Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 08-14-2006, 12:00 AM   #16
3g Jester's Avatar
3g Jester is on a distinguished road
you sure know alot about foam mister.
3g Jester is offline   Reply With Quote
Old 08-14-2006, 12:03 AM   #17
GoHybrid's Avatar
GoHybrid is on a distinguished road
the more foam dust you breathe....
ps- thanks Vin
GoHybrid is offline   Reply With Quote
Old 08-28-2006, 12:47 AM   #18
jay_tu's Avatar
jay_tu is on a distinguished road
looks awesome...
04 Corolla
Modifications:
Upgrading pc 99%
Progress
jay_tu is offline   Reply With Quote
Old 08-28-2006, 04:34 AM   #19
KaBoOoM's Avatar
KaBoOoM is on a distinguished road
Genius imo, and very easy to cover in glass for reinforcement. I like it a lot!
*Edit* You think it would be possible to use a hot wire to cut the foam without damaging the plastic? If you could it would make it flush almost instantly and require only a small amount of sanding (if any). Don't know anything about working with foam though.
Also it would be interesting to just use a crappy cheap foam, maybe with a very low melting point and put a glass shell on it. Then cut out/poke a whole in it and melt the foam out or just dissolve it out. Just throwing some ideas out there ...
I'm hungry
KaBoOoM is offline   Reply With Quote
Old 08-28-2006, 09:47 AM   #20
GoHybrid's Avatar
the renshape can't be cut with a hot wire unfortunately. It can be bent with a heat gun in thicknesses of 1/4" or less though. Kind of an oddity but it works. I have seen links using the "lost foam" method. Google lost foam and you might find some hobbyists that shape foam cores for model airplane fuselages and then do exactly what you say. For that though, you'll want to use EPS foam and epoxy resin.
good ideas!
Old 08-28-2006, 03:31 PM   #21
KaBoOoM's Avatar
If one were to do the exact same thing you did, but glass it would it be too thick? And is it easy enough to take a fraction of a centimeter off the edges evenly?
Sorry for all the questions, but I like this method
I'm hungry
Old 08-28-2006, 05:50 PM   #22
GoHybrid's Avatar
Well, here's what you could do instead. Make the part out of foam. Make it to the exact dimensions that you want the final part to be... THEN! instead of trying to reinforce the foam, build a box around it and fill it with RTV silicone! Then you can fill it with your favorite urethane and paint it, machine it, make a billion of em for that matter. If you want, check out www.smooth-on.com They have all kinds of wonderful castable plastics.
BuT, if you don't want to bother with all that, then yes, you could just offset your boundaries and laminate glass over it. I'd advise looking into vacuum bagging too because chopped mat and wet-layups are just asking for rough finishes and air bubbles, especially in small parts.
I could go on for hours with any of those reproduction methods, or some others i didn't mention, but let me know what you're interested in and we'll talk.
Old 08-28-2006, 06:10 PM   #23
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
those smooth-on products rule! i've used a few of them with great results!
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 08-28-2006, 06:46 PM   #24
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
I like the way that looks.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 08-28-2006, 08:42 PM   #25
GoHybrid's Avatar
hey truckinmp3! are you coming to the colorado carpc meet on 9/26? it'd be really cool if you could make it. check the gatherings for "greetings from colorado" towards the end of that thread are all the details.
Old 08-28-2006, 10:40 PM   #26
Anshu is on a distinguished road
that looks fantastic, superb way of getting around the bondo nastiness
98 V6 Camry XLE
Status-Who Knows
Just Finished:Dual Battery Setup
Next Stage:1/2 Din Faceplate
Ze Worklog
Anshu is offline   Reply With Quote
Old 08-28-2006, 10:45 PM   #27
TruckinMP3's Avatar
I have read the thread. Not sure I want to go.
Thanks though.
TruckinMP3
Read the FAQ!
Old 08-29-2006, 12:22 AM   #28
Siezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to all
Nice write up on the process. It certainly gets one thinking about the potential uses of foam.
"It's a blessing . . . and a curse."
Siezmik is offline   Reply With Quote
Old 08-29-2006, 12:35 AM   #29
GoHybrid's Avatar
i've spent alot of time making parts out of it. I'm pretty excited to see what the possibilities are for mold-making and production. I'll probably do another write-up when i finish my alumilite version of the trim bezel.
Old 08-29-2006, 10:24 PM   #30
tml240 is an unknown quantity at this point
That looks amazing.
tml240 is offline   Reply With Quote
Yard Sale agashka Classified Archive 20 08-21-2006 11:41 PM
Liquid Foam JPuma Fabrication 8 08-31-2005 09:59 PM
Foam bmwperson Fabrication 8 09-15-2004 05:35 PM
Before you use foam to mount your Touch Screen NewTechFool LCD/Display 0 03-05-2004 02:33 PM
Fiberglass over foam? gork General MP3Car Discussion 9 08-20-2003 06:57 AM
