Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 08-31-2006, 09:51 PM   #1
we87's Avatar
we87 is on a distinguished road
Spray Paint Question - Powder Residue
I just got thru painting my custom mount for my LCD in my car. The mount it self is a piece of wooden clipboard that I used a dremel on to make it fit my car, and my lcd, for detailed pictures check out my sig.
What I did was take some textured spray paint and sprayed the piece once. Then I went over it a second time with flat black to get the color I want, and I let it dry all day long in 95+ heat in the sunlight.
However, even though its dry and not wet anymore, when I touch the paint I get like this powder substance on my hands. And if I rub the board its like particles of paint seem to rub off... Its not all due to the texture, because even if I rub real hard (well, hard enough anyway without doing any damage) the texture still stays on under the black paint like it should...
But my question is: What is the next step in this process? What can I do to take away the powder substance that got left behind?
I dont want to spray a layer of finish on it, because I dont want this to end up glossy what so ever.... It needs to stay the flat color that it is. However, I am a complete n00b when it comes to spray paint so I really dont know what the best-next-step would be.
Here are some pictures, but I have to be honest. The pictures dont really explain what I am trying to say. But I tried my best to take these to better help my explanation....
As always, thanks very very much in advance for any advice or information you guys can give me. I really do apreciate it.
Carputer Progress
[||||||||||] 100%
Finally Installed!!
Everything is in the car and working.
I painted the cilpboard mount and it looks good.
Shutdown/Startup is working excellent!
View My Progress Here
we87 is offline   Reply With Quote
Old 08-31-2006, 10:42 PM   #2
GoHybrid's Avatar
GoHybrid is on a distinguished road
sounds like your flat black color is not bonding well to the texture paint. See if you can get ahold of an adhesion promoter like Bulldog. Spray that on the texture, then spray your flat black color on top.
GoHybrid is offline   Reply With Quote
Old 08-31-2006, 11:03 PM   #3
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
yeah, or use a better paint for your final trim black...
I use a paint made by sem, it's pro stuff auto body supply house....
no problems at all... & it's flat enough to not look glossy, but not flat enough to dry like powder... if you use a true "flat" black, you'll get EXACTLY what your discribing...
this is the stuff, & the finish it gives...
this is very durable, non fading & even semi flat finish that matches most plastic trim..
turbocad6 is offline   Reply With Quote
Old 08-31-2006, 11:56 PM   #4
we87's Avatar
Thanks guys for the replies, I apreciate it
Where would I get these paints you guys are describing? Would somewhere as common as a Home Depot have them? Or are they more speciality store stuff....
Both sound like great ideas, and I really like that black trim paint.
I have a stupid quesiton though: What if I was to go over this board very lightly with a gloss black spray paint. Would that screw it all up? And would that just give me a completely glossy black? Or would it just seal in the flat enough to make it all look right without making it all too glossy...
I just came back from Wal-Mart (its the only thing thats open at the moment) and I got a can of gloss black, and a lint brush for the powder. The lint brush actually picked up alot of the excess pretty well. I'm thinking that a once over with a little of the gloss black should do the trick. But then again, if I knew what I was doing I wouldnt be in this mess to begin with.....
Carputer Progress
[||||||||||] 100%
Finally Installed!!
Old 09-01-2006, 12:20 AM   #5
GoHybrid's Avatar
if you don't want a glossy finish, i wouldn't mess with glossy paints. I know you can order SEM paints like turbocad6 mentioned if there's no local supplier. I think your best bet is to track down an auto body supplier. Ask your local collision repair center where they buy their supplies. One other thing you might try is going to your home depot/lowes/woodworking store and hunt down a can of Deft clear lacquer. Deft is an interesting character. You can spray lightly and get a clear lacquer coat that dries flat to satin, or you can go a little heavier and after a few layers you can get all the way up to a glossy finish. Lacquer is also pretty benign in the presence of latex and rattle-can paint so you'll find it quite easy to work with. Check it out and let me know what you think.
Old 09-01-2006, 12:21 AM   #6
turbocad6's Avatar
it's gonna look gloss black... if that's not what you ultimately want, don't start piling all kinds of crap on this, wait one more day & do it right...
automotive bodyshop supply stores are the best source, if you can't find that & must go with something off the shelf, check home depot or lowes for krylon semi-gloss..... anything semigloss should be ok...
also, did you think of just washing the piece as it is now,,,, if the dry dust is washed off it might be fine as is....
Old 09-01-2006, 12:24 AM   #7
we87's Avatar
I wanted to go the lacquer route, but to be hoenst I was afraid of the end result.... I just sprayed some test pieces I have: one with the glossy black, and one with a clear top coat I have. Ill let them both dry over night and see what they look like tomorrow. If they both dont look like I want them to, then I will try what you guys said.
