Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 08-30-2006, 03:10 AM   #31
KaBoOoM's Avatar
KaBoOoM is on a distinguished road
The mold making is a grand idea. Will love to see how your car turns out!
I'm hungry
KaBoOoM is offline   Reply With Quote
Old 08-30-2006, 09:01 PM   #32
Das
Das's Avatar
Das is on a distinguished road
1 075119 Ren Shape 5025 4" Partial Board - T-4" W-24" L-16" Bd. Ft.-10.67 $105.21 $105.21
Shipping Estimate: $23.00
Total Quote Price: $128.21
Yeah right, what a ******* rip off.
Das is offline   Reply With Quote
Old 08-30-2006, 10:10 PM   #33
KaBoOoM's Avatar
Anyway to subscribe to a thread without replying? Oh well accidentally usubcribed so replying again.
That is pretty expensive foam lol
I'm hungry
Old 08-30-2006, 11:50 PM   #34
GoHybrid's Avatar
GoHybrid is on a distinguished road
It's not free, I'll give you that. The thing to remember is that even that partial board, you could make patterns for a pair of custom speaker pods, a radio trim bezel custom knobs, levers, lids, containers... damn near anything you could think to do. And for only $130, it's all going to be completely stable. No worries about melting it, Shapes can be made incredibly accurate. Some of this stuff you just can't do with MDF or floral foam... Even if you did spend 14 times as long on it as I did. It's not a rip off, you just have to consider the all the hidden costs you can incur with other materials less suited for prototyping.
GoHybrid is offline   Reply With Quote
Old 09-13-2006, 03:59 PM   #35
Blaz3's Avatar
Blaz3 is on a distinguished road
wow- i like that idea
Blaz3 [|||||||||-] 88%
Blaz3 is offline   Reply With Quote
Old 12-05-2006, 09:38 PM   #36
GoHybrid's Avatar
It's Back!
Hey everyone! After that brief hiatus I have responded to some comments and queries in this thread and others about the uses of foam and casting techniques, and with the invaluable help of several members here (you know who you are) i give you my best efforts in demonstrating low-tech and effective mold making and casting techniques.
Rather than use my existing trim bezel, I wanted to make a few changes to hold closer tolerances to the screen itself and improve the fit and finish to some degree. So i remade the bezel out of RenShape (as described earlier) with the new form, and here it is in my car to see how it fits and looks:
Old 12-05-2006, 09:44 PM   #37
GoHybrid's Avatar
Primer and mold container
The next step is to build a box around your part and block it out with cheap materials as necessary to reduce the amount of silicone you need for your mold.
You can see in this picture that i've filled the center of the box with a piece of MDF... there's no reason that needs to be solid silicone and so i save a little money.
For this particular mold which is a one part mold, all you need to do is ensure that your part sits perfectly flat on the bottom of the box and use some hot glue or other adhesive to make sure it stays in place.
Be sure to leave at LEAST 3/8" around thin sections on both sides. Any thinner than that and the silicone gets a little floppy.
Old 12-05-2006, 09:55 PM   #38
GoHybrid's Avatar
The Mold Pour
This next step is to mix and pour the silicone. One very important thing you want to look for when purchasing a silicone is the viscosity. Lower viscosities are much easier to mix, not to mention far more forgiving when perfect surfaces are a must-have. Another important thing to check is whether it is a addition cure or condensation (tin-cure) silicone. Condensation cure silicones are almost inhibition proof which means they'll cure against most anything. Good safety factor there.
The method for pouring is a VERY clever method courtesy of TAP Plastics that they call the "Bombs-Away" method. If you are like me and just don't have $1500 to drop on a professional vacuum deairing station, this is a phenomenally cheap and easy way to ensure bubble free parts.
Here's how it goes:
1. You mix your silicone and prepare a dixie cup with a 1/2" hole in the bottom. Cover the hole with tape and place the cup at least 30" above your mold.
2. Pour an amount of silicone into the cup and pull the tape off. A glob of silicone will come out. I caught this in another cup and "followed" the stream down to the mold box so i didn't have a poorly aimed glob on the floor. Once your aim is right, let that thin stream start to fill the mold. Aim for a low spot in the mold and let it flow over and fill everything up to the top.
