04-08-2007, 12:07 AM
#76
absolutely amazing... The work is beyound top notch!!! I know the owner lives in Dallas; I'd love to see this thing at a meet.
Setup:
Dynaudio 240GT
PPI PC4100, PPI PC2350
Zapco DSP6
ADS DAC
Testing new board (Albatron KI690-AM2)
"I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
04-12-2007, 09:30 AM
#77
Im looking to do a custom bezel with a 12" sideways widescreen like the OP. I dont have a bezel within a bezel though like the OP describes.
I have vinyl dash surround with a large hole I want to fill that usually has 3 plastic dash panels in place one on top of the other (instead of an inner and an outer). I cant use all 3 in 1 bezel because the top and bottom pieces are pull off slips giving access to the middle piece screw in clips. I want to make my own bezel but I will have to create my own removable mounting system and I was wondering if you have any ideas for this. Ive added some pics below.
Mitsubishi Magna VR-X - Whitsundays, Australia
Continued Worklog... Upgrades in progress:
*15.4" WXGA LED backlight touchscreen upgrade
*Custom fiberglass dash bezel
*768 X 1024 Narrow RR Skin
http://bigs.omfg.net.au/
04-13-2007, 02:27 PM
#78
Super Moderator. If my typing sucks it's probably because I'm driving....
I would think to build some sort of framework behingd the 3 bezels combined into one, then have it hook at the top, then pivot down & get locked in place with a few lower screws only...
04-13-2007, 08:45 PM
#79
interesting theory.
04-13-2007, 08:56 PM
#80
What if..
I cast a mold of all 3 pieces together with fiberglass. I shape the mold to exclude things like air con vents, din opening, ash tray and cig lighter using tape and foil. This way I can choose the position and size of the bezel hole, and also could use a resin based bodyfiller to form it, which I find much easier to use. I would still use that hook and screw system.
04-23-2007, 12:24 AM
#81
that could definatley work, in your case a complete fiberglass new bezel can be a good idea, theres not much of the existing stuff that's usable for you anyway....
05-25-2007, 10:49 AM
#82
07-04-2007, 06:14 PM
#83
primer?
Turbocad6
Thanks by the way you rule men...I busy farbing my bezel for a land rover discovery...and I got a dumb question for you..by primer do you mean the 3m stuff or primer paint..let me know thanks...
07-23-2007, 02:39 PM
#84
I'm looking at doing a similar build, and was wondering exactly how you apply the dynatron around the initial gaps (ie - the large arced gap between the screen bezel and the factory faceplate on the sides)? Do you apply it directly onto the tinfoil and then peel the tinfoil off the back once it has dried (15mins)?
Thanks! :-)
07-23-2007, 02:59 PM
#85
yes, the tin foil is like a mold of sort, it will contain the stuf till it hardens, the tin foil doesn't release as nicely as I would have liked, but on the back side it wasn't a problem
I missed the post above yours, but primer I mean primer, I used a bumper primer for flexability & buildup, but a regular primer should do fine too.
08-17-2007, 07:08 PM
#86
hey turbo
im going to use your technique to build my bez.... i went to get some dynatron and some of the m3 that you used, and the shop i went to said they didn't sell dynatron they said fasco epoxo 88-t10 is the same and it will work.... what do you think
11-01-2007, 09:30 PM
#87
This is my custom Double Din I Fabed up don't have the head unit yet Kenwood DDX7019 ordering this week will post more pics later. Its a 300m No Carputerbut thanks for the info Turbocad6
I forgot to take some pics when i started
 [/img]
11-03-2007, 01:57 PM
#88
Raw Wave
Awesome writeup (and work, of course!) turbocad! Thanks!
11-06-2007, 01:46 PM
#89
WOW, that's beautiful work
11-10-2007, 10:56 AM
#90
| Thread Tools |
| Display Modes |
Linear Mode
