The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Closed Thread
Thread Tools Display Modes
Old 02-20-2005, 05:28 PM   #76
My Photos: (0)
uh, no.. how would yoru speakers be powered?
Carputer HIFI car stereo project!
[XXXXXXXXXXXXXXXXXXXXX-]
95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
[XXXXXX--------------]
30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
miztahsparklez is offline
Sponsored Links
Old 02-21-2005, 03:07 PM   #77
jbraddoc's Avatar
Vehicle: 1998 Cadillac Seville SLS
My Photos: (0)
Through the amp.. I thought that would be self explanatory... :-\
jbraddoc is offline
Old 02-21-2005, 03:26 PM   #78
Vehicle: 2000 Subaru Impreza Outback Sport
My Photos: (0)
Only if you have an external amp. I don't for example, so your approach doesn't work for me.
Arathranar is offline
Old 02-21-2005, 03:38 PM   #79
My Photos: (0)
what would be the point of hooking your pc to the speaker wires? that wont do anything. you will be lucky if you get any sound at all. first of all, speakers need quite a bit of power. on top of that the ohm load probably wouldnt be very good for your soundcard.
Old 02-21-2005, 10:56 PM   #80
jbraddoc's Avatar
My Photos: (0)
Okay let me clarify this... You listen to FM radio all the time, and cannot find a good USB FM radio antenna, so You want to hook the car's original HU to your computer, so you can still have sounds from your computer, for mp3's and what not, and when you are not listening to those, you listen to the stock radio. Okay, that Or, say you have a navigation system with voice guidance, and you want it to 'lower' the volume on the stock system. You take the outputs from the stock HU (the ones to FR FL RR RL speakers, and hook those onto a headphone jack, and plug that into line in, and take the line out, and hook it to an amp, then to the factory wires, so that the FR, FL, RR, RL speakers get powered, and then you can have both worlds..
jbraddoc is offline
Sponsored Links
Old 02-22-2005, 12:04 AM   #81
Vchat20's Avatar
Vehicle: '96 Ford Windstar
My Photos: (0)
i should also add that depending on your vehicle, it may have an amp that is seperate from the radio. if this is the case, you can easily find a wiring harness online which will allow you to directly wire the amp into your pc or any other aux device.
Ford Windstar XP (last update: 06/25/05)
Current Progress:
[▓▓▓▓----------------]20%
Planning Near Completed. Some Parts Bought/Salvaged
Vchat20 is offline
Old 02-22-2005, 06:43 PM   #82
kamikaze2112's CarPC Specs
kamikaze2112's Avatar
Vehicle: 99 Pontiac Sunfire
My Photos: (0)
I don't know if this will work or not (won't for laptop ppl, but will for the ATX/mini-itx crew), but most TV tuner cards have FM radio tuners....
for example:
http://search.ebay.com/pci-radio-tun...dsreturnedZ300
Like i said. May work for some. don't know what the SQ is like, but definately a solution.
kamikaze2112 is offline
Old 02-22-2005, 07:51 PM   #83
Vchat20's Avatar
My Photos: (0)
i think what the main issue in this thread though is getting the sound to the speakers in the car. pc fm tuners have been around for quite some time.
Current Progress:
Vchat20 is offline
Old 02-23-2005, 04:17 PM   #84
My Photos: (0)
Ok don't assail me please, but I have a quick question.
When I was in highschool I took an amp I got and a portable CD player. I connected the CD player to the amp as youguys suggested here and it was super quiet no matter what.
Do computers output a stronger signal or something? If not isn't a car computer really quiet as well? I ask b/c I am trying to get up to date so that I can build myself a car computer. I want to replace my headunit in a subaru WRX...
sxotty is offline
Old 02-23-2005, 04:27 PM   #85
Vehicle: 2003/Chrysler/PT Cruiser
My Photos: (0)
i cant answer your question but in high school i did the same thing except i am so old that we did not know what cds were at that time well they just came out anyway all i had was a cassette walkman ran it through a alpine amp to alpine speakers and it played better than some of my friends high dollar head units
Tangerine_Man is offline
Old 02-23-2005, 10:33 PM   #86
ppgt94's Avatar
Vehicle: MKIV VW Jetta
My Photos: (0)
There are many variables and one of many things could have gone wrong. Are you sure the amp you were using (or the connections you used) accepted low-level inputs or line-level speaker input. If you pluged a low-level output signal (like CD walkmans) into inputs for line/speaker level you'll get a very low volume output.
