The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Thread Tools Display Modes
Old 07-16-2006, 05:33 AM   #76
chewEboy's Avatar
My Photos: (0)
ok ive got a new problem now dudes.... and I think its cos I changed my setup to boot straight into front end... by using this tread
when pc first comes on.... the touch screen behaves very strange.... but after about 30 - 60 seconds its perfectly fine....
when I say strange.... its like its not been configered and it things its being pressed and when u touch it it wont react properly... (just like it aint be setup)
I can only assume its summit to do with the driver not being loaded straight away... then it gets loaded and its fine???
anyone got any tips that could maybe help me with this?
Living the dream!
AMD Athlon 1700
512mb ram
7 inch toch sceen
wireless
bluetooth
GPS
See my car and setup
http://www.cardomain.com/ride/847490/1
[++++++----] 60% finished
chewEboy is offline   Reply With Quote
Sponsored Links
Old 11-06-2006, 11:40 PM   #77
Vehicle: 04 Honda Accord Coupe (6 MT)
My Photos: (0)
tried your guide and I was able to boot directly into Road Runner. Everything seemed to be working fine till I opened GPS and found out that for some reason GPS is not locking to any settelites. So I imported the orignal registry (with Explorer as shell) and restarted the computer and everything started working again.
What could be the connection between GPS unit and explorer ? that it does not work when window boots directly to frontend ?
ajamils is offline   Reply With Quote
Old 11-07-2006, 09:27 PM   #78
My Photos: (0)
Hi guys, I've too booting directly into RR. Well, it's much faster and simpler.
I've got a problem though.
IVT Bluetooth Soleil
I can get it to load embedded when I'm having explorer as the shell, but not when I boot directly into the frontend.
It seems like it's loading embedded, but the screen never pops up (it does when I'm on explorer shell). Wondering if anybody has encountered that and what is a possible solution?
I notice when I launch it it resides in the taskbar, not on the desktop. Might this be a possible cause?
I also have wifi (Aztech) and it works OK on both explorer and RR as my shell.
Thanks in advance
SentraVIP is offline   Reply With Quote
Old 11-07-2006, 11:27 PM   #79
My Photos: (0)
I believe that there Explorer has something to do with apps that reside in taskbar because Xport resides in taskbar too.
We need to find out a way to load these things with road runnner.
Old 11-07-2006, 11:43 PM   #80
My Photos: (0)
Are you having the same problem with me as well? Some of our apps doesn't load when you're using the frontend as your shell?
I notice not all apps behave the same (doesn't load) eventhough the resides on the taskbar (notification area). My Wifi program loads OK when running RR as shell, eventhough when explorer as shell, it too resides on the taskbar as well.
An alternate solution would be to get some software to load at the background that works as though it's the desktop task bar?
Is there such a program?
Sponsored Links
Old 03-14-2007, 10:05 AM   #81
My Photos: (0)
i didn't read through all 6 pages, but here's a free program that will allow you to add anything to start up quite easily...
http://www.mlin.net/StartupCPL.shtml
PM me if you can't get it working
darroj is offline   Reply With Quote
Old 03-28-2007, 05:54 AM   #82
pasan's Avatar
Vehicle: 1997/Nissan/Sentra
My Photos: (4)
How to boot directly in to Winamp using windows 98?
Pasan...
pasan is offline   Reply With Quote
Old 03-28-2007, 06:15 AM   #83
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Put a shortcut to WinAmp in the Startup program folder.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 03-28-2007, 07:05 AM   #84
pasan's Avatar
My Photos: (4)
Mike Lin's Home Page
Thanks man. Its working. and very easy
Pasan...
Old 03-28-2007, 07:21 AM   #85
pasan's Avatar
My Photos: (4)
Thank u very much for the fast info
Pasan...
Old 03-28-2007, 02:23 PM   #86
EL CAMINO's CarPC Specs
EL CAMINO's Avatar
Vehicle: 1981 chevy el camino
My Photos: (0)
what about autoit, i use simple scrypts to make the changes to the registry from my skin(ROAD RUNNER SKIN)this way if i need my full desktop i can go back to explorer easily.
road runner is capable of launching any program when starts, for example i use this to launch xport. RUN;C:\xport\xport.exe RRconfig tool has this option and writes this info to the rr.ini, but for more info about this,go to the Road Runner corner.
