12-10-2006, 12:29 AM
#61
i'm excited to see a thin-wall casting! Do you have any thoughts on which resin system you might use to make the final part?
12-10-2006, 02:08 AM
#62
I've done this before...
Last time I did this, I used Polytek's Poly15 series of resins:
http://www.polytek.com/products/poly15.html
Read up on the two threads I started nearly 2 years ago:
How to: Duplicating a radio bezel.
8.4" LCD in WRX dash.
They're long dead threads, so don't add anything to them, but they're still interesting reading.
The problem I ran into during the mold making was that the container wasn't rigid enough.. I used 1/2" thick posterboard, which was too flexable for the size of work required.. MDF is much better.
Back then, I didn't have a tablesaw to cut MDF, and I didn't have a X2 mini mill.
I got this model from MicroMark:
http://www.ares-server.com/Ares/Ares...oduct&ID=82573
It's the same as this one from Harbor Freight:
http://www.harborfreight.com/cpi/cta...emnumber=44991
Now I have a table saw, and a mini mill, and hope to convert the mill to CNC within the next few months, with this much larger table:
http://cncbridges.com/mmb85265.htm
They're coming out with a slightly larger table soon that can cover a full 26"X by 12"Y of travel, more than enough to mill anything I want - including complicated radio bezels.
Anyway, getting off topic there..
My current plan is to buy a replacement lower center console (the area where the radio is mounted) and a replacement radio bezel - both available for less than $50 each - and to carve / mill blocks of foam to fit.
This lets me work on the project without having to have my dash torn apart.. :-)
12-10-2006, 03:43 PM
#63
well go to smoothcast.com
to check out what thet have, i really recommend ordeting from www.farwestmaterials.com
this is their phone number, if they are still in business last time i worked with them were 5 months ago
(509) 522-0556
they have a great support, look at smoothcast 300 it's a 50/50 compound resin sets with in 10-12 minures, very durable, if you want smoother rubber like finish, i highly recommend dragon skin, i believe you can get a quart trial kit for about $15 USD.
I am a professional scale modeler, and have been casting, molding, and sculpting & painting miniatures for over 5 years
I hope they are still in business, plastics has been tough business laterly
Yev
R. T. F. M
12-10-2006, 03:51 PM
#64
I think you meant www.smooth-on.com - smoothcast.com doesn't resolve.
12-10-2006, 03:53 PM
#65
yeah sorry i haven't been in this business since i got my car
yev
R. T. F. M
12-10-2006, 03:58 PM
#66
Dakar m3
if you don't want to drop too much money into quality stuff i suggest starting with florist foam, it's cheap, and very easy to shape, you can get it in any craft store
here is some pics from fiberglassforums
sorry little off topic, but this might work for the budget
Yev
R. T. F. M
12-11-2006, 04:10 PM
#67
can you fiberglass right over the floral foam??
12-11-2006, 04:51 PM
#68
I think the resin (unless you were using an epoxy) would chew it up to some degree. If you're going to spend a month sanding the fiberglass and fillers and hack out the foam later, then no big deal, but if you're trying to make a mold and keep it accurate, I'd look at a different kind of foam or resin.
12-11-2006, 10:41 PM
#69
yes you can
R. T. F. M
12-11-2006, 10:49 PM
#70
floral foam is heat resistant, and even with slight chew ups, they can be easily fixed with evercoat body fillers.
make a mold from the final product after you are done.
the reason that solution caught my eye is because of the price you can get a case of 60 9 x 6 x 3 blocks for under 40 usd. and it's a good practice before you get to work with expensive stuff, my philosophy is, basic bondo fillers are crap, i learnt hard way but i got good experience is sanding, before i went with better evercoat products.
I would recommend floral foam to any first timer, then you can get to the professional equipment which is pricier, but get's you better results, as Hybrid pointed out
He is professional in what he does though
Yev
R. T. F. M
12-11-2006, 11:08 PM
#71
Subscribed
12-12-2006, 04:16 AM
#72
Raw Wave
Dakar m3
Get the ***** out, that is awesome work. Never would have occured to me to even attempt that with floral.
As far as working with wax (it's been awhile since I bought a 55lb block of polycrystalline wax ), I wonder if you could smooth the surface of tooling marks with a careful application of a heatgun.
12-12-2006, 12:21 PM
#73
well, there are many options out there
i haven't tried heat gun, but floral foam is heat resistant, so it wouldn't melt during the fiberglass cure.
othet than that you can shape that foam with your fingers, they come in different strenghts, from lighter green being softers, to a darker green being denser.
Yev
R. T. F. M
12-13-2006, 10:27 AM
#74
Wow that's a great foam made bumper... where did you get those pix?
12-13-2006, 02:13 PM
#75
i'd be more concerned about the solvents melting the foam than the heat...
| Thread Tools |
| Display Modes |
Linear Mode
