02-17-2007, 06:49 PM
#1
First Time Fab - 2003 Ford Explorer - Please help! - A lot of pictures...
02-18-2007, 02:47 PM
#2
Further update.
02-18-2007, 05:08 PM
#3
my question is how the hell did u fit that screen above the little bar? i have a 2002 mountaineer and my bezel is the same as urs and i had to cut that little bar off to fit my screen which i just bondo'd in. But now i cant fit my fans back in. Ok i think i just figured out my own question i put the screens original cover in which is much bigger then the screen itself.
02-18-2007, 05:30 PM
#4
Reponse
I thought about just removing the middle black bar entirely also, but the clip that holds the fans is on it. If I remove it then there is nothing to latch the fans onto. So instead what I did was grind/sand the black middle peice down a little with my Dremel, so that the Metra trim kit, my modified bezel, and when the lcd goes in it would butt right up against it basically becoming the bottom of the frame around the LCD screen. I hope that was clear enough. I would love to see a picture how yours turned out.
-R
02-19-2007, 01:42 AM
#5
o i think im just gonna build a grate over the middle to make it look like i have a fan cuz the fan still works but it just looks stupid. or option 2 is that i can just cut the top part of the fan and it would still look fine but im not sure if it would fit and i dont really wanna cut it off if it doesnt fit.
02-19-2007, 02:34 AM
#6
I have officially reached the "what the hell did I get myself into" part of fabricating. I used lightweight bondo to build up around the frame of the trim kit and the bezel. I really don't know how guys get such perfect edges. Its so hard to get in between the little nooks with 40 grit sand paper. I really hope this comes out nice, but at this point I am not so confident. I also don't know how people apply the bondo so smoothly. I guess I just have to keep sanding and then sand some more. Tomorrow I will apply another coat of bondo and then see where I am at. I did notice that while sanding I cut into the side of the tape and now have to bring my bondo up even higher then originally thought. Otherwise I will have to paint the whole thing black and don't really want to do it. I guess I will just see how bad it is after I take off the tape. I still don't know if I am going to be able to fit a indash computer behind this screen yet either, but I guess one thing at a time. Any help or suggestions would be greatly appreciated as I can use some at this point.
Here is the bondo before sanding:
Here is the bondo after first round of 40 grit sanding:
02-19-2007, 05:25 AM
#7
Quote: Originally Posted by diosagain
I have officially reached the "what the hell did I get myself into" part of fabricating. I used lightweight bondo to build up around the frame of the trim kit and the bezel. I really don't know how guys get such perfect edges. Its so hard to get in between the little nooks with 40 grit sand paper. I really hope this comes out nice, but at this point I am not so confident [...] Any help or suggestions would be greatly appreciated as I can use some at this point.
Let me preface this by saying that I have not bondoed a bezel into my dash (yet), but I have used it for years for repairing surfing/windsurfing boards... The trick to it is just apply it in loads of layers, until you get the hang of it...
For your first layer, I always find it easiest only apply enough filler to fill any gaps that exist. That way there's little (if any) sanding to do (though you do need to give it a light sand to allow the next layer to stick well). Once the gaps are filled, you'll have a really good base on which to apply subsequent layers. If you're trying to get a nice straight surface between two edges, use a squeegie or a steel rule, and simply scrape all the excess bondo off. This will usually leave little pits and puckers in the bondo, but if you do it really slowly and have the squeegie nearly parallel with the direction you're pulling it (see attached image) it comes out ok.
Once this layer dries, it's just a matter of giving it a quick sand and then apply a very thin layer of bondo (maybe 2) in order to get a perfect surface finish.
Then lots of wet and dry with a fine grit, prime, paint and serve.
02-19-2007, 05:01 PM
#8
OK, I bought all the squeegee's i could possibly need. I can't wait to get home and apply the other coat of bondo. I also bought Fiberglass Resin Jelly. Do you think I should use this instead of the lightweight bondo? I know a lot of people on the boards are against lightweight bondo because it cracks. I tried the FB resin jelly on the back and it seems like its stronger but even more of a pain in the *** to sand. My fingertips are all cut up from sanding arleady. I should have more pictures tonight.