How did you plug the portable CD player into the amp? Did take the headphone outputs and use a 1/8" miniplug to RCA adapter or cable and to go into the RCA inputs of the amp? Was the volume on the CD player turned up? If so it should have worked alright. This is of coarse assuming everthing was in working order and it wasn't just a whimpy amp and/or speakers.
Most consumer sound cards output low-level signal. This is usually enough for an decent power amp to take and output sound as good or better than a headunit playing a CD.
You'll find that almost always a seperate external amplifier is going to sound better than any head unit amp.
ppgt94 is offline
Old 03-07-2005, 09:42 AM   #87
My Photos: (0)
Steering Wheel Controls
Does anyone have a solution to incorporate steering wheel controls to control the volume and etc?
buddylee7 is offline
Old 03-07-2005, 10:32 AM   #88
ltrain1007's Avatar
Vehicle: 2001/BMW/330i
My Photos: (0)
Search
http://www.mp3car.com/vbulletin/search.php?
"I-Bus"
ltrain1007 is offline
Old 03-10-2005, 02:32 PM   #89
My Photos: (0)
I have the following:
Eclipse 54400 head unit - no aux input.
Eclipse Model 3640 4/3/2 Channel Power Amplifier
Dell MP3 player
After contacting my local Eclipse dealer, they confirmed that there is no aux input on the head unit. They mentioned RF modulators, doing something custom, etc. I've heard RF modulators and they really do compromise the sound in my opinion. Anything custom would cost me a bundle.
I thought that since I have the external amplifier, I could likely buy or build an RCA selector switch that would allow me to toggle between the head unit and the MP3 player.
I've attached a diagram of what I think I need.
I've seen some existing switches/selectors available, but almost all are designed for video - red, white and yellow RCA.
The head unit has four RCA outputs, the amp has four RCA inputs. The MP3 player has a single headphone (mini 1/8") out with which I can use an RCA Y adapter.
It seems, to build something, I would need a small box with four inputs for the head unit, and two inputs for the MP3 player, and then four outputs to the amp - with a switch to select which input source to direct to the amp.
Can someone help provide a novice with information about the appropriate parts and the wiring info I would need to build such a thing? While I don't have any real experience with this sort of project, it seems like it should be simple enough.
Or if this set-up is available for purchase somewhere (again, I can't seem to find much other than video switches) I'd appreciate a tip.
Thanks.
bcw55 is offline
Old 03-11-2005, 03:45 PM   #90
My Photos: (0)
i have been looking through this thread and am confused on something. everyone is talking about 5.1 and such.... but noone mentions anything about time alignment. the whole idea with 5.1 is that you get sound from all these differnet speakers to your ears at certain times. well in a car.. you sit to the left of a center speaker. you practically sit ontop of the left speaker.
for those of you going straight from a 5.1 card to an amp... how are you dealing with time alignment? does the hardware app/firmware support this? is there external software that does it??
i just ordered my carpc... and am still wrestling with the idea of keeping my head unit (time alingment built in) or going straight from the carpc.
thanks
chrislloyd is offline
Sponsored Links
Closed Thread
vB code is On
Trackbacks are Off
First Car PC Questions - Pretty Long Post Sorry :D [56k death] FiReToY Newbie 9 06-08-2006 05:15 PM
Car 5.1 Dsp Options Vs Pc 5.1 Dsp port20 Car Audio 13 05-29-2006 02:10 AM
Car power supply (battery charger) from old pc supply stimps Power Supplies 8 08-24-2004 07:59 AM
PC To Car Speakers eCar™ General Hardware Discussion 2 02-11-2004 07:44 AM
Another pc sound -> car speakers question Juz General Hardware Discussion 13 10-17-2002 11:47 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