3. You can see in the cup itself the big bubbles that are trapped by the mixing process. As the silicone stretches out on its way down, the vast majority of those bubbles pop.
Old 12-05-2006, 10:01 PM   #39
GoHybrid's Avatar
De-molding
This is the worst part. Although there are some fast-curing silicones, this particular one made by Silicones-Inc (www.silicones-inc.com) is GI-1000 which is a lower viscosity condensation cure silicone that takes a good 24 hours to cure. So you just have to be patient and don't poke at it.
When it is ready though, break apart your box and gently peel the silicone from the part. If you designed enough draft into your part, it should come out very easily. One of the benefits of silicone though is that you can have minor undercuts and still be able to demold the completed part.
There may be some flash to trim off but if your part sat flat against the bottom and you did a good job in gluing/claying it, then it should be pretty clean. You can see that I did not!
Old 12-05-2006, 10:07 PM   #40
GoHybrid's Avatar
Part Pour
Here's where we start to have fun. I was introduced to Alumilite by my local plastics store (plasticare for those of you in the denver area). This stuff is nuts. Two parts, 90 second open time, and demoldable in about 5 minutes. I do recommend leaving it in the mold until it has totally cooled though. This minimizes the possibility of shrinking or warping. This stuff is a little thinner than honey and mixes easily with a 1:1 ratio by volume. I just mix it and pour it on the edge of the mold. I let it roll down the side and fill the mold smoothly. This eliminates many of the surface bubbles that might otherwise occur.
Old 12-05-2006, 10:13 PM   #41
GoHybrid's Avatar
And voila!
And that's it! It's pretty amazing to me that these parts came out bubble free. Alumilite may cure too fast for those seeking the ultimate in precision, but the beauty of this process is that you can re-pour a part tens if not hundreds of times with all kinds of materials. And since silicone has inherent non-stick properties, you don't really have to muck about with mold release for short runs. In any case, it's far stronger than the original foam part, and can be machined, sanded, painted, drilled and tapped to fit in your car.
So... I hope this helps further the cause. I know there is another silicone related tutorial on here. I don't mean to step on it's toes but rather supplement it. Overall expense for silicone and alumilite was about $80. Dixie cup came courtesy of my office. Thanks guys!
I'm happy to answer any questions. Fire away!
Old 12-05-2006, 10:17 PM   #42
NiSlo's Avatar
NiSlo is an unknown quantity at this point
You are the grandmaster of this stuff.
Do you think latex rubber would also work to make the mold? The stuff I've used is about the same consistency as milk, which I would think would give you a great smooth finish around the stock with no bubbles. Not sure about any seepage under the stock though...
Subscribed
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 12-05-2006, 10:29 PM   #43
GoHybrid's Avatar
I think latex has one major drawback which is that it only dries in thin sections which means you'd need some sort of mother mold to hold it in shape. That means lots more draft and you kind of lose the flexibility that silicone gives you. That isn't to say it cant be done or isn't done. I just think that for this type of thing you can't beat silicone.
Old 12-06-2006, 09:12 PM   #44
GoHybrid's Avatar
One more thing...
I went to the store and to my surprise they had dyes for the Alumilite! So i picked up a bottle of black and thought i'd give it a try. The results are pretty good if you just want a nice ABS-level black.
I had a little resin left over so i couldn't resist....
It's amazing to note the level of detail this stuff picks up. If your foam model were finished glossy, you would never have to finish your poured parts! they'd all come out the exact same way!
love peace and grease!
Old 12-07-2006, 12:58 PM   #45
FLAC is for flaccid
parksgm's Avatar
parksgm will become famous soon enough
Amazing work on both the mold and this thread, GoHybrid. Your prose and completeness makes this a process that anyone should be able to follow and achieve similar results.
I'm jealous (but not jealous enough to prevent me from trying this myself when I get around to building a bezel, of course)!
Mods, make this a sticky!
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Yard Sale agashka Classified Archive 20 08-21-2006 11:41 PM
Liquid Foam JPuma Fabrication 8 08-31-2005 09:59 PM
Foam bmwperson Fabrication 8 09-15-2004 05:35 PM
Before you use foam to mount your Touch Screen NewTechFool LCD/Display 0 03-05-2004 02:33 PM
Fiberglass over foam? gork General MP3Car Discussion 9 08-20-2003 06:57 AM
