The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Thread Tools Display Modes
Old 07-11-2006, 04:47 PM   #1
Location: Goshen NY but going to college in Pomona, NJ near Alantic City
Vehicle: 06 Cobalt SS/NA
My Photos: (0)
Best Place
What is the best place in the car to put the computer so that it is not exposed to over-heating and that it is not an eye sore?
spade44 is offline   Reply With Quote
Sponsored Links
Old 07-11-2006, 05:08 PM   #2
Dracos's Avatar
Vehicle: 1995 Ford Fiesta Si 1.6 16v
My Photos: (0)
the boot or glovebox, like most people
Dracos is offline   Reply With Quote
Old 07-11-2006, 06:11 PM   #3
My Photos: (0)
kida new at this stuff, whats the boot?
Old 07-11-2006, 06:15 PM   #4
Vehicle: 2003 Audi A4 1.8t
My Photos: (0)
That's europe-talk for trunk...
Under the seat may work well for you too. I think the general rules are keep it out of sunlight and away from any major heat source. Provide enough space for airflow, and try not to go with a power-monster machine.
~Puff
View my worklog... I dare you... http://www.mp3car.com/vbulletin/showthread.php?t=77267
Carputer Progress [||------------------] 10%
Puffanug is offline   Reply With Quote
Old 07-11-2006, 06:16 PM   #5
volum3rider's CarPC Specs
My Photos: (0)
I have mine on a custom board that mounts to the side of the inside of my trunk. Its carpeted to the stock color of the trunk and I also put a fan on it so it doesnt overheat. I think that most people just put them in their trunks.
volum3rider is offline   Reply With Quote
Old 07-12-2006, 11:15 AM   #6
FC3S's Avatar
My Photos: (0)
for most people, theres 2 choices like mentioned above
trunk, or under a seat, u should go to Show Off Your Ride
check some other peoples installs, could give you some other ideas as well
FC3S is offline   Reply With Quote
Old 07-12-2006, 11:22 AM   #7
My Photos: (0)
I put my laptop under the seat for the simple reason that that's probably the coolest place in my car. I haven't needed to install a fan yet. The AC fan will blow right through it. Another advantage is I don't need to run long wire to the screen upfront.
iGMon - Integration between iGuidance and Road Runner
CFX - Skin for Road Runner
b8bboi is offline   Reply With Quote
Old 07-12-2006, 11:29 AM   #8
FC3S's Avatar
My Photos: (0)
haha, a lot of people dont have a laptop X)
but yeah, under seat most AC's/Heaters can blow on it
Old 07-12-2006, 01:04 PM   #9
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
under seat is a no no, used only as a last resort
there are so many issues that occur when equipment is mounted under a seat...
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 07-12-2006, 01:26 PM   #10
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
trunk is good no noise from fans etc as well
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Sponsored Links
Old 07-13-2006, 08:54 AM   #11
double-0-newb's Avatar
Vehicle: 1998 Volvo V70
My Photos: (0)
Can you elaborate a little bit?
Hi GTi VR6,
Perhaps I missed it in the Uber-FAQs, but could you list just a few of the reasons why under-seat mounting is a no-no?
I would think that, but have no real idea, that....
CONS:
Not enough space under most seats to get good ventilation.
Could be subject to dampness/moisture from backseat passenger's shoes
~edit to include -zip-'s comment above~ trunk is good no noise from fans etc
PROS:
Shorter cables (than trunk mount), thereby reducing likelyhood of wiring-related "noise".
If laptop in docking station, ease of access from inside cabin
Thanks.
1998 Volvo V70 "Volputer"
Worklog: planning and procurement.
http://www.mp3car.com/vbulletin/showthread.php?t=75505
double-0-newb is offline   Reply With Quote
Old 07-13-2006, 09:44 AM   #12
_
My Photos: (73)
Reasons for not installing anything underneath the seats.
  • There is no place to properly ground anything underneath the seat. Most people would try and use the seat bracket bolts. These are not good grounding points for a few reasons.
    - Usually these bolts are covered in grease, grit, or grime, thus making the ground a bad ground.
    - These same bolts are usually covered in paint, as is the threaded part that the bolt goes into.
    - Those mounting points usually have carpet underneath them, meaning that the ground is not solid.
  • That dirt, grit, and grime got there somehow. That same dirt, grit, and grime will get in whatever piece of electronic equipment you put underneath the seat.
  • If passengers can see it, they will mess with it. I know that we all like to think we can trust our friends. The fact of the matter is that people are curious. If they see a bunch of wires sticking out they will play with them. Not only will you risk having your passengers pulling things apart, you also risk them shocking themselves. Though you might think “Good, they deserve it then”, you can still be held liable. Sucks, but that’s the truth.
  • Even if you ask people to watch their feet, it’s like a magnet. Their feet will find their way under the seat. In doing, so they will break wires, break solders on boards, and introduce all kinds of foreign objects from their shoes that you don’t want around electronics.
  • The seat moves, you can try all you can think of, but it moves. There are things beneath the seat that will catch wires and pull them out. Moving pieces are never a good thing to mount next to or around unless you have the proper materials, and 9 times out of 10, you won't.
I'll remember the others in a bit, right now I need to eat breakfast...lol
Jan Bennett
Sponsored Links
vB code is On
Trackbacks are Off
No good place for Xenarc except for! tna0601 LCD/Display 23 09-14-2004 09:07 PM
Cable extensions question (IDE to USB, longs, place...) windalo Newbie 2 08-09-2004 08:36 PM
where is the cheapest place to find a slim dvd rom (tray load)? DSM97RS General Hardware Discussion 4 05-02-2004 09:36 PM
where and how to place laptop??? cubanmoses General Hardware Discussion 3 06-08-2003 12:39 AM
cheapest place to get an laptop hdd adapter? whoojong General Hardware Discussion 6 01-27-2003 12:19 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
