Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Closed Thread
Old 10-16-2004, 03:33 PM   #31
ppgt94's Avatar
ppgt94
Quote: Originally Posted by murdaki11
ppgt94 trying to PM you but your box is full
Im going to be doing pretty much the same install you did. Was wondering about your speakers setup. If im correct you arent using the HU anywehre. When hooking up amp, to sound card, did you have to rewire any speakers or anything?
Do you have the monsoon system?
You can PM me now.
ppgt94 is offline
Old 10-16-2004, 05:19 PM   #32
Tred is on a distinguished road
cd adapter
im thinkin of just running a cd tape adapter to the output on the mobo. What is so bad about wiring it like this? what problems may i get?
Tred is offline
Old 10-16-2004, 06:20 PM   #33
Raw Wave
Rob Withey's Avatar
Rob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to behold
I started my system out like this. It's perfectly fine, and you get what is effectively a ground loop isolator for free (between the heads of the tape and the player).
Systems retired due to new car
Rob Withey is offline
Old 10-18-2004, 01:25 AM   #34
Thanks, is sound quality effected?Hissing?Static? also what should be be the ratio of volume of the pc to the head unit? is there some way to calculate that, since I think it might be dependent on watts.
Tred is offline
Old 10-18-2004, 01:37 AM   #35
edikp is on a distinguished road
Quote: Originally Posted by roller
Hello (sorry for my english, I'm spanish) !
I have a problem with the sound in my carPC. I have an Alpine 7894RB and I bought and adapter for connect "AUX IN", next I bought a jack 3,5 - 2 RCA conector. The physical connects are OK.
The problem is:
When I'm listening music in my car by FM or CD source that's ok, but when I select de AUX-IN source I only can hear the music, video .... by one side of the car.
The balance control in CarPC it's Ok, in the Alpine the same.
Could you help me ??
Thanks a lot
Rubén
roller, make sure that the 3.5 jack is all the way in. I've experienced same symptom as yours and turned out that it's not all the way in. Also, sometime the outer jacket of the connector kinda in the way which hinders the jack to go in all the way.
edikp is offline
Old 10-18-2004, 11:15 PM   #36
ecaandrew is on a distinguished road
how would you set it up to have the soundcard play the speakers off your head unit, and the soundcard go to your amp and sub
ecaandrew is offline
Old 10-19-2004, 12:08 AM   #37
ppgt94's Avatar
ppgt94
You use a multiple channel sound card.
ppgt94 is offline
Old 10-19-2004, 01:07 PM   #38
ok heres what i want to do, i want to hook up the center/subwoofer from the sound card to the amp to sub
and i want to hook the soundcard up to the headunit as well so the headunit is hooked up to the speakrs, but in the diagram above it shows one Y adapter going to the head unit, which port is the adapter plugged into???
the adapter going to the SUB would go in the "CENTER" port on the sound card probably?
but where would the adapter going to the headunit go to, which port??? cause there is front and rear? you would hook up both right but how? thanks
Old 10-20-2004, 11:27 AM   #39
ppgt94's Avatar
ppgt94
You don't have to. I would suggest not to since your headunit input is only stereo. I think you should use the front channels for the headunit. Use the rear channel output for the subwoofer. The amplifer for the subwoofer will most likey (or should) have a low-pass filter crossover and can accecpt stereo input. There are other solutions but this would work just as well in your situation.
ppgt94 is offline
Old 10-20-2004, 03:00 PM   #40
i just forgot im not even using my headunit, im using my carputer for music, so can i use the front channels on the sound card and hook that up to the front speakers, and the rear channel to the back speakers, and the center to the amp to sub?
Old 10-21-2004, 03:27 PM   #41
ppgt94's Avatar
ppgt94
Yes. Although you can't go straight from sound card to speakers. You need something like a amp inbetween to drive the speakers. You probably know this from the images. Just thought I'd make it clear for others who may not.
ppgt94 is offline
Old 10-29-2004, 06:43 AM   #42
mayh3m's Avatar
mayh3m is on a distinguished road
Just exactly how bad is a FM Modulator?
My head Unit (JVC KD-G405) doesn't have any inputs
I have the choice of hooking my PC up to the head unit with a modulator or buying an amp and making some kinda switch system to switch between the two (head unit and pc) to play through the amp. Currently the head unit is hooked up directly to my speakers as the power is good enough for me.
I don't want to lose CD quality sound.
What is the best bet?
mayh3m is offline
Old 10-29-2004, 11:12 AM   #43
Marsupial's Avatar
Marsupial is on a distinguished road
I had modified my FM modulator in order to get "descent" audio - otherwise it looks like you are listening to Montreal radio while being in Ottawa 100 miles away.... and even with the homebrewed extended antenna, the sound get quircky sometimes - it depends of the other available radio stations. You might have to change your "station" from time to time.
All in all, it rarely gives a CD quality audio, there is almost always some parasite. But maybe its my cheap ratshack modulator...?
-Mars
Carputer progress meter:
[----------] - 0%
status:
Changing project. The kiosk I have will end up in the kitchen! Reviewing carPC ideas...
Marsupial is offline
Old 10-29-2004, 11:18 AM   #44
mayh3m's Avatar
What did you do to make yours better Marsupial?
mayh3m is offline
Old 10-31-2004, 04:46 PM   #45
OriginalNick2 is on a distinguished road
What sort of Wattage should the 4 chanel amp be? dont want it super loud, i also have a 1200W amp to power a sub but is only 1 or 2 chanel.
Nick
OriginalNick2 is offline
Closed Thread
PC To Car Speakers eCar™ General Hardware Discussion 5 08-17-2008 01:35 PM
First Car PC Questions - Pretty Long Post Sorry :D [56k death] FiReToY Newbie 9 06-08-2006 06:15 PM
Car 5.1 Dsp Options Vs Pc 5.1 Dsp port20 Car Audio 13 05-29-2006 03:10 AM
Car power supply (battery charger) from old pc supply stimps Power Supplies 8 08-24-2004 08:59 AM
Another pc sound -> car speakers question Juz General Hardware Discussion 13 10-17-2002 12:47 PM