That Deft sounds like the best bet since depending on how many layers I put on I get the gloss that I'm looking for. That sounds great. Tomorrow I am definitly doing some spray paint shopping
Carputer Progress
[||||||||||] 100%
Finally Installed!!
Old 09-01-2006, 12:28 AM   #8
we87's Avatar
Well thats one of the reasons I went with the lint brush to pick up the excess and see how that would look. And I think after I picked up most of the flat black powder/dust, this being the end result- Its not what I wanted. After all of that mishap, I feel its too flat
I know I am being way too picky about this, but I want a very specific look. And since I'm not getting it, I am basically trying to settle for the best substitute. If that makes any sense....
Like I typed above, I did some test pieces to see how they come out. If they look good, then I think I dont have to do anything else. If not, then I am going to track down that Deft stuff.... Ill let you guys know what I end up doing.
Carputer Progress
[||||||||||] 100%
Finally Installed!!
Old 09-01-2006, 12:30 AM   #9
turbocad6's Avatar
there are available also "eggshell" clearcoats, clearcoat without the shine, used to refinish & match factory interior trim... that may be overboard cause it's prolly not avail in aerosol, but that's what we use to restore factory plastics & vinyls...
with the texture this is less critical, cause the texture will kill the gloss bigtime anyway to a certain extent..
Old 09-01-2006, 12:41 AM   #10
we87's Avatar
Thats good to know... Perhaps that would be the best idea period. Thats what I wanted in the begining of all this, was a clear coat that wouldnt shine/gloss..... Interesting.
It sounds like you work in a body shop? Let me ask you a quesiton, I am willing to comepletely sand this down and start from scratch...but, only if I would end up getting what I want. My question is: Is it possible to get the exact look and feel of the bezel trim that I have around the screen?
If you click "View My Progress" in my sig, youll see what I'm talking about. I want the exact look as that beauty bezel around the radio din. Is that even possible? Or is that way to hard and I should give up on that whole idea....
Carputer Progress
[||||||||||] 100%
Finally Installed!!
Old 09-01-2006, 02:08 AM   #11
turbocad6's Avatar
A bit hard to tell from pictures really, but from what I can see you'll have a very tough time getting an exact match to the trim bezel texture wise, BUT in my opinion I don't think that should be your target.... I think you should be trying to match the "other insert", which is the climate control.... & that is exactly what the trim paint I showed will be really, more or less anyway..
but then you need smooooth....
you'd need to step up your shaping a notch or 2, but starting with a flat smooth board your most of the way there to begin with....
if you wanted the texture you could also just by a flat sheet of abs that is already textured, either of these 2 last methods thoudh & you'd have to get a file & spend some time getting you opening right, It's have to be almost perfect for either of these options to look good...
& yeah, I own a bodyshop
Old 09-01-2006, 02:36 AM   #12
we87's Avatar
Well, I was thinking that... The factory radio and the climate controls are both smooth flat black. But personally, I dont think it would look as good for some reason. Ive tried putting up a piece of straight black plastic behind the bezel to see how it looked and it wasnt all that great to me. So, I am going for the texture win loose or draw. At least this time around anyways, I could always do something tricky with it later on down the line....
I dont know. My paint is almost about dry, so I'll see what the deal is.
Carputer Progress
[||||||||||] 100%
Finally Installed!!
Old 09-02-2006, 04:54 PM   #13
we87's Avatar
Well, first I want to say thanks for all of the help and advice
After letting it all dry and sit, I put everything together. And I think I'm happy with the way it came out. It looks pretty close to what I was trying to get, so I am probally just going to leave it the way it is. Here are some of the completed pictures below....
Carputer Progress
[||||||||||] 100%
Finally Installed!!
Old 09-02-2006, 05:15 PM   #14
GoHybrid's Avatar
fine work my friend. looks good!
Old 09-02-2006, 05:44 PM   #15
Pathos's Avatar
Pathos is on a distinguished road
If it were in my car I would be happy
"A rose by any other name is still a flower"
Pathos is offline   Reply With Quote
quick paint question :) rasheedn Fabrication 15 05-07-2006 04:46 AM
Paint And Polish Question gboy Fabrication 8 08-13-2005 08:22 PM
Paint question - matte finish, want to gloss it up Moondog51 Fabrication 18 07-24-2005 06:11 PM
Car Paint Repair Question Max018 Off Topic 4 03-12-2004 01:03 PM
$50 and a can of spray paint later..... notion LCD/Display 4 08-06-2002 11:37 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
