Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Closed Thread
Old 10-14-2004, 08:42 PM   #16
joebagodoe's Avatar
joebagodoe is on a distinguished road
I've thought that, but I thought I should ask. Thanks!
joebagodoe is offline
Old 10-15-2004, 03:13 AM   #17
LeoTheHamster's Avatar
LeoTheHamster is on a distinguished road
How about using a BatCap for a tank circuit?
Leo
http://www.talkaudio.co.uk
Quote:
A million people can't be wrong, right?
Well... unless they're all from the red states...
LeoTheHamster is offline
Old 10-23-2004, 05:30 AM   #18
ky_khor's Avatar
ky_khor is on a distinguished road
sorry i'm very new to "carputer". (i even spent 10++ seconds to figure out what is "carputer")
1. when u turn off the car completely, will it cut off the power supply to the computer?
2. how will shock when driving affect the computer?
ky_khor is offline
Old 12-11-2004, 10:52 AM   #19
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
Quote: Originally Posted by fluffy2097
We've also had a few hard drives fail due to cold weather.
A properly mounted hard drive should not give you problems. Unless you run into a tree.
Two points, from lots of experiance.
Cold effects hard drives with FDB (fluid dynamic bearings) by slowing the RPMs of the platters this reduces the chance to boot but does not hurt the drive at all. After it warms a a little it will boot just fine.
Other drives are fine.
Running into a tree will cause the driver and other parts of the car far more trouble than the HD. My HD has been in 3 or 4 wrecks one bent the frame on my 91 toyota truck (totaled the truck). The HD is still in use.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline
Old 12-11-2004, 10:57 AM   #20
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Remind me NOT to accept a lift from you.
Enforcer is offline
Old 12-11-2004, 11:18 AM   #21
TruckinMP3's Avatar
No worries... the interesting thing about the wreck is none of them were my fault.
TruckinMP3
Read the FAQ!
Old 02-06-2005, 11:05 AM   #22
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
HMMMMMM, I own a body shop & I talk to many who are involved in accidents & I can tell you that at least 90% of the accidents are "not my fault..."..I guess all of the people causing the accidents are going to a different shop?
turbocad6 is offline
Old 02-06-2005, 12:00 PM   #23
TruckinMP3's Avatar
Buy a vowel, I was rearended 3 times.... one of them the other driver was drunk, one on a cell phone the third was digging in her purse.
The big one a driver turned left across my line of travel (was ticketed for failure to yeild) Then he stopped across my lane.... traffic in the lane on one side of me and a median on the other. No where to go and the distance was 15 feet.
TruckinMP3
Read the FAQ!
Old 02-06-2005, 05:47 PM   #24
I've got no answer!
Question's Avatar
Question is on a distinguished road
Hey! Keep on topic please.
Question is offline
Old 02-16-2005, 02:13 AM   #25
agarbino is on a distinguished road
How about making a wiki out of all this info? Make different categories, and allow all the real info to build up there; it should take traffic off the forum and reduce chatter for people looking for info.
Alex
agarbino is offline
Old 02-25-2005, 01:55 PM   #26
shinny's Avatar
shinny is on a distinguished road
What are the standard dimensions for a head unit?
Edit: I found these dimension for the external dimeters of a head unit - 7" x 1-15/16" x 6-11/16"
Are they right? And has anyone ever sqeezed a mini-itx inside a head unit?
shinny is offline
Old 03-13-2005, 02:14 PM   #27
patbateman is on a distinguished road
wiki
I second the idea of starting a wiki. Using threads works well but a wiki is much more easier to navigate and update.
patbateman is offline
Old 03-22-2005, 08:37 PM   #28
stinger is on a distinguished road
scuse the ignorance.. but what the heck is a wiki..?
would an inverter running a standard home pc run ok in a car? what sorta wattage inverter would u need to do this? i wouldnt mind making one with a lil case n stuff, but just for mucking around and seeing what i can do at this point..
stinger is offline
Old 03-22-2005, 08:52 PM   #29
kmcniece's Avatar
kmcniece is on a distinguished road
I have had problems with inverters (small ones) and my laptop. If the battery is not fully charged it drains more juice from the inverter to get back to full charge. This caused my inverter to over heat. I hung it in front of the AC to cool it off and it worked fine. I would suggest getting a better inverter if you choose that route. Mount it someplace it will get air flowing over it.
With an inverter and nothing else, you will have to boot each time you start your car, or drain your battery. I believe.
If I could point you in the direction of the information about Power supply power consumption and inverter requirements I would, but I'm not sure where that information is, I'm sorry.
EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
Status:
Installed & Working....
Custom enclosures
Newbie Guide
kmcniece is offline
Old 04-21-2005, 03:21 AM   #30
Wyattx17's Avatar
Wyattx17 is on a distinguished road
Wouldn't a battery backup Help this situation? I am thinking of running UPS off the inverter (400 watt+). Any one have any opposing opinions?
Wyattx17 is offline
Closed Thread
