03-31-2005, 10:57 PM
#106
yes he wanted you to buy a stereo.. what you need is a line driver =P
Carputer HIFI car stereo project!
[XXXXXXXXXXXXXXXXXXXXX-]
95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
[XXXXXX--------------]
30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
04-01-2005, 02:34 AM
#107
Quote: Originally Posted by miztahsparklez
did you try setting the gains?.. most likely you need a line driver to boost the signal of the sound card so it works with your amp. your soundcard probably doesnt put out enough power for the amp.
Where can I get a line driver? What specs will it need? Is there a specific brand or model? Will using a different sound card work? If so will a usb soundblaster do the job? Thanks so much for your help.
Reason: incomplete
04-01-2005, 02:45 AM
#108
Vehicle: '96 Ford Windstar
id try to run straight from the carputer to the amp without a line driver. nothing should be damaged, and depending on the sound card, it should be able to provide enough voltage for an amp to be able to work with it.
Ford Windstar XP (last update: 06/25/05)
Current Progress:
[ ▓▓▓▓----------------]20%
Planning Near Completed. Some Parts Bought/Salvaged
04-01-2005, 11:47 AM
#109
I've tried it. It isn't working. I think you have me confused with Song0330. I'm the one that is running straight from my sound card to my amp, with no success. Will switching to a usb soundblaster solve my problem? Do I need a line driver?
04-05-2005, 10:35 PM
#110
Vehicle: Acura TL 2004
Get line drivers here:
http://www.logjamelectronics.com/linedrivers.html
I think the PIE is good enough for your purposes... I am getting one too. Sound from my laptop to the head unit line level input is too low for my taste. =)
04-06-2005, 08:06 AM
#111
Vehicle: STi
The guy at Car Toys must have been in awe when he saw the CarPC and not to mention the idea.
How I'd love to see him try to tell me that my setup is hooked up wrong, I'd say what did the five fingers say to the face (slap) ahhaha.
Silver Wing -
Get a headphone and plug it into the back of your PC soundcard and listen to see if it's outputting a audio signal. If so, then your soundcard is fine.
Next to test the amps....
I suggest you get a mp3player, cd player, or old walkman, and plug the 1/8th jack into it that goes out into RCAs to your amp and see if it amplifies your mp3player or what you test it with. If it amplifies, then your amps are fine, if not, then your input on the amps is screwed up or something.
Let me know how your testing goes... After that you should be a ok.
04-08-2005, 07:53 PM
#112
Silver Wing -
Thank you for the response.I had already found the problem. Your troubleshooting tips are exactly what I had done. I meant to post earlier. I re-tested everything and did find that my sound card had gone out. Bought a usb audigy nx. All works perfectly.
04-09-2005, 12:43 AM
#113
Vehicle: STi
Glad to hear that Silver Wing.
I also use the NX and like the results.
04-09-2005, 10:12 PM
#114
I have a question. I have a new HU in an old car - no AUX IN. Now I had to buy an adapter cable so the new HU can plug in the old cables.
Kind of like this:
(OLD CABLES)======(my solder job)====(New Cables into HU)
I saw an article caying if you make your own Y-splitter adding a 10k resistor on each input line will eliminate the feedback-problem. can I do something like this?
(OLD CABLES)======/\/\/\/\/\============(HU)
\\==/\/\/\/\/\/\====(Amp)===(Carputer)
Or did I miss something?
Also one more question - we use shielded cable going from the pc to the amp - but regular wire when goig from amp to speaker. Should I use regular wire when going into the nest of cables behind my HU, or shielded? Why don't we uses shielded all around?
04-09-2005, 10:57 PM
#115
you could run shielded cables for the speaker.. but why bother.. the power running through the speaker wires is generally a pretty high voltage which rejects noise pretty good.
04-12-2005, 06:08 PM
#116
can someone give me a quick answer?
I am setting up my audio setup using the 5.1 guide on this thread.
Question is.... I have an Alpine HU that has Aux-in. now how can i use that to control volume?
I have 1 mono channel amp for my subs, a 4 channel for the speakers.
I really want to use the HU for volume control. possible?
04-12-2005, 07:17 PM
#117
Vehicle: STi
How do you plan on getting 5.1 sound if you run it through your headunit?
04-17-2005, 05:10 PM
#118
i just wanted the headunit to control the volume.
is it not possible?
04-17-2005, 06:35 PM
#119
Vehicle: STi
You can have the HU control volume if you run the Sound Cards main audio output to the Headunit via Auxilary in , or a FM Synth to go over 87.5FM or something.
But if you want 5.1 sound or similiar you will need to hookup the soundcards 3 outputs to get that, if you don't the sound from rear and stuff won't come out. So you can't use the HeadUnit if you want 5.1 sound.
My soundcard has 3 outputs being used now, 1 to the front left and right, 1 to the rear left and right, and 1 to the subwoofer and center channel (But I dont have cc, so i put the slider down so it doesnt output.)
So basically yes, you can run the soundcards green 1/8th somehow into your Headunit, but you wont't have 5.1 sound, just stereo. In the car 5.1 isnt that great, actaully not good for music, just DVD movies and stuff which I never watch in my ar. I always listen to music, so I set my Sound Blaster CMSS setting on Stereo x's 2. Where it changes it from 5.1 mode to a regular type of stereo mode.
04-18-2005, 11:37 AM
#120
thanks leslie,
let me recap..... i don't care too much for 5.1 so i will.......
aux in on headunit to green 1/8th on sound card. Then hook up the amps to the headunit just like any amp install on a car. right?
| Thread Tools |
| Display Modes |
Linear Mode
