07-12-2006, 09:05 AM
#1
Location: Goshen NY but going to college in Pomona, NJ near Alantic City
Vehicle: 06 Cobalt SS/NA
Best Way 2 Keep Cold
What is the best way to keep your computer from over heating?
Is this a good fan:
http://www.directron.com/uc001btc.html
07-12-2006, 09:08 AM
#2
? Or do like I did and mount it under the seat where the AC blows directly on it. The End.
07-12-2006, 09:20 AM
#3
Vehicle: 2006 Ford XR6 Turbo Ute
about when the heater is on?
07-12-2006, 09:41 AM
#4
I relocate it to the trunk in the winter.. or I just plug up the vent that is cooling it right now.
07-12-2006, 09:45 AM
#5
Vehicle: 2006 Scion XB
Quote: Originally Posted by spade44
I've got the same fan going into the case I'm building.
It's a good one,but you either need to put the thermal sensor on something hot like a hard drive,or short the sensor out to get the fan to spin fast enough to move some air.
Ripped it all out the Dodge....here we go again.
Planning 100%
Parts 90%
Install 0%
07-12-2006, 10:21 AM
#6
dont turn it on?
07-12-2006, 11:21 AM
#7
Vehicle: 2004 VW R32 ... 2006 Jeep Commander
move to alaska
07-12-2006, 12:03 PM
#8
It's not really that small...No, seriously.
Vehicle: '02 GTI
Just blow on it, like you do hot soup.
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
07-12-2006, 12:52 PM
#9
Vehicle: 2005 Honda Element
Quote: Originally Posted by strohj
move to alaska
Then they freeze...
Failure is not an option....
It's installed by default on every version of Windows.
07-12-2006, 12:54 PM
#10
Vehicle: 2007 Honda Fit Sport
Phase-change cooling would probably be the best way.
07-12-2006, 01:03 PM
#11
Laptop, Tablets, UMPC Moderator
Vehicle: 2002 pontiac montana
the best way is to start with an efficent setup to begin with... a mobile processor will run alot cooler than say a p4...
07-12-2006, 01:06 PM
#12
_
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
all this talk of heating....it's 100+ degrees here today, meaning 150+ in the car, started right up without an issue, just like it has for close to 3 years now....and mines back behind a body panel with minimal air flow
07-12-2006, 01:13 PM
#13
Vehicle: 1996 VW Golf
and how might you power a phase change setup? come on those are some power hungry beasts.
07-12-2006, 01:32 PM
#14
Regenerative braking?
07-12-2006, 03:51 PM
#15
Vehicle: MKIV VW Jetta
This is almost like the "how should I mount my hard drive" question. For most people it's really a non-issue and any standard cooling setup will typically be fine.
In the 5+ years I've been building and using carputers I've never had any over-heating issues. Not even in LA summers. A decent place to keep the PC is in the trunk. It's usually cleaner than the cabin and natrually cooler. Depending on your setup (CPU, GPU, OC/UC, case size) you may not even need more than a CPU fan and a decent path for hot air to escape. My current setup has one 92mm fan blowing air in from the front/bottom of the case and another 92mm "blow hole" near the back of the case nearly on top of the CPU heat sink with speed pot (no actual fan on the HS, though). And really, even that may be a bit redundent for my senerio but I don't mind.
| Thread Tools |
| Display Modes |
Linear Mode
