The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Thread Tools Display Modes
Old 05-31-2005, 12:04 AM   #1
Admin
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Help me Build a "suggested systems" FAQ for n00bs
Hi folks, I'm trying to put together a FAQ for newbies that answers one of the commonly asked questions, "Can you just tell me what to get so I can do my install"?
Newbies often come on here and want to jump right in but get very confused about what to buy and whether they have all the right stuff or not. What I'd like to do with this thread is give four ready made systems (I can do more if we need to, but 4 sounds about right) that meet different needs.
1. Cheap install.
2. Compact/low power. (Probably a Via install)
3. Zippier but still compact (a mini-ATX? I don't really know much about these)
4. Damn the torpedos, full speed ahead! (Gamer's delight, no holds barred, max power)
I need your help to put this list together. Yes, I know it will go out of date quickly, but it will serve as a guide to newbs who can't seem to figure out all the stuff they need and want a "parts list"
When specifying a system, make sure you include the mobo, power source (i.e. inverter or DC-DC) and approximate prices for the system. I'll consolidate the answers into a single point FAQ eventually.
I can start a separate thread on each of these systems, if that would make it easier. Let me know. Thanks for the help!
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Sponsored Links
Old 05-31-2005, 12:28 AM   #2
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
Vehicle: 1995 Lexus SC300 1997 Mazda Miata
My Photos: (0)
1.
VIA EPIA M10000 - $154
256/512 Megs of DDR266 RAM $26/45
80gb 5400RPM Laptop HD - $100
Slim CD-RW/DVD drive - $90
Slim Converter USB - $50
M1-ATX - $75
2.
VIA EPIA SP13000 - $249
512 Megs of DDR400 RAM - $45
7200RPM Laptop HD - 7200RPM Desktop HD - $168
120w Opus - $149
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 05-31-2005, 12:34 AM   #3
Vehicle: 1989 Toyota Celica
My Photos: (0)
Cheap!
gong chep has its side effects. It can be more challanging as well as much harder to do.
For a good cheap system, you need any smllish Motherboard and CPU laying around. I am using a 1.3 Ghz AMD athalon cpu with 256 of pc133
(total cost new, around $70?)
For the Video, I bought a $25 ATi 7000 that has S-Video out. this is connected to a 4 inch LCD that natively uses 12 volts. (can be pulled right off of the pc power supply) A screen of that size is less than $100
For power, I built a 550 watt 12 volt (car power) DC to 120 volt (Us ac) adapter. These can be purchesed for around $50. Any standard or small footprint pc (baby tower) pc power supply will work
For input, I took a $4 keyboard, and took it apart. Inside is a thin plastic set of sheets that did the work in the large unrollable keyboard. A little bit of sharpie to lable the keys, and you have a roll up keyboard for cheap. Also, as I just use winamp, a serial control can be used to control the basic functions of playback a quick search or wiamp.com's plugins tells all. As a new feature, I found a nifty device called OpticalBar that gives you touch screen like capabilities, and has some powerful software.
Any old IDE desktop drive works well, but I did throw mine in a removable tray so that I could update my music Database as needed.
A 20x slotloading IDE desktop drive is hard to find, but can be gotten for around $5 at some used computer shops. By useing a slot loeading drive, you have less of a hassle when ptting a new cd in.
For a case, mine is made out of metal and plexiglass
A gps is optional, but I use a Tripnav GPS that is just under $100
And software, nothing fancy, just Windows xp, Winamp, mappoint and girder to tie together everything
Everything is in USD
I will update and finalise this post when it is not 2 am, and others are more than welcome to take/expand apon/fix all the spelling issues... this post
Every day driver, 1989 Celica. Probly won't get a carpc for a while
Working on: 1972 240z. Gonna put a V8 and a Turion in it. Best power in bothworlds. Now if only I could get my theoretical boot as low as my theroretical 1/4 mile time (8.22 s)
Geking is offline   Reply With Quote
Old 05-31-2005, 01:25 AM   #4
Jesus Freak
antimatter's CarPC Specs
antimatter's Avatar
Vehicle: 2006 Mazda Mazdaspeed 6 GT
My Photos: (0)
Good idea.
For the cheap setup what are the space requirments?
antimatter is offline   Reply With Quote
Old 05-31-2005, 01:30 AM   #5
Admin
Bugbyte's Avatar
My Photos: (19)
No space requirements. Just cheap! Although it looks like we may need a "cheap" and a "dumpster diver, found computer stuff cheap"!
Old 05-31-2005, 02:35 AM   #6
nzKAOSnz's Avatar
Vehicle: 1992 Subaru Legacy VZ Wagon
My Photos: (0)
Really cheap/ghetto install: only for MP3's
Brains:
- old atx computer. anything over a 200Mhz will do. pref with onboard sound, and onboard lan helps. If doing a custom case - avoid P2's as their cpu is quite tall - and restricts the size. a socket 370 cpu (a 433 i think) did me well
- only needs 32mb-64mb odd ram.
