Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 05-31-2005, 08:51 PM   #1
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
FAQ: Getting Rid of that Whine or Buzzing Noise in Your Speakers
So, now you've installed your PC and hooked it up to your stereo. It rocks! Except for the fact that there's this "buzzing" noise, or "whine" coming through your speakers! It may seem to pick up when you accelerate and slow down when your rpms go down, or it may just be a persistent buzzing noise. Either way, it's ruining your install! What's up and how do you get rid of it?!
The noise is nearly always caused by improper grounding of your system. According to the wikipedia, a ground loop is caused by an unwanted current that flows between a conductor at two points that have nominally the same potential.
Wha?! Here's what's happening. The chassis of your car serves as a ground. Often when installing PC's and amplifiers, they are located in different parts of the car. The ground wire for both units is often grounded in different spots on the car. While the metal chassis is a decent conductor, it isn't perfect and there can be a difference in electrical potential between the two grounding points. The result is a buzzing noise, or a whine, often coming from the alternator, which accounts for the change in the sound as the alternator spins faster and slower with engine rpms.
There are two possible solutions:
1. Ground all components to the same point. This will reduce the potential and should greatly reduce any noise.
2. If number 1 is not possible (and it often is not), use a "ground loop isolator", available at nearly all electronics stores, or car audio suppliers. This device prevents a direct electrical connection between the two sources and will usually fix the ground loop.
The source of the whine can be mysterious and very difficult to track down even if you perform 1 & 2, above.
For more information, search on terms: "Ground loop", "alternator whine", or "buzzing".
Useful threads:
http://www.mp3car.com/vbulletin/show...ht=ground+loop
Car audio professionals/geniuses, please post any tips or tricks in this thread. Thanks!
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 06-05-2005, 01:52 AM   #2
Stealth97 is on a distinguished road
Also, a loose audio connection between your PC and amp, or PC, head unit, and amp (depending on your install) can cause a constant buzzing sound. Often the Y-adapter connecting the sound card is not pushed in fully. That one has bitten me several times.
Is this where the witty comment goes?
97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
Stealth97 is offline   Reply With Quote
Old 06-06-2005, 07:08 PM   #3
crypto is on a distinguished road
Talking or
or you can get the ground straight from the battery... run two wires from the battery (pos and neg) instead of one(pos)...i know you can get the ground from the chassis but its better if you get it straight from the battery terminal...
just my 2 cents
crypto is offline   Reply With Quote
Old 06-07-2005, 05:18 PM   #4
Mr. Wiggles
shakes's Avatar
shakes is on a distinguished road
As an added note, in a CarPC setup sometimes buzz or hum can come from an unmuted MIC or Line-In on your sound card. this has been happening to me lately.
Another thing bugbyte probably meant to mention, is make sure your groud points are clean. That means sand/grind off all paint and such so you get a clean metal on metal connection.
Regarding grounding to the battery ... I've always heard and read it's better to keep your ground cables as short as possible. YMMV ... so if they're long and you get no noise more power to ya.
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
shakes is offline   Reply With Quote
Old 07-07-2005, 03:07 AM   #5
Yuriy's Avatar
Yuriy is on a distinguished road
I recently discovered than background noise can get higher in volume substantially if your battery is low. In my case, to drive my three 12" woofers I require more current than the alternator can provide, therefore my battery eventually discharges and needs manual charging. I noticed that when it's very low, the whining noise is simply horrible to a point where you can't hear anything. But as soon as the battery is charged to 50% or above the noise is removed completely.
00 Saturn SL2, boosted @ 8 psi - CarDomain
Newest install - my quickest ever
My 2nd carputer - b4 I broke the touchscreen
My very first carputer - voted the most ghetto
Yuriy is offline   Reply With Quote
Old 07-09-2005, 04:28 AM   #6
Levin is on a distinguished road
It's also possible that the RCA cables are too close to power cables. While most proper setups would ensure that power cables do not run near or beside audio cables, people make mistakes...like me. I solved it by moving the power cables further until there was no more "whine".
Levin is offline   Reply With Quote
Old 07-09-2005, 11:18 AM   #7
Bugbyte's Avatar
I too had a slight whine upon finishing my install. Rerouting my audio wires away from my power wires (they were carried in a common wire bundle) made a huge difference.
Want to:
-Where is the iBug?
Old 07-10-2005, 01:45 AM   #8
KyleYankan's Avatar
KyleYankan is on a distinguished road
same for my install - power wires down other side got rid of all of it
KyleYankan is offline   Reply With Quote
Old 07-10-2005, 06:00 PM   #9
carabuser's Avatar
carabuser is on a distinguished road
Getting Rid of noise using POWER INVERTER:
The main idea: ground EVERYTHING POSSIBLE that runs from the inverter.
