Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 05-15-2006, 11:03 PM   #61
Bboy_jon is on a distinguished road
so for centrafuse, do i just hit the "run as shell button" in the settings? or do i still have to mess with the registry?
Bboy_jon is offline   Reply With Quote
Old 05-16-2006, 12:47 AM   #62
d_sellers1's Avatar
d_sellers1 is on a distinguished road
It's been a while I played with Centrafuse but if there is an option to run it as the shell I would use that option. More than likely it is going to do all the steps described earlier for you. I'd take a look of in the Centrafuse forum to see if anyone has had any problems with this or not. If it's an available option, it should be okay.
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
d_sellers1 is offline   Reply With Quote
Old 05-20-2006, 04:11 AM   #63
Cirion is on a distinguished road
Yes, it's as easy as that. This is definately the best way to do it, since it's reversable. So if you ever want your desktop back just disable it again and reboot.
Also for starting other apps needed, you can add those in Startup Commands. CF will then load all those apps at startup so you wont need your windows startup folder.
Cirion is offline   Reply With Quote
Old 05-20-2006, 04:28 AM   #64
how would i add the "my computer" id mainly close it to do hard drive stuff
Old 05-20-2006, 04:55 AM   #65
If you dont need the Windows Shell, but just Explorer to navigate throug your HD's then you can embed Explorer.
Then you can use Explorer inside CF like I doo
Old 05-20-2006, 05:30 AM   #66
AHHH good thinking, run it as an external app?
sweetness ill do that tomorow, so basically i will NEVER EVER have to exit centra lol
Old 05-24-2006, 01:18 AM   #67
d_sellers1's Avatar
Quote: Originally Posted by ITL
just put a frodo shortcut in the startup folder under the START > Programs list...
When people want to run their front-end as the shell, normally they don't even want explorer to be running. What's the point of having a program running that you're not going to use. Besides, it is a memory hog.
I'm running a stripped down version of XP right now. I have 16 applications running counting RR, winamp, iGuidance, and SkinBedder. In this configuration I'm using 106Megs of RAM. Windows by itself was using 66Megs. Explorer, IIRC, uses about 12Megs just by itself. Wasted memory. Plus it shortens the boot time with one less thing that needs to be loaded (or saved to memory when hibernating). My system is up in about 5-10 seconds.
Derek
Old 05-24-2006, 01:27 AM   #68
geezus
ya mines 40 seconds using the regular size xp pro
i tried nlite, but it ended up witht he same boot time and more problems (alot of missing necesary files)
Old 05-24-2006, 01:45 AM   #69
d_sellers1's Avatar
geezus
PM coming your way with more information on the build that I'm running.
Derek
Old 05-25-2006, 07:41 PM   #70
chewEboy's Avatar
chewEboy is on a distinguished road
Great Idea but but because "explorer.exe" is not running.... no other progs are running either
ie.....
I need a bluetooth thing to load up and my wireless interntet to conect....
but becase explorer is not loaded.... these things dont start
so all that loads is my frontend (RR) on its own.... and the GPS dont work (as bluetooth not loaded) and internet dont work (as wireless internet thing not loaded)
is there a way to get these two things to boot aswell as just my front end?
Living the dream!
AMD Athlon 1700
512mb ram
7 inch toch sceen
wireless
bluetooth
GPS
See my car and setup
http://www.cardomain.com/ride/847490/1
[++++++----] 60% finished
chewEboy is offline   Reply With Quote
Old 05-25-2006, 07:58 PM   #71
d_sellers1's Avatar
ie.....
Just because explorer.exe is not running does not mean that nothing else is going to run. I have RoadRunner set as my shell and my Bluetooth module, USB GPS, and Buffalo wNIC adapters all load with no problems. I also run iGuidance within RoadRunner along with SkinBedder and iGMon. I can also use Firefox to access the internet when I am connected wirelessly. I can also manually start Explorer.exe by launching it from within RoadRunner. So again, explorer does not need to be running to do what you've described.
EDIT: To answer your question: You should be able to set you front-end up as your shell and have the front-end loaded your desired programs.
Derek
Old 05-26-2006, 08:57 AM   #72
chewEboy's Avatar
ok my bad...... u was right....
it just seems that my bluetooth GPS thing wont automaticly conect to the computer..... so have to phisicly open up the program to get it to conect!!
damb it... im so close to getting it how I want it then another problem comes along...
off to GPS section I guess
Living the dream!
AMD Athlon 1700
512mb ram
7 inch toch sceen
wireless
bluetooth
GPS
Old 05-26-2006, 07:03 PM   #73
Raw Wave
justintime's Avatar
justintime is on a distinguished road
WHat command do you use to startup the DESKTOP (explorer with full desktop view) from your frontends? I have had mixed results... using 'explorer.exe' or even 'explorer' seems to just bring up a plain explorers window, without full desktop...
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 05-26-2006, 11:27 PM   #74
d_sellers1's Avatar
In all technicallity, explorer is just that: the plain explorer window. However, when it is run as the shell, then you get access to the taskbar, system tray, desktop, and various WIN+ key shortcuts. From within explorer you can still access your Desktop. It will be at the top of the list on the right hand side of the window.
Derek
Old 05-26-2006, 11:50 PM   #75
Raw Wave
justintime's Avatar
Well, I really want a full desktop view to load so I can access START menu, tray icons etc.... it used to work for me, but not anymore.
2002 Honda CR-V
Why do we need car Front End software?! nijel Software & Software Development 45 04-09-2006 01:50 AM
Recomend a front end. bigmac999 Software & Software Development 7 05-03-2005 03:24 AM
Roll your own front end wysocki FrodoPlayer 27 05-01-2005 11:46 PM
BASIC Stamp question Banderon General Hardware Discussion 18 05-07-2004 09:33 AM
cool front end software liquid_smoke Software & Software Development 3 09-02-2003 01:23 AM
