Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 05-14-2008, 01:03 AM   #121
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
turbocad6 is offline   Reply With Quote
Old 05-14-2008, 01:15 AM   #122
turbocad6's Avatar
the lower contour line is less than perfectly straight, a pencil line & ruler can help as a sanding guide to make it crisp... pencil lines can help get everything really straight... here I can see that the left lower edge needs to be filled slightly as it has a slight dip... if it's not all 100% straight, it'll not look factory for sure
Old 05-15-2008, 02:12 PM   #123
VmtSquad's Avatar
VmtSquad is an unknown quantity at this point
Hey thanks again for this DIY thread, its been a really great help for me !! Here's my result with my bezel....took some time but it feels great!!
Question no1: I was looking at your last bezel, at post 119 you applied a WHITE product to fill the holes and make a soft finish what is that product ???
Question no2: Would it be a problem with static electricity if I make a computer case with the Dynatron Epoxy in my glovebox???
VmtSquad - I sold my soul to Honda!
Final Install
CarPC progress: 95%
VmtSquad is offline   Reply With Quote
Old 05-15-2008, 07:56 PM   #124
turbocad6's Avatar
that white product is a flexible bumper primer made by sem. I buy it in gallons but I'd assume there are smaller quantities available... not sure if it's available in aerosol cans though, probably not. I've never looked for a compatible product in spray cans because I just use so much of this, look for something spec.'d as a flexible bumper primer for best adhesion, although a regular high build primer can work, just not as well...
I wouldn't worry about static electricity really, but it won't help dissipating any heat either, as long as you can get some in/out airflow it'd be fine I think
Old 05-21-2008, 11:42 AM   #125
VmtSquad's Avatar
Thanks man, I'll look for that to finish my case design and look.
Keep up the good work buddy!!
VmtSquad
Old 05-24-2008, 11:09 PM   #126
turbocad6's Avatar
ok, more progress. sanded it more, shaped it more,prime sand repeat. got all my lines perfect, got everything flawless, then paint...
Old 05-24-2008, 11:12 PM   #127
turbocad6's Avatar
and...
Old 05-24-2008, 11:16 PM   #128
turbocad6's Avatar
few more & the before picture again :P
Old 05-26-2008, 03:21 PM   #129
Williamz is an unknown quantity at this point
Amazing work!!! Keep it up :]
Williamz is offline   Reply With Quote
Old 05-27-2008, 11:33 PM   #130
VmtSquad's Avatar
You are The king of the custom bezel!!!
Final Install
CarPC progress: 95%
Old 06-01-2008, 09:09 AM   #131
samantech's Avatar
samantech is an unknown quantity at this point
It was really phenomenal job if I am correct. Do you suggest any book or reference too?
thanks really. You save time and life
samantech is offline   Reply With Quote
Old 06-01-2008, 12:25 PM   #132
VENDOR - Nexations Creations
Nexson's Avatar
Nexson is on a distinguished road
Which texture is that, looks great
Brian @Nexations Creations
Specialist in Custom Interior Fiberglass OEM Replication Work.
AIM: Exus28
E-Mail: Exus28@aol.com
Nexson is online now   Reply With Quote
Old 06-12-2008, 05:23 PM   #133
turbocad6's Avatar
hey nexson, I get my texture by varying my spray techniques... the same way you have to try & lay out a flat even coat, if you try to lay out a textured coat you can do it with normal paint even... this particular bezel is with sem trim black... I spray further away so it's dry, this adds texture, then I also have a technique of holding the can upside down & shaking it while spraying... this aerates the paint & also causes it to atomize pretty badly, which is also a good way to produce texture... with a spray gun similar can be done by varying the air pressure & distance... play around with it & eventually you'll be able to create & control your own texture...
this bezel is finished, haven't had time for final shots till now but here they are... this looks like a simple bezel & pretty small but it was a bit challenging as far as bezels go, I've built some larger & more complicated ones that winded up easier than this one... the incompatibilities of the plastics was a major obstacle here & the DVD slot gets kinda tedious, but the final product is 100% & it is still flexible & has all the properties of a factory piece in the end... I did let it cure for about 2 weeks & then sanded it & refinished again... this allows for all final shrinkage to occur & makes sure that the end result is perfect & durable...
Old 06-12-2008, 05:27 PM   #134
turbocad6's Avatar
few close ups & from behind all welded back togeather...
Old 06-12-2008, 08:58 PM   #135
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
That's absolutely beautiful workmanship and craftsmanship. It looks not just completely OEM, but hand-crafted OEM with attention to detail, like I'd expect in high-end machines. Wow.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
How to make the Garmin GPS 35 Work with Copilot 2003 fluffy2097 GPS 16 09-05-2007 05:19 PM
Ford Explorer Custom Lilliput Bezel LOOK CDesigns Classified Archive 14 05-29-2006 11:23 AM
factory power button baller40 General MP3Car Discussion 0 10-19-2005 04:14 AM
How to make a new bezel from a picture frame Psychobiker Fabrication 0 08-25-2005 08:38 AM
BMW bezel Jir1984 Fabrication 6 07-15-2005 03:40 PM