02-19-2007, 06:08 PM
#9
i wish i had a place to put my mac mini in my dash so i could pop DVDs and CDs in easy (not that i do but it would be nice to be able to). Also i have the electronic AC unit at the bottom and i guess id rather have that there then the mac mini.
02-19-2007, 07:21 PM
#10
In retrospect I would have advised you to start off with the resin (reinforced with fibreglass) to fill the gaps and get the rough shape... Then finished off with the lightweight bondo to get a nice finish.
What I would do in your current situation is as follows: If you think that you can get a complete layer of resin and fibreglass over the existing bondo and over onto the bezel/centre console, then do this. It will strengthen it up no end and should prevent cracking. However, if you're just covering a little bit of the bondo and not the whole area, I can't see the point of doing it as it'll do very little to reduce the cracking and just be a nightmare to sand, I should imagine... Have a search and see what other people are doing... (I'd do it myself but it's bedtime!!!)
Oh and if the resin is just resin (without fibreglass reinforcement) I'd save yourself the time and effort and just stick with the bondo, as resin by itself cracks just as easily...
Happy sanding!!!!!!!!!!!
02-20-2007, 12:51 AM
#11
I am going to start the next layer of Bondo in about 20 minutes. I finally got my motherboard today and decided to just build the computer. Well, at least get it up and running. I used the new Jetway 2Ghz Via mini-atx, with a gig of 533mhz ram, and a a 60 gig 2.5 7200rpm drive. I am still waiting for my M2-ATX psu, CF to ide, and my pcmcia daughter board; but other then that I can at least load windows and RR to get it going. I also want to put a DVD slim slot usb drive somewhere in the car just haven't figured out where just yet. Oh and I also need USB extensions. This **** never seems to end. I am also waiting on a custom indash case from Joe.
http://www.mp3car.com/vbulletin/showthread.php?t=68452
Here is a picture of the mess of a computer I have on my table. My girlfriend wants to kill me as I have now turned our dining room table into a work bench.
Screen still works after the dismantle. I was happy to see this.
Off to bondo and sand.
02-21-2007, 12:53 AM
#12
OK, well I had time to take some pictures today. I must say fabricating is not the least bit fun, but I have definitely learned a lot. I started off bondoing in my house where its warm and felt like I was racing the clock with this stuff. It was drying so damn fast. So I moved it out into the garage and its definitely better there. It took twice as long to dry and I actually felt like for the first time I could use that SQUEEGEE technique. Its starting to look good, but there is a lot more sanding before its ready for priming and painting. Although, I do finally see a little light at the end of the tunnel. I really don't know why I even bothered taping the whole thing off. I guess I was trying to save that factory silver carbon fiber look, but I realize there is just no way. So I started sanding the whole thing down. This way I can just make the entire thing one piece. It will come out much better if I just have to prime and paint the whole thing as one. I hope that this thread helps someone in the future or that someone actually reads this. Anyway here are the pictures:
02-21-2007, 01:51 AM
#13
also, I wouldn't try to sand the bondo to a paintable finish. Definently get some glazing putty to smooth it out.
02-22-2007, 11:39 AM
#14
WoW, ok first thing , did you sand all the areas where you applied body filler?
if not it is probably going to crack off. next time you fab a piece try assembling your pieces together with some type of plastic weld material or epoxy
that is for plastics, you can find them at a local body shop, also your dash piece is flaxible (semi-rigid) body filler isnot, and the thicker you make the less it is, body filler is britle, try next time to use a plastic bumber repair material, it only comes in smaller tubes but its flexural properties are more correct. and always sand everything your going to use first, or it has nothing to adhere to, fillers arent glues.
02-22-2007, 01:27 PM
#15
Houdini,
What is the name of that bumper material? What do you suggest I do at this point? Do I just continue with the lightweight bondo or do I add Fiberglass Resin Jelly over this?
| Thread Tools |
| Display Modes |
Linear Mode
