Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 07-02-2005, 08:14 AM   #16
273BeLow's Avatar
this might be handy. If you want to cheaply wire four speakers up to a two channel amp then simpy run four wires (two sets of twin) from your amp to the front and then have a Left +/- and a Right +/- then wire the two left hand speakers to one set and the two right hand speakers to the other thus:
sorry if it's obvious but it saved on running lots of cables.
273BeLow is offline   Reply With Quote
Old 08-22-2005, 10:45 PM   #17
how are you guys connect the 4-12 gauge wires to your power supply?
the wires on my m1-atx are very thin (i'm guessing 16+ gauge) , are you just connecting the larger guage wire to the 16+ gauge wire?
thanks.
2001 Acura CL traded for a 2006 Subaru Legacy GT
7" Lilliput Touchscreen
NANO-ITX+m1-atx
512 DDRsodimm
60g SATA Laptop HD
4x Apple DVDslot
digimoto OBDii
mS GPS
mini BT keyboard
relocated HU faceplate
acura cl is offline   Reply With Quote
Old 08-23-2005, 09:33 AM   #18
Dragonknell911's Avatar
I can tell you that no one does that. In order to realize any effects of using larger wire, you have to use larger wire all around.
Most likely the 16 gauge wire is unsoldered by reheating, and then the new larger wire is soldered into its place.
At least thats what i plan on doing
Dragonknell911 is offline   Reply With Quote
Old 09-16-2005, 04:03 PM   #19
I think this is a misunderstanding. I'm not going to get into a long technical response, but for short distances, gauge isn't a big issue. If the device harness supplies a 1 ft 16gauge wire, you won't see any benefit to cutting the harness shorter as the device doesn't require it. Now if you were running a 1500w amp, 16 gauge wouldn't cut it for any length of course.
The point being, 4 gauge for 20ft split to 8 gauge for 1 ft is no different than running 4 gauge to each device unless the device requires more than 4 gauge to begin with.
  • 2.53ghz, Maxtor 200GB, 1gig RAM, ASUS miniATX w/ HD Audio & PCIE
  • 150w OPUS, DVD, VideoMate TV/PVR/FM, GPS, Wireless-G, Antec Aria case, RoadRunner
  • JL Audio 450/4, 1000/1 - XR650CSi, 12w7, Lilliput 7" touchscreen
EuroFan is offline   Reply With Quote
Old 09-19-2005, 08:05 PM   #20
Banned
heres a question, I have 0 gauge wire running to the rear of my truck for my amps, could I tap into this for power to my 150w Opus? If I can, how would I go about doing it? sorry for the basic but important question
jasondavis is offline   Reply With Quote
Old 09-20-2005, 01:00 PM   #21
As long as you fuse it properly it will work just fine.
wrx614 is offline   Reply With Quote
Old 09-20-2005, 09:16 PM   #22
I would say just take the 12v+ from your opus and put it on a wire going to your amp. I plan to just unscrew one of the amp wires from the fuse block and put my PSU wire in there with it. But I am a newbie too and actually have a remote power on/off control.... no fancy startup/shutdown controllers here.
kameleon is offline   Reply With Quote
Old 03-26-2006, 06:05 AM   #23
273BeLow - I wouldn't advise people to wire 2 speakers into one chanel of your amplifier. The problem with doing this is that wiring two speakers in parallell with each other like that reduces their impedance which inturn results in higher current through the amplifier.
Most amplifieres are designed to handle ONE 4 ohm speaker on each chanel - putting the two speakers in parallel will reduce the equivalent impedance of your speakers to 2 ohms and you risk overheating your amplifier - possibly invalidating its warranty (not 100% sure about that) - and u loose a good amount of your output power inside the amplifier as well.
If you are not putting much power through your speakers then i wouldn't worry about it too much just be aware that its not the best thing to do to your amplifier. If you really want more speakers i suggest buying a better amp.
Spuzzdawg
spuzzdawg is offline   Reply With Quote
Old 04-11-2006, 09:31 AM   #24
HAHAHA! Watch the wires!!
Some people think they have it down pat...
