Go Back   MP3Car.com > Mp3Car Technical > Fabrication
Old 03-15-2007, 10:43 AM   #1
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
89 Toyota Supra Fab Round 2
Well, it's time to redo my Supra screen. I purchased a 2nd hand screen (7" Super/Avatar) from a fellow member and a Metra Ford kits (95-5812) as done by blk02si in this thread. The purpose was to use the Metra kits to build a frame for the LCD bezel to attach instead of fab the LCD bezel directly to the radio bezel. Why you ask? Well, if the LCD crap out on my down the road, I'll just take the lcd bezel out and glue a new on (if different brand) on to the metra frame. This approach will save me from doing another fab job whenever I replace a new screen. The radio bezel is a abs plastic cover with rubber. This combination of material make it really difficult to fab.
Anyway, this is the original fab job on a modded 5" PSOne screen.. I want to re-use the radio bezel although I had in my hand 2 extra bezels from junkyard. I have to remove the old paint and the PSOne screen out.
I ask the forum regarding to paint stripping. Most was suggest to use sanding method
As you can see in the picture below, the paint is pelling off.
A closer look.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 03-15-2007, 11:16 AM   #2
MySQL Error
MatrixPC's Avatar
Thanks to my crappy fab job I did 2.5 years ago, I was able to peel the paint off without any sanding. within 2 hrs.
Next was to prepare the frame and the LCD bezel. The frame is the Metra Late model Ford Kit 95-5812 which is the same as the kit the double DIN in kit (99-5807) that blk02si used in his install.
The bezel sure pop right into the kit openning if you trim the bottom of the bezel.
Well not exactly perfect fit. There is a gap in front of the bezel because the bezel is wider.
I have to either trim the 2 sides of the bezel or modify the side metra kit. I opt to trim the 2 side of the bezel and it pop right in. Perfect .
Old 03-15-2007, 11:58 AM   #3
MySQL Error
MatrixPC's Avatar
I have to trim the radio bezel a little wider to fit the Metra kit in the openning.
Just to double check that there is at least 1 DIN high or room for the Alpine HU.
More test before epoxy. You can see I use balsa wood to fill/jam the gap between the radio bezel and the metra kit.
Epoxy is in.
The back side.
Old 03-15-2007, 12:02 PM   #4
Takes it in the Rear
kevinlekiller's Avatar
kevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud of
Nice, got tired of the psone screen?
kevinlekiller is offline   Reply With Quote
Old 03-15-2007, 12:12 PM   #5
MySQL Error
MatrixPC's Avatar
Actually, I like the PSOne and still do. Really bright for my semi convertible usage. I replace it because I the fab start to get crappy and I can get the 7" for cheap. I just wait and see how is this 7" serve me. Otherwise, I will go transflective .
Okay more to the fab.
After the epoxy was cured, I try to fit the LCD bezel again. I was shock because the metra is twisted a little and no longer a perfect rectangle. It was due to the stretch/squeze when I put those balsa wood.
Also I should of cutting up a piece of wood/board to fit into the kit to keep the it from bending out of shape.
I end up using the solution below to push it out a little and test how good the epoxy really bond the pieces.
Rub around the epoxy part with a 60 grid sand paper and ready for the filling. I already has some SEM bumper repair left over from the Matrix job and use that. I should of try the 3M that TurboCad6 used. So far SEM is good enough base on the matrix job because the bezels are just abs plastic. The supra material is a totally different one. Rubber
Old 03-17-2007, 02:27 AM   #6
MySQL Error
MatrixPC's Avatar
This is the first couple layers of SEM bumper repair.
I put a thin layer at a time. Thin layer give it an option to cure faster then 1 thick layer.
This one is after first 150 grid sand. Before that was about 3 passes of 60 grid sand paper. I just applied more filler to build it up after each sand.
So far looking good
Old 03-17-2007, 02:39 AM   #7
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
looks good so far!
Old 03-19-2007, 01:54 PM   #8
MySQL Error
MatrixPC's Avatar
Here are a few more pics.
Prime, wetsand, glaze putty, prime, wetsand .... about 3 times.
I'm getting tired of sanding and stared to do the whole thing. I thought cuz the original piece isn't perfect, why should I spend too much time make this this portion perfect
The last 2 pics are one with first coat of paint. I use flexible vinyl paint. It isn't sandable paint. So far, it isn't dry evenly, and was taken 5 minutes after spraying.