EL CAMINO is offline   Reply With Quote
Old 05-16-2007, 07:31 PM   #87
Vehicle: 2005 Honda Civic
My Photos: (0)
I hit Start and then Run and put in regedit and hit OK. But it said regedit is not a valid Win32 application and that's it.
Ampie Case
2.5" Hard Drive 80GB Toshiba 5400rpm
Kingston 512 MB DDR RAM PC3200
Xenarc 700TSV - VGA Monitor
VIA EPIA M10000 Mini-ITX Mainboard
M1-ATX 90 Watt - Smart Power Supply
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 05-26-2007, 06:11 AM   #88
Vehicle: 2003 BMW 320i, 1992 Nissan Skyline GTS-T Type M
My Photos: (0)
I just thought I would share my current solution:
In regedit navigate to:
HKLM\Software\Microsoft\Windows\CurrentVersion\Run
You should see a familiar list (if you play with your boot settings a lot). It is the list of programs that windows loads during start up.
Go to edit, and create a new string value. Name it whatever you want (front end name most likely) and then for the value, put the path of the program you want to boot in quotation marks.
ex. "C:\RoadRunner\RoadRunner.exe"
When you restart your computer the program will then load on startup. Granted you will see your desktop for around 1/2 second but I found this loaded faster than changing the shell to Road Runner.
It also saves you from any sort of trying to launch explorer when you want to return to desktop. (I was launching explorer and only the My Documents window would appear)
Hope this hasn't already been exposed!
ajdale is offline   Reply With Quote
Old 07-05-2007, 04:44 PM   #89
Vehicle: 91 Ford Probe
My Photos: (0)
I have a problem. I'm running TinyXP_rev05 and changed the shell as described on the first page. I guess it works as it should:
I changed the registry key to start RoadRunner. Now when I reboot RoadRunner runs as shell. When I exit RoadRunner it automatically restarts. So far so fine.
But when I want to shutdown the computer, RoadRunner quits and then windows tries to restart it. But it can't because the shutdown-procedure is initiated. So a Windows message window appears saying "The application failed to initialize because the windows station is shutting down". Why does the system do that ? When I shutdown it obviously shouldn't restart the shell. I also set "AutoRestartShell" to 0, which doesn't make a difference.
1. So, how do I stop windows trying to restart the shell-program when shutting down ?
2. Not that important, but I'd rather like RoadRunner not to restart, when I quit it.
EDIT:
Hm, I guess this question fits better in the RoadRunner forums, so I posted my question also there. If that's against the rules I'll delete this post asap. I just still left it in this thread, because that's a problem which didn't appear in this FAQ before, and I guess this could be helpful for other users.
EDIT2:
Problem solved...more or less. After changing back from minilogon to winlogon this problem doesn't occur anymore. Anyone got a clue why it's not working correctly with Minilogon ?
Konrad is offline   Reply With Quote
Old 07-12-2007, 09:52 AM   #90
My Photos: (10)
Autologon problem
I'm running frodoplayer and I have it set to run as my shell. I edited using tweakui the autologon files to automatically log me on and for some reason after I edit the files I restart and it works fine then I shut down the computer and come back the next morning and theres the stupid login screen again. Whats the deal with that? I've done everything that the guide tells me to do but I think its just not saving it in the registry after a complete shutdown. Any suggestions.
heefer12 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Why do we need car Front End software?! nijel Software & Software Development 45 04-09-2006 12:50 AM
Recomend a front end. bigmac999 Software & Software Development 7 05-03-2005 02:24 AM
Roll your own front end wysocki FrodoPlayer 27 05-01-2005 10:46 PM
BASIC Stamp question Banderon General Hardware Discussion 18 05-07-2004 08:33 AM
cool front end software liquid_smoke Software & Software Development 3 09-02-2003 12:23 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
