Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 09-07-2006, 03:31 PM   #31
anik321's Avatar
anik321 is on a distinguished road
turbocad,
one hell of a write up man.
did you mention what the second material (by 3m) is called?
99' V6 Solara SE.
'05 CBR600RR
Baltimore MD.
Shuttle XPC| 512MB | 120GB 3.5" Seagate
Opus 150W PS | Rikaline 6010 GPS
7" Lilliput 619 | Centrafuse | IGuidance 3
anik321 is offline   Reply With Quote
Old 09-07-2006, 04:42 PM   #32
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
I attach this by cleaning both side edges (left & right), then very thin double sided tape to hold everything in alignment, you can see the thin red tape backing sticking out from the top in one of the shots... this is so I can slide my insert into possition without the tape sticking to it, then pull the red backing out & attach in the correct spot... I then epoxy from the rear.. I haven't completed this last epoxy step yet, so I left the last post for those pictures... I might be able to finish this tommorow...
the 2 materials used..
turbocad6 is offline   Reply With Quote
Old 09-11-2006, 09:33 AM   #33
BiGGy's Avatar
BiGGy is on a distinguished road
10/10
Looks amazing, so the 2 bezels are epoxy glued at the back? You should make a tab/screw system to make it removable.
Mitsubishi Magna VR-X - Whitsundays, Australia
Continued Worklog... Upgrades in progress:
*15.4" WXGA LED backlight touchscreen upgrade
*Custom fiberglass dash bezel
*768 X 1024 Narrow RR Skin
http://bigs.omfg.net.au/
BiGGy is offline   Reply With Quote
Old 09-11-2006, 09:52 AM   #34
turbocad6's Avatar
yeah, that makes a lot of sense, & is what I originally planned, but me & the owner discussed both options, & in the end it was decided that this wasn't necissary, as he has no plans to do any further modifications to this piece, & refinishing it if necissary as an assembly isn't a problem if the need arose...
also, I am adding 2 more ccfl's to this screen & a touchscreen, & it'll be more stury & the whole assy will be more stiff if bonded,,,,
the main reason to do them as seperate pieces was so that I wouldn'ty harm my factory bezel in the process, but once done, there aren't to many drawbacks to it all being one piece like vertually all other bezels would be anyway....
honestly, if it was mine, it would be removable, but that's cause I'm always tinkering & changing things around, this is more designed for drop in & forget it...
Old 09-12-2006, 04:56 AM   #35
BiGGy's Avatar
ic ic nice work! I only read about 80% of your posts but why did you go with polished black as apposed to the texture grey? Is it to hard to get it a perfect match? It still looks OEM with the black tho.
Old 09-12-2006, 10:11 AM   #36
turbocad6's Avatar
it looks more oem being black than if I matched the grey really, it matches the instrament bezel... it looks the best really in black to me... the other alternative was to match the silver down low, but we decided on the black for the low key factory look...
Old 09-12-2006, 07:44 PM   #37
cherrybomb's Avatar
cherrybomb is on a distinguished road
First of all, super write-up, it's answered a whole ton of questions I had about the fabrication I plan to do.
One question though.
The LCD I got is an 8.4 that didn't come in any plastic case, meaning no trim piece to use as the base for my fabrication like you did. Any suggestions on how to reproduce this piece, or should I just look to cannibalize some other 8.4 screen?
Thanks!
'99 Ford Explorer Eddie Bauer
CarPC Progress ~= 97%. Everything is installed, and operational. Still need to tweak and tune, and do some "finish" fabrication.
CarPC Project Web Site
SpaceNavigatorDriver SourceForge Project
Check out my blog.
cherrybomb is offline   Reply With Quote
Old 09-12-2006, 09:51 PM   #38
turbocad6's Avatar
this lcd that I used is also just an open frame design, I used any old bezel just for the opening precut & perfect, but it doesn't make mounting the screen any easier....
if I didn't have anything, then I'd have to create my opening... that can be a *****, but I've done it before... the best advice I could give to do something like this is it's easier to form your opening with 4 straight edges rather than trying to cut a perfect opening.. the last one I did, I used 4 stainless steel thin rulers, this adds some problems because instead of trying to get perfectly mitered edges to match up, your better off overlapping... then this is cool because the stainless steel edge is what you sand to, it is easier to start with something that has your opening though....
in your case it should be easy enough, just order a spare lilliput housing for an 8.4... I think they have them in the store, & there cheap enough, & if your really lucky it may even help you with mounting too..., I have to order one too now that I think of this... , I'm doing an 8.4 in my car overhead...
Old 09-12-2006, 10:43 PM   #39
dynamok's Avatar
dynamok is on a distinguished road
turbocad6, where do you get either of those two products dynatron and the 3M? I've searched online and found nothing.
Thank you
dynamok is offline   Reply With Quote
Old 09-12-2006, 10:51 PM   #40
turbocad6's Avatar
I know someone sells the dynatron on ebay, any bodyshop supply house should have it too... & the 3m stuff....
Old 09-12-2006, 11:00 PM   #41
Raw Wave
justintime's Avatar
justintime is on a distinguished road
Turbo, you sonofagun, that looks fantastic. Do my bezel, will ya?
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 09-12-2006, 11:29 PM   #42
turbocad6's Avatar
hey jit, if your seriously need help, email me pictures & stuff, I'll see what I can do
Old 09-17-2006, 11:26 PM   #43
turbocad6's Avatar
final pictures are up.... looks really good I think, & the owner is very pleased
check the last shot to get an idea of the viewing angles of this screen...
Old 09-18-2006, 12:20 AM   #44
Siezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to all
Absolutely gorgeous work and an excellent write-up!
"It's a blessing . . . and a curse."
Siezmik is offline   Reply With Quote
Old 09-18-2006, 12:59 AM   #45
Yevmeister's Avatar
Yevmeister is on a distinguished road
put of curiouity, is ths just a monitor, or tablet pc as a whole with nothing else
i am pretty interested in such desigh, in my car it means a surgery though.
what brand tablet it that if aaplicable
Yev
R. T. F. M
Yevmeister is offline   Reply With Quote
How to make the Garmin GPS 35 Work with Copilot 2003 fluffy2097 GPS 16 09-05-2007 05:19 PM
Ford Explorer Custom Lilliput Bezel LOOK CDesigns Classified Archive 14 05-29-2006 11:23 AM
factory power button baller40 General MP3Car Discussion 0 10-19-2005 04:14 AM
How to make a new bezel from a picture frame Psychobiker Fabrication 0 08-25-2005 08:38 AM
BMW bezel Jir1984 Fabrication 6 07-15-2005 03:40 PM