Old 03-19-2007, 02:12 PM   #9
david69leonard's Avatar
david69leonard is an unknown quantity at this point
Looks way better than what you had before, Awesome job!!!
david69leonard is offline   Reply With Quote
Old 03-19-2007, 04:24 PM   #10
J187's Avatar
J187 is on a distinguished road
Exteme makeover Matix PC style. Looks infintely better. Nice. Can't wait to see it fully done.
Its not the cards you're dealt, its how you play the hand!
Quote: Originally Posted by ryuandwings View Post
Where can I get a roll of tin foil?
I been looking for that all over the net, but I can't find it.
Please help.
J187 is offline   Reply With Quote
Old 03-20-2007, 02:34 AM   #11
MySQL Error
MatrixPC's Avatar
I came home after work in hope to see a nice looking layer of paint, but I run into something unexpected. I was to see that the paint doesn't look normal. There are part that looking really nice while other part is really dull. I try to rub my finger on the dull part and found this.
Rub a little more and I was able to peel the vinyl paint off like rubbing on your dead skin
The paint has soften the primer and tacky like glue.
Anyone run into this type of problem? Paint/primer incompartible?
Old 03-20-2007, 08:41 AM   #12
J187's Avatar
Matrix, first I have to ask out of curiousity, it seems that every time you type the word paint, you leave off the T? I'm just curious why.
About your problem....there are most definitley plenty of issues regarding paints sticking to primers/other paints/surfaces. Laquer over enamel, enamel over laquer, some paints w/ flex agents can soften primer making like a gel... Some primers can never harden over fiberglass(heat reaction).
Exactly what paint and primer are you using, brand and type?
Please help.
Old 03-20-2007, 09:56 AM   #13
MySQL Error
MatrixPC's Avatar
I didn't realize I missed that many "T".
Well, it could be that I am tired after working on it and late into the night + trying to type fast
The primer I used is Plasti-Kote Sandable Primer. This is the leftover on my Matrix Job. On the can it said "Fast Dry Lacquer Primer For Lacquer, Enamel or Acrylic Topcoats"
Paint was make by RustOleum Vinyl paint. Leftover from my previous Supra job. I used RustOleum primer previously, but the result still not that perfect.
Anyway, I am running low/out of that Vinyl paint already, so I am going to buy something else by Plasti-Kote. Any of these you guys recommended (will be in flat black)? I am thinking of bumper or vinyl paint as those are more flexible than the other 2.
Old 03-20-2007, 11:07 AM   #14
J187's Avatar
Trim black or wrinkle paint. I recently used the wrinkle stuff and LOVED it. perfect match to a dashboard that I recently molded an xm receiver to.
You should be ok painting on a laqcuer primer. But I'm suspect of the flex agent used. It says vinyl resins are used...may not react well with laqcuer primer or non etching primer in general. I'd go with a different paint. The ones above sound good. Unless you expect the piece to flex quit a bit, I wouldn't worry about having flex agents. Just spray a few coats and hit it with a clear coat if you don't mind the finish - its much stronger. Look for one of those little plastic gun trigger attachments for spray cans, they make control of the can much easier when painting and they are like $1.99 in the spray paint aisle.
These
Please help.
Old 03-20-2007, 12:00 PM   #15
MySQL Error
MatrixPC's Avatar
After a little searching/reading, I think the "flexible agen" is the problem. I'll go with the wrinkle paint to see how it look. Probably, it will be better than trim black paint due to the imperfection looking on the original piece.
As of how flexible is the piece, well, it was make of plastic cover in THICK rubber to give it a soft touch/feel. When I try to sand off the old paint, I got a feeling of filing/repairing a bicycle tube instead of working on my radio bezel.
Oh yeah I see one of those gun in most place where there are spray paint.
91 Toyota Supra Fabrication dsballer2000 Fabrication 79 06-06-2009 09:18 PM
1998 Toyota Supra RZ-s Install jazz13 Show off your project 17 04-22-2007 07:01 PM
89 Supra Turbo finished (for now) drait Show off your project 16 04-16-2007 12:38 PM
WANTED - Toyota Supra 1990 Roof bars tracysupra Classified Archive 3 11-01-2005 07:22 PM
Toyota Supra TT mkiv spyda Show off your project 31 02-21-2005 06:08 PM
