Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 01-23-2007, 10:51 AM   #1
Dr.jinG is on a distinguished road
Building Custom Box in Enclosed Space?
I have a small space (VERY small) under my rear seats that I'm planning on building custom boxes for 6" round speakers (that's all the space I've got). What would be the recommended method for building a box to fit the space snugly, and be a good fiberglass job?
I was thinking one of two ways:
1) Box in the area with tape/wood/plastic sheet, and lay in glass to build it up (don't get a really good glass box out of this, though, I think), and possibly expand a balloon into the space to hold things in place as the first layer or two cures.
2) Create a plug with expanding foam and a plastic bag, remove the plug, cut to shape, build box around plug, remove plug and seal the box.
Any other ideas? I'm sure this has been done many times but I'm not even sure what search terms to use to find them.
Thanks!
Dr.jinG is offline   Reply With Quote
Old 01-23-2007, 11:02 AM   #2
GoHybrid's Avatar
GoHybrid is on a distinguished road
your first idea is the more conventional method. It will adhere perfectly to the contours of the space if you use good technique in laying the fiberglass down. This means not trying to cover the whole thing in one sheet, cutting/tearing the fabric to better conform to the contours, as well as using a roller to consolidate the layers and press out any air bubbles. This also improves saturation.
the second idea is intriguing. i would suggest going to a packing store and getting one of those bags with the expanding foam inside it. this might give you a more rigid structure to work with and contain your mess. Keep us posted on what you decide!
GoHybrid is offline   Reply With Quote
Old 01-23-2007, 01:33 PM   #3
Thank you, GoHybrid. I've done a little glass work, but hadn't considered the use of a roller. Great idea! I'm assuming a hard rubber roller is the ideal tool. I'll go with this plan, instead of the plug idea, because it will conform to the space the best. Using the roller will prevent poor adhesion (which is what I was afraid of: Too much resin, not enough cloth, and too much gap between them.).
Old 01-23-2007, 02:28 PM   #4
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
yeah, ... also, tin foil is usually best for lining everything for the glass cause it won't stick to it, tape & cardboard can get messy, just layer it with tinfoil after the tape & cardboard & it'll pop right out...
turbocad6 is offline   Reply With Quote
Old 01-23-2007, 02:32 PM   #5
Will do. Thanks, turbocad6 (btw, does that mean you're an exceptionally fast letch?)...
1967 Mini Cooper S turbo project: www.drjing.com
Old 01-23-2007, 02:38 PM   #6
turbocad6's Avatar
turbocad6= a 6 cylinder turbocharged engine in a cadillac
Old 01-23-2007, 03:34 PM   #7
GoHybrid's Avatar
dr.jing, there is actually a specific roller tool made for fiberglass, such as this. The rollers are ribbed which helps the bubbles break through the surface rather than just being pushed around underneath. These are cheap and in fact quite reusable if you have acetone handy to clean your tools before the resin kicks.
Old 01-24-2007, 12:47 AM   #8
Awesome! Being back in the land of Tap Plastics, these will be easy for me to get. Little bit of a drive, but cheaper than shipping!
Thanks for the help, everyone. I'll post when I do the job...
Old 01-24-2007, 06:16 AM   #9
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
your car rocks btw...
ok back to the help
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 01-28-2007, 02:33 PM   #10
Thanks, again, everyone. Sorry I've been away, but I haven't used my home computer in a while, and I don't recall my password for this site, so I can't log on with my work computer... Darnit.
Cheers!
Building the custom center console: a photo journal Cryogen97 Fabrication 32 04-24-2005 01:31 PM
sell laptop and build custom pc in glove box... WebDog General Hardware Discussion 7 11-01-2004 03:49 PM
custom box fabric? bulgogi777 General Hardware Discussion 1 08-30-2004 09:02 PM
Building Custom PC Help SilverGT Newbie 3 06-05-2004 11:50 PM
Consider not building a case for Carputer antimatter Fabrication 6 05-20-2004 01:00 AM