RED is NOT ALWAYS 12v
eg...
older Ford Models:
12v - Green/ Yellow
Switch- BLACK/pnk
Ground- BIG RED WIRE
--CROSS THESE WIRES AND SAY GOODBYE TO YOUR PROJECT---
jnetn99 is offline   Reply With Quote
Old 05-15-2006, 10:22 PM   #25
blk02si's Avatar
2 things to add,
Im running my m2-ATX off an OEM 20 amp radio circuit in my dash with no issue at all. (been running good for 6 months now)
Im also running a 2 channel amp off of another OEM 20 amp circuit. I am running 4 speakers off of this amp without an issue either. I however wired my speakers in series NOT parallel because the OEM speakers are 4 ohms each. By wiring them in series im putting an 8ohm load across each speaker channel so my amp will not run hot. If you put them in parallel you are dropping the load to 2 ohms and most amps are not 2 ohm stable on each channel. Permit me to elaborate with this cheesy paint render
My carPC - www.shocknet.us
blk02si is offline   Reply With Quote
Old 06-25-2006, 07:35 PM   #26
thats just asking for disaster... wire speakers in SERIES not parallel...
mike6789 is offline   Reply With Quote
Old 07-23-2006, 07:24 AM   #27
_
hu?
yes, this is true, but why wouldn't you advise people to run an amp at 2 ohm? nearly every amp on the market is 2 ohm stereo stable now a days.
There is a lot of misinformation in this thread, like here for instance....
no - most amps now a days are stable at 2 ohm stereo, as I stated above.
If the amp is stable at that ohm load, you may increase your distortion, but because you are now putting out more power and probably running double the cone area, you are able to turn your gains DOWN due to more output period.
you would NOT void your warranty by running an amp at a rated impedance level.
If the amp specs say the amp will do it, why would it void your warranty?
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 07-23-2006, 07:25 AM   #28
_
eg...
older Ford Models:
12v - Green/ Yellow
Switch- BLACK/pnk
ditto! red is NOT always positive....there's those blanket statements again I keep seeing....blanket statements are baaaaaad
Jan Bennett
Old 07-23-2006, 07:30 AM   #29
_
SINCE you are wiring your amp in series, then you probably aren't pulling more than 10 amps, and in this case this is fine. However, this can be a dangerous post for those who will be running their amps at 4 ohm or 2 ohm. In general, this is not a good idea.
Yes, that's one of those blanket statements I hate so much, but it's one that's true.
this is incorrect.
I'm not sure where the people in this thread are getting that modern amplifiers are not 2 ohm stereo stable, but it's absolutely not correct.
Modern amplifiers are almost always 2 ohm stereo stable.
re: your paint renderings:
the first one: "not good unless you have a 2 ohm stable amp"
correct, but again, MOST modern amplifiers are 2 ohm stereo stable. I'm worried that someone will read that and freak out because they aren't well educated in the car audio world. They will see it and think that they are all wrong, when in fact they aren't.
use this as an example:
someone goes out to a big box retailer and buys a 50 x 2 amp @ 4 ohms to power 4 speakers.
they wire it up in series (8 ohms), you get 25watts x 2 @ 8 ohms. Meaning each speaker gets 12.5 watts. Now you have to turn up the gains to get the expected volume output out of those speakers, meaning you're more likely to run into clipping and distortion because your gains are up so high. When if you had run them in parallel to get 2 ohms out of them, you're running at 100 x 2 @ 2 ohms at the amp, meaning 50 watts per speaker, meaning gains lower to get the same amount of volume. Meaning, less likely to have clipping and / or distortion. Yes, distortion at lower impedances will be higher, really good ears don't even hear 5% distortion. Yes at 2 ohms the amp will pull more current, and yes at 2 ohms you need to beef up your wire and grounds, but you get more out of your amp.
The root cause of the issue can be solved by buying the proper equipment for your application, if you have 4 speakers, buy a 4 channel amplifier.
re: your second image: series allowing you to turn gain up without risking clipping or blowing out a channel.
this is along the same lines of what I have already said.
if you're higher impedance you're less power, thus you HAVE to turn the gain up to get the needed power output.
Jan Bennett
Old 07-23-2006, 07:40 AM   #30
_
why do you say this?
how is this a disaster?
again, I'm lost as to why people in this thread think that parallel is the debbil??
again, most amps are 2 ohm stereo stable...it should be fine!
Jan Bennett
