Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 10-04-2005, 01:28 PM   #31
alti's Avatar
alti has a spectacular aura aboutalti has a spectacular aura aboutalti has a spectacular aura about
Quote: Originally Posted by tj!2k4
fp may not accept system variables like that.. you may have to specify the full path.
that is what i meant, i was only using the variable to signifiy that i dont know where his windows installation is. Hope i did not confuse you, muldrick.
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
alti is offline   Reply With Quote
Old 10-04-2005, 04:34 PM   #32
muldrick's Avatar
muldrick is on a distinguished road
Right. I did not change the directory when installing windows, so they should be:
c:\windows\explorer.exe
and
c:\windows\system32\calc.exe
Correct?
AtmosUSA.biz, E-Cig Mods
muldrick is offline   Reply With Quote
Old 10-04-2005, 05:09 PM   #33
alti's Avatar
and
Correct?
that is correct
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 10-04-2005, 06:25 PM   #34
muldrick's Avatar
Quote: Originally Posted by alti
that is correct
Ok, I had done that, just never tried it. After I had entered it into apps. it kept (keeps) saying "FALSE-FALSE" after the command line. But it works fine, added a bunch of other stuff too. I like this
Thanks for your help.
Old 10-28-2005, 01:34 PM   #35
vairu's Avatar
vairu is on a distinguished road
great post!
vairu is offline   Reply With Quote
Old 11-24-2005, 08:58 PM   #36
ayclens is on a distinguished road
Quote: Originally Posted by justintime
A quick note: For me, when bringing up the Task Manager, and using the New Task (Run...) feature, if I type explorer.exe or explorer, all I get is a browse window. It does not load the full explorer desktop etc.
Any ideas?
Did you ever get this problem solved? I have the same problem - if I type 'explorer.exe' or 'explorer' I just get a browse window. I want the explorer GUI to load...why does it seem that nobody else is having this problem?
ayclens is offline   Reply With Quote
Old 11-27-2005, 05:06 PM   #37
Raw Wave
justintime's Avatar
justintime is on a distinguished road
Nope, could not get it fixed. No idea!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 11-28-2005, 09:20 AM   #38
IntellaWorks's Avatar
IntellaWorks is on a distinguished road
Once you've told windows to launch another shell (c:\frodoplayer.exe) you cannot launch explorer in shell mode. You can only launch explorer as a window. With this said, this FAQ doesn't show users the BEST way to launch an app as the windows shell.
Instead of fooling with the registry just leave it the way it is. Boot your carpc's OS up in another computer and re-name explorer.exe to explorer.bak.exe then place your front ends exe and files into the same folder. Rename your front end's exe to explorer.exe.
The reason why fooling with the registry is undesirable is simply because what if you want to change back to explorer to make a settings change? I suppose you could write two .BAT files that automate this but in my case, my system is EWF'd and its a pain in the *** to disable this stuff in the car. Its much easier to bring the drive into the house and rename explorer.exe
or I created a smart front end chooser, see instructions here: http://www.mp3car.com/vbulletin/show...ighlight=Shell
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 11-28-2005, 11:59 AM   #39
arebelspy's Avatar
arebelspy is on a distinguished road
I have 2 registry (.reg) files to switch back and forth between my frontend and explorer.. and of course a batch file to apply changes if I'm running it in a EWF (for HORM) state at the time, both easily accessable through the explorer app embedded in the frontend .. pretty simple and easy for anyone that wants to take a minute to set it up so they can switch back and forth quickly.
-arebelspy
See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
Quote: Originally Posted by xdjxklusivex
i think every thread is now a whoreing thread
arebelspy is offline   Reply With Quote
Old 11-28-2005, 03:39 PM   #40
@ arebelspy: Holy cats this is exactly what I'm struggling with trying to do right now. I'm sending you a PM to ask for a copy of the reg/batch files
3 of my reg/batch files work fine, but the one to change the explorer to Frodoplayer won't work for some reason. I'm not really good with writing reg files so I'm sure I'm just making a stupid mistake...
Old 11-28-2005, 04:05 PM   #41
arebelspy's Avatar
well the batch file i ws referring to was to apply changes to an EWF system, as I stated.
As far as registry files, just export the explorer one that's default, then create the one as described in the first page of this thread and export that.. now you have 2 registry files you can click back and forth between and reboot to change the shell.
-arebelspy
Old 11-28-2005, 05:25 PM   #42
Here is what my reg file to change the shell to Frodoplayer looks like:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"Shell"="C:\Program Files\Frodoplayer\Frodoplayer.exe"
But it doesn't work. The shell stays as explorer.exe. Do you know why?
My other reg file changes the shell from Frodoplayer back to explorer.exe no problem...but I have to manually modify the registry to change the shell to Frodoplayer...
Old 12-06-2005, 09:01 AM   #43
Tekmazter is on a distinguished road
%systemroot% is the 'default' for all NT boxes (NT4/2K/XP/2K3) while %windir% is a nice little add-on in most installations for application calls etc...
Quote:
^ think you meant to say %windir%
opps
Muldrick, if your file system is setup like above and you are running XP they *should* be there.
Tekmazter is offline   Reply With Quote
Old 12-26-2005, 12:06 PM   #44
d_sellers1's Avatar
d_sellers1 is on a distinguished road
I went and tried to make a .reg file so the shell could be easily changed. For some reason, the registry seems to not allow the shell to be changed via a .reg file. Even when I'd manually change it (which it would take) and then export the key, the registry would not make the change. Perhaps its some kinda of safety within Windows to prevent this from happening.
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
d_sellers1 is offline   Reply With Quote
Old 12-26-2005, 03:43 PM   #45
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Derek
Create the .reg in safe mode.
Why do we need car Front End software?! nijel Software & Software Development 45 04-09-2006 01:50 AM
Recomend a front end. bigmac999 Software & Software Development 7 05-03-2005 03:24 AM
Roll your own front end wysocki FrodoPlayer 27 05-01-2005 11:46 PM
BASIC Stamp question Banderon General Hardware Discussion 18 05-07-2004 09:33 AM
cool front end software liquid_smoke Software & Software Development 3 09-02-2003 01:23 AM