Storage:
- Hdd - 2gb min - doesnt matter if its a 3.5". they make things easier & cheaper
only put your current selection of music, and the OS on this.
Power:
- Search round and find a cheap DC-DC psu. Something such as the morex psu can often be found cheapish. I paid the same for my 80W morex as what an average 400w desktop psu is worth.
Input:
- get a cheap keypad. can be found in most computer places.
Display (optional):
- Find a hd44780 compatible charater LCD. 16x2 is enough.
Wire this up to your parrallel port. Diagrams on net.
Programs:
- Win98. Cut it down if wanted
- Winamp
- Markus Zedhner's LCD plugin (not sure if spelt rite)
Case:
- Either dust off the old woodwork skills - or use a normal case. (i did say ghetto)
Thats all i can think of at the moment - total cost for me:
Motherboard+CPU: $40 i think
Ram: very little i would assume (had lying around)
Harddrive: 4gb cost me $10-20
Power: Expensive bit - $80
Input: $20-40
16x2 LCD: $40+$15 for wiring
Case: cost me $20 of sheet perspex
Programs: all free except windows 98 (?)
So i spent less than $200 on first carputer.
THIS IS NZD$ so you do the maths
92 Subaru Legacy Wagon
Epia MII12000 :D
Morex 80W
120G External HDD
16x2 Charater Display
Creative IR Remote
VIA Sereniti 2000 Mini ITX Case
7.2Ah SLA Tank
PCMCIA 802.11b
256DDR Ram
Diamonds are for girls- wise men follow the stars
nzKAOSnz is offline   Reply With Quote
Old 05-17-2006, 09:32 PM   #7
chomo's CarPC Specs
chomo's Avatar
Vehicle: 2004 Volkswagen New Beetle 2.0l
My Photos: (0)
How cheap is cheap???
I did my first try with an old PIII 800MHz with 128MB RAM with a Matsonic MoBo and a AT 200W PSU, two hard drives, a 3.5GB for the OS and tools and a 10GB 2.5" HD, a USB numeric keyboard and no screen... Except for the 2.5" HD and the keyboard, which I got from an old laptop that didn't work anymore, I basically just dismantled an old PC I had laying around my house; so I didn't spend a single dime! I did buy a 300W DC-AC inversor, but it was a real bargain: less than US$30!!! I didn't get to even see what I was playing, but I did love every single song I had in my collection and back then it was a cheap alternative to an iPod.
By the way: doesn't the apple shuffle go for about US$99 and does exactly the same and nothibg else?
Car PC progress: 60%
Pics coming soon!!!
chomo is offline   Reply With Quote
Old 06-30-2006, 04:42 PM   #8
DodgeCummins's CarPC Specs
DodgeCummins's Avatar
Vehicle: 96 Dodge Ram 2500 Cummins Diesel (turned up)
My Photos: (20)
I am still running my cheap system.
The only thing it won't do is run video...well...
But it plays MP3s WHILE running the moving map software.
$150...maybe less now.
To run only mp3s a P90 could do it...
I think you need to define the task...not the price.
If you simply want to run mp3s with no visualization...then buy a pocket mp3 player and plug it in. ($60 total)
If you only want visualization...get a low cost mobo (something in the 500+ mhz range) and almost free everything else...but put a few bucks into the screen...a standard composite screen will be fine for this task. ($150 total)
If you want to play DVDs and other video files, (and perhaps a nice on screen control center with touchscreen) then you will need as a minimum a M10000 miniitx...and can get crazy expensive from there...up to one of those Pentium M mini motherboards.
Also now you need to get a couple of nice VGA screens...$200 to $1000...each. These start sucking the power so you need to spend some bux on a nice 12v power supply...from low price to Opus. (so from $500 to $2000 total)
current projects
DodgeCummins is offline   Reply With Quote
Old 06-30-2006, 04:46 PM   #9
Raw Wave
Tidder's CarPC Specs
Tidder's Avatar
Vehicle: 04 Pontiac Sunfire (The Racer is dead...)
My Photos: (0)
Wow, talk about bringing dead posts back to life...
Tidder is offline   Reply With Quote
Old 06-30-2006, 05:38 PM   #10
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
hey dodge - are you aware of the D/FW meet July 9th?
http://www.carpctexas.org/forum/portal.php?topic_id=55
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Sponsored Links
Old 07-12-2006, 10:50 PM   #11
My Photos: (20)
Nope...
current projects
Old 07-13-2006, 07:47 AM   #12
_
My Photos: (73)
maybe you would be interested in this page as well: http://www.carpctexas.org
Jan Bennett
Sponsored Links
vB code is On
Trackbacks are Off
97 Toyota Tacoma You gotta See This. NEW UPDATE with 100+ pics on 7-4-03 cproaudio Show off your project 97 09-18-2006 01:56 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
