very impatient hehe.
skippy911 is offline   Reply With Quote
Old 04-08-2006, 08:39 PM   #7
Ya this method was great for no wait times. I could have sanded right after i applied the last coat if it wasn't so damn cold outside.
12 hours to wait would be way too long. Oh well, hope yours is worth the wait.
Old 04-08-2006, 09:00 PM   #8
skippy911's Avatar
Yeah me too. I just went out and added a lil more to the open sections. Ill leave it till the morning to dry and then start sanding my first coat. What grit paper did you use to sand??
Old 04-08-2006, 09:39 PM   #9
I'm using 120grit on mine but like i said, this stuff is very easy to sand. I've never done anything like this before so I'm learning as I go.
Old 04-09-2006, 10:42 AM   #10
More Sanding
As you can see, I sanded down the extra plastic I put on yesterday. I need to go to the hardware store and grab higher grit sand paper and some paints.
I still haven't decided what will go at the bottom but I'm thinking a slot load DVD burner and usb ports as well as relocating my cig lighter down there.
Old 04-09-2006, 08:11 PM   #11
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
look good so far.
I am waiting to see how it come out cuz I want to redo mine with a 7".
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 04-10-2006, 05:06 PM   #12
Phillie
Escalade182's Avatar
Escalade182 will become famous soon enough
If you want a more stock looking peice....straighten out the bottom...
Escalade182 is offline   Reply With Quote
Old 04-10-2006, 05:10 PM   #13
I'm actually going to fill that whole bottom out so its just the start. I am going to put a dvd slot drive as well as usb ports down there so its pretty much going to be flat all the way down.
Old 04-10-2006, 05:31 PM   #14
MySQL Error
MatrixPC's Avatar
Try to twist the bezel a little to see if filling material came off.
Old 04-10-2006, 05:33 PM   #15
i tried flexing it a lot. Everything seems to stay on nicely w/o cracking or anything coming off. I only worry about when it gets really hot out when the roof is off and the sun is just beating down on it.
WANTED - Toyota Supra 1990 Roof bars tracysupra Classified Archive 3 11-01-2005 07:22 PM
swbball28's toyota highlander project - fabrication done by meeee xdjxklusivex Fabrication 7 05-21-2005 05:43 AM
Toyota Supra TT mkiv spyda Show off your project 31 02-21-2005 06:08 PM
ME 2.0 Official Bug Reports phat_bastard ME Archive 67 01-31-2004 07:27 PM
Error #91 SiGmA_X ME Archive 18 01-08-2004 10:40 PM
