The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Thread Tools Display Modes
Old 08-15-2006, 07:58 AM   #1
Vehicle: 1998 Subaru Forester
My Photos: (0)
Question Backup Camera Weatherproofing
I'm looking for thoughts on weatherproofing my backup camera. I want to mount it on the liftgate of my Subaru Forester pointing down at the back bumper.
Installed:
Lilliput 7" w/ TS * Kenwood head unit interface
Deluo GPS * BR3 OBD-II * P-1900
Removable/Exchangable:
Mac mini * Dell Latitude 600m
ShaneFK is offline   Reply With Quote
Sponsored Links
Old 08-15-2006, 11:41 AM   #2
My Photos: (0)
Ah, I'd suggest READING THE DESCRIPTION!
Quote:
If that is the case for your vehicle, you will need to install a fuse, voltage regulator, etc. to protect the camera) Water-proof without extra housing:
Shadow is offline   Reply With Quote
Old 08-15-2006, 03:58 PM   #3
My Photos: (0)
Only the camera lense is waterproof without extra housing. The body needs to be protected if it is mounted outside the car.
Quote:
Water-proof without extra housing: for part (camera glass lens) exposed to outside ONLY and for normal usage ONLY. Camera body and cables are not designed to be exposed to outside and must be properly sealed against moisture.
Installed:
Old 08-15-2006, 04:34 PM   #4
3D Warrior's Avatar
Vehicle: 2001 Honda Civic
My Photos: (0)
why not just buid a box out of sheet mettal or something that's water tight? i just use some silicone to seal the corners let that dry and pop a camera into it... follow me? if you apply silicone properly i'll not come off and be water proof for sure... ever seen how they build fish tanks? all that's holding the glass together is that silicon and it withstands a ton of pressure and never leaks...
3D Warrior is offline   Reply With Quote
Old 08-15-2006, 09:32 PM   #5
skuller's CarPC Specs
Vehicle: 06 accord
My Photos: (5)
haha
i think its better to read the description correctly before telling people
peace
skuller is offline   Reply With Quote
Old 08-15-2006, 09:44 PM   #6
My Photos: (0)
I read the description just fine. I misread his post. I thought he said he wanted to mount it in the lifgate instead of on the liftgate.
The G35s have a little box that's up near where the tag/trunk release is. You could get a project box from RadioShack for like $5 and get some weatherstripping and RTV silicone and you'll have a good start to a solution. I don't think neo magnets would mess with the camera (don't quote me on this) but you could use those inside the project box to hold it to your car (unless it's aluminum or fiberglass).
Sponsored Links
vB code is On
Trackbacks are Off
Infiniti G35 Backup Camera chirowolf General Hardware Discussion 3 05-04-2006 12:01 PM
G35 coupe, Xenarc and backup camera chirowolf Input Devices 2 05-04-2006 11:59 AM
Auto activate backup camera SWC Hardware Development 26 04-24-2006 09:40 PM
Where can I find the demensions of this Backup camera mbkowns General Hardware Discussion 0 08-28-2005 04:50 PM
why is my backup camera not working with my capture card? nappyjim General Hardware Discussion 0 02-17-2005 02:52 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
