Yesterday I finally got around to getting all the things I needed to begin my fiberglass box. It decided to rain as soon as I got home so I had to wait till this morning to start it. It was a bit tricky at first but I think it turned out well so far. I have it about 50% complete right now and hope to finish it off tomorrow and bolt it in my car. Here are the pics from the work I did today.
My trunk before the fiberglass box, this is my 4-5 year old bandpass box which sounds nice but takes up half my trunk and slides around all the time.
Here are most of the materials I used. Resin, Fiberglass mat, some mixing stuff, blue tape, gloves etc.
The first thing I did was tape off the area to be fiberglassed
Then I put some tinfoil over the taped area (light portions on the blue tape) and proceded to cover the tape with apoxy and fiberglass. It was tricky at first and doing it inside the car didn't make it easier.
After about 2 hours it was completly cured and flexable enough for me to pop out of the trunk easily.
After it was out I began to layer more fiberglass and apoxy ontop of the first 2 layers. This is after 4 layers.
This shot is when I finished with the 7th layer. I also happened to run out of fiberglass so I guess 7 layers is good enough. The piece is much larger than it needs to be to account for weakness around the edges. Trimming the edges will make it look neater and it will be much stronger.
Before I cut the box I filled a 1'x1'x1' box with packing peanuts. My 10" sub needs 1' cubed amount of volume but it is really hard to measure the strange shape of the box. The solution is to create a box of known dimensions then pour the packing peanuts into the box. As you can see I have more than enough room which is great because I will be trimming off the edges.
I marked and cut the edges of the box so that they best fit the flow of the inside of the car and the volume I needed. The actual sub should not protrude much beyond the current width of the box. I can always cut more though if I need to. We will see how it all goes together tomorrow!
