Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 06-07-2006, 02:16 AM   #1
damarble's Avatar
damarble is on a distinguished road
03 Neon SXT in-dash Xenarc install
So I've had my carpc built and running nicely in my old car for almost 1/2 year now. I just used the included stand and screwed it to the dash, since I planned to get a new car soon.
Well the new car is here and I'm ready to start fabbing a center bezel/console. I do have a few options.
In the pic it looks like the bottom of the colsole curves in sharply, but in reality it is almost straight up and down.
I think I'd prefer to put the LCD near the bottom, using the cubby/lighter area and the HU area. That would mean the least modification, only removing the HU and relocating the rear defrost and lighter. The LCD will be recessed a little and tilted back slightly.
Apparently I'm going to have to buy a bezel on ebay, since my local junkyard did not have a single Neon. It's a shame too because if they had it, it would have been only $5.
Any comments?
{Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
MY INSTALLATION LOG
damarble is offline   Reply With Quote
Old 06-09-2006, 10:29 AM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
what would you like us to comment about?
do you smoke?
if not, move the cig lighter to the glove box, should relocate nicely, same with the defrost switch and possibly even the factory radio...are you stuck on keeping the factory radio? are you stuck on keeping a hu?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 06-09-2006, 01:48 PM   #3
damarble's Avatar
I dunno, anything. Anything that pops out or comes to mind. I know how to fabricate the dash parts and I know how to build carPC's, so I don't really need help in that department. I guess I was looking for fresh ideas if anything.
Quote:
do you smoke?
No smoking for me. I thing the best place for the cig lighter and defrost switch is in the center console. There's plenty of wide open plasic above the parking brake.
I have been without a head unit in my old car for almost a year and I couldnt imagine going back. (First hardwired MP3 player, then carPC.) FM radio sucks, and the only thing worthwhile on AM is sports and Sirius covers that. Besides, Chrysler's factory HU's suck major arse.
A couple ebay auctions for the bezel are ending today so I should get one of them. Fabrication start late next week then.
MY INSTALLATION LOG
Old 06-09-2006, 02:43 PM   #4
_
welp, it sounds like you have it all covered then
Jan Bennett
Old 06-10-2006, 11:06 PM   #5
damarble's Avatar
Radio bezel comes of so easy, just two screws and a few clips. It was easy to run wires too, all the trim pieces pop off, just clips hold them on. I got the power lines run today. I'll run the signal lines probably next weekend, it will only take an hour tops to finish. Then the only thing left will be fabbing brackets to hold the PC itself in the trunk, and fabbing the new bezel for the LCD. It seems like Chrysler wanted me to put a carPC in this thing, every aspect has been so easy so far.
Sorry for the really crappy low res pix. The colors are even distorted.
After pulling the radio and defrost/lighter/cubby thing, the dash is wide open for whatever I want. I could fit a Mac Mini or VIA based PC in there, if I wanted. But I prefer my Celeron M based PC, it's the size of a amp and there is a great place in the trunk for it.
Direct view with LCD in place. Plenty of clearance without any trimming.
View from driving position.
MY INSTALLATION LOG
Old 06-11-2006, 09:25 AM   #6
_
some cars lend themselves nicely...
be sure to keep us posted with fabrication pics!
Jan Bennett
Old 06-12-2006, 02:32 PM   #7
damarble's Avatar
I have all my materials ordered now. I got a extra radio bezel, a 12"x12"x1/8" sheet of black ABS, and a black plastic slim DVD drive enclosure.
Since my radio bezel is ABS PC, I'm not sure if the acetone/ABS shavings method will work. So I'm going to look for some of that Dynatron stuff that Turbocad was pimping. Stuff looks great.
MY INSTALLATION LOG
Old 06-12-2006, 03:34 PM   #8
_
Plastic weld works amazingly well also.
two part epoxy style in what looks to be injectors...at your local auto parts store.
It's what we have found works incredibly well on just about any material, ESPECIALLY plastics.
Jan Bennett
Old 06-12-2006, 10:28 PM   #9
damarble's Avatar
Go some more stuff.
I got some MEK instead of acetone, it was only $1.50 more and supposed to be better. I'll try it on some of the bezel scraps after it's trimmed up to see if it will melt it. If it does I'll use the ABS sludge for filler. Got a 5'x2" ABS pipe for an ABS source.
And if that fails, I got Loctite plastic epoxy. Anybody see a problem with this stuff? It says it's for ABS and PVC. Says it's not for PE and PP. But that's OK, since I won't be working with any.
MY INSTALLATION LOG
Old 06-12-2006, 11:50 PM   #10
BarryWoods's Avatar
BarryWoods is on a distinguished road
MEK is some nasty stuff. Be careful with it. It's been banned in the Air Force.
Failure is not an option....
It's installed by default on every version of Windows.
BarryWoods is offline   Reply With Quote
Old 06-12-2006, 11:56 PM   #11
Sidewalksalvage's Avatar
Sidewalksalvage is on a distinguished road
WOw love the set up so far, should come out lookin preety nice.
You are doing plastic fabrication rather than fiberglass or else?
what made you choose ABS?
Worklog -- 1987 Toyota Camry Resurrection
Current Progress:
[XXXXXXXXXXXXXXXX====]80% Works Great; Front speakers need to be replaced; On hold while at school.
Brown 2010
Sidewalksalvage is offline   Reply With Quote
Old 06-13-2006, 12:55 AM   #12
damarble's Avatar
No kidding. I popped the top and instantly the smell was sickening, and I was working outside. But it did melt the ABS shaving within a few minutes. I should pick up a respirator.
Yeah I went with ABS because it's more durable than fiberglass and I hate working with fiberglass. Also, the Xenarc bezel is already ABS, the car's bezel is ABS PC, ABS sheets are cheap. So everything should be pretty compatible.
I've used Bondo on plasic before, and although I haven't had cracks yet, and the job came out really nice, I want this install to be perfect so I'm doing it right, fusing the plastic pieces together as one.
MY INSTALLATION LOG
Old 06-13-2006, 01:40 AM   #13
BarryWoods's Avatar
Yes you should. I know a guy on permanent disability because of these kind of fumes.
Old 06-13-2006, 11:44 PM   #14
Thats sad. I was in lowes today and saw the MEK stuff. I got sick looking at the warnings
good luck with the install. I understand now why you chose ABS
Current Progress:
Brown 2010
Old 06-15-2006, 09:08 PM   #15
damarble's Avatar
Yay the ABS sheet came today! But still no sign of the bezel. I'm all set to start fabbing this up too. I guess I might cut the abs peices tonight, since my old bezel is the same as the new one....
Oh yeah, I found a respirator at work so now I shouldn't die from the fumes.
MY INSTALLATION LOG
How can I install my screen to the dash ? shinjetko LCD/Display 5 04-24-2006 01:17 PM
Repairing a hole in my bumper as practice for my dash install... Arathranar Fabrication 3 03-26-2006 03:15 PM
Infiniti G35, 7" Xenarc Install, How-To Doc god_of_cpu LCD/Display 0 02-20-2004 03:03 PM
Install in dash with no case? tigerarch General MP3Car Discussion 2 03-15-2003 12:18 AM
In Dash Kit for 7" WS display Xenarc gunnt LCD/Display 0 08-22-2002 03:53 PM