My experience: Using a laptop and Lilliput 7" both powered by an inverter (from sig. lighter). A lot of noise in the speakers, a lot of noise on the screen as well.
Solution:
1. Grouning the screen (yes, screen does make noise): simply take the negative line from the screen's power adapter and ground it.
2. Grounding the laptop: same thing, take the negative line from the laptop power adapter and ground it to the chassis.
My two grounding points for laptop and screen are at two different locations but there's NO noise when the system is on.
However, there's still loud noise when I turn the laptop off.
EDIT: This might sound stupid to those of you who's been in "business" for a while, but I'm sure people with less experience can use it: use HIGH quality cables. In my case I'm using a cheap radioshack cable to connect laptop to my HU and over time quality went down and I can hear a lot of noise now.
2000 Maxima CarPC
Current Status: Rebuilding
Specs
- 1.5Ghz Toshiba Laptop
- Indash Motorized 7" VGA TS
- DeLorme GPS
- Power Inverter
- Pioneer HU
carabuser is offline   Reply With Quote
Old 07-11-2005, 10:08 AM   #10
Yuriy's Avatar
Funny how electronics work, when I turn on my inverter 80% of the noise goes away.
That's not saying that I have a lot of noise, and have almost zero, but whatever's there, it goes away when I switch the inverter on. That's a complete opposite of my last system, where turning on the inverter means you'd be listening to your alternator instead of MP3s.
Old 09-04-2005, 08:44 AM   #11
KyferEz is on a distinguished road
A little more info about grounding...
It's not always a good idea to ground directly to the battery, as long lengths of wire can be the cause of ground loops as well, as previously stated. If you make sure you have a heavy grounding wire (4gauge or larger) from the - terminal of the battery to the vehicle's body, then most often grounding to the body of the car will be fine. However, there will be noisier ground spots on certain locations of the body than others, and these locations are different for each and every car.
Also, grounding everything to the same ground point may not be necessary, and may even make the situation worse, depending upon the gauge of wire used and if the 1 ground point you choose was already a noisy location because of all the other ground currents flowing around your vehicle.
The BEST thing to do is try each and every suggestion you can find and see which works best for your particular vehicle/setup. (Or at least try them until you find one that you can live with.
KyferEz
TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
PSU Wattage Calculator
Electronics Calculators
Copper Wire Data
KyferEz is offline   Reply With Quote
Old 10-01-2005, 02:27 PM   #12
attack eagle is on a distinguished road
if you are adding big loads or long runs, please consider upgrading the chassis to battery ground to 2ga...
another thing is that with many electronic devices like amplifiers and other metal cased devices the outside shell is ground. Avoid if possible screwing and in essence direct grounding them. For some reason they will give you noise if they are grounded thru the chassis instead of thru the ground wire.
mount them isolated, using a wood block or plastic to electically isolate the chassis from chassis.
Ever since i started doing this 8 years ago I have never had a single alternator whine problem in any install. Example, in my current car I have 2 ga power, changer cables speaker cables and 3 sets of rcas bundled together, and in my mgb after adding a bigger ground for the dual batteries, and isolating the amps and crossovers by building a trunk board all noise was eliminated, and that was a noisy little car to begin with.
attack eagle is offline   Reply With Quote
Old 11-02-2005, 06:38 PM   #13
12Vsystems's Avatar
12Vsystems is on a distinguished road
In the past I have had problems when running cables near the air condition. Everything sounds great until I turn the A/C on then I get a buzz. Rerouting the cables away from the A/C solves the problem.
12Vsystems is offline   Reply With Quote
Old 11-02-2005, 06:55 PM   #14
carabuser's Avatar
I have/had very similar problems. Same thing happens with rear window defroster.
2000 Maxima CarPC
Specs
- DeLorme GPS
- Power Inverter
- Pioneer HU
Old 11-03-2005, 02:03 AM   #15
anky1's Avatar
anky1 will become famous soon enough
http://www.termpro.com/articles/noise.html
older article but always a good start.
RIP 1993 civic sedan
RIP 1993 civic Del Sol
Hello! VW Golf 1.8t
anky1 is offline   Reply With Quote
Buzzing noise help fletcher5555 Car Audio 19 05-30-2005 07:03 AM
Troubleshooting: NOISE RedGTiVR6 Car Audio FAQ 0 03-26-2005 11:31 AM
Buzzing noise when shuttle is plugged in mazda3uzr Car Audio 17 12-22-2004 09:59 PM
More details on my buzzing noise.... sq_geek General Hardware Discussion 4 11-02-2004 01:46 PM
noise from rear speakers, please look at video sanbas Car Audio 4 09-25-2004 08:46 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
