Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 06-25-2008, 03:39 AM   #1
rgarjr's Avatar
rgarjr is an unknown quantity at this point
FAQ How to power up multiple devices
Sometimes you may find yourself having a lot of carpc devices that require 12V battery, 12V ignition, and ground. You can use terminal strips, jumpers, and spade connectors to wire up you gear. You can easily add more devices as well.
My carpc worklog
rgarjr is offline   Reply With Quote
Not enough power to USB devices >> Possible Solution? Tuckie General Hardware Discussion 20 11-16-2005 12:24 PM
Which Power supply to use with External devices? Sorex Power Supplies 0 08-17-2005 03:55 PM
FS: ITPS shutdown controller and PW-70a MINI-ITX power supply hanzacra Classified Archive 4 08-07-2005 11:32 PM
Which devices should I power with the OPUS? slushieken Power Supplies 4 08-24-2004 04:19 PM
how much power does different devices take?? mrzigzag Power Supplies 1 06-05-2003 01:41 PM
