Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 06-07-2005, 11:36 PM   #1
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
FAQ: Booting XP from a USB or Compact Flash Card
****Note - this is a FAQ in progress and may contain errors. All CF users, please feel free to correct and add as necessary!****
Are you interested in booting your computer from a solid state device such as a Compact Flash (CF) card? While there are MANY posts on this topic in the
Operating System Optimization forum, here is a link directly to the definitive post on the topic with step by step instructions from our very own Sfiorito:
http://www.mp3car.com/vbulletin/winnt-based/38484-new-ewf-minlogon-cf-instructions.html
A couple of quick FAQ's:
Does using a CF card make XP boot faster?
Your mileage may vary. http://www.mp3car.com/vbulletin/show...=cf+boot+speed
What is the advantage to booting from CF
Mostly, that your system is not tied to a mechanical disk drive. Disk drives can fail from vibration, heat, cold, shock. CF cards use less power as well.
Are there downsides to CF cards?
CF cards only support a limited number of writes (don't worry, it's "lots"), so you want to ensure that your XP install will write as little as possible to the card.
How does it work?
First, read the message link!
CF cards have a finite number of "writes" that can be made to them. This is the reason that XPe (embedded) is used to write the files to the card. First, MinLogon can optionally be used to help reduce boot times. Thenn a product called nLite is used to strip XP down to a bare minimum to fit on the card and EWF (Enhanced Write Filter) is used to reduce writes to the card. A procedure called HORM (Hibernate Once, Resume Many) is also used to reduce writes to the card.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 05-27-2007, 02:55 PM   #2
Wimster is an unknown quantity at this point
Red face Will any CF do?
I'm just about to embark on my first CF Windows system. Before I buy the CF, will this booting XP work with ANY CF or should I buy a specific specification? Right now I have my eye on a Dane-Elec 4Gb one (DA-COMFLASH-4096MB).
Thanks so much in advance!
Wimster is offline   Reply With Quote
Old 05-28-2007, 07:29 PM   #3
thumper_svx
The only real caveat is; how FAST do you want to boot. Oh, and some older cards don't actually support IDE emulation mode (though those would be too small to be considered, anyway).
Myself, I'm going with a 4Gb card as fast as I can get (133X seems to be the max at the moment), and almost to hell with the cost. The faster, the better your boot when using HORM.
Also, it's a good idea to build your machine in a virtual machine to test it perfectly and get everything "in situ" before you move it to CF. This results in minimal changes to the CF filesystem.
thumper_svx is offline   Reply With Quote
Old 11-10-2008, 09:23 PM   #4
chris350's Avatar
chris350 is an unknown quantity at this point
ok this thread told me nothing on what to do.
how about what i need ( compact flash card, IDE interface...etc)
can i just get the CF and install it on the carpc, then load windows? or is there something special that I have to do?
chris350 is offline   Reply With Quote
Old 11-10-2008, 10:04 PM   #5
MAZDABOY is on a distinguished road
This would be baller, so you don't need a hard drive, just get a huge flash card or whatever and take it out when you want.
MAZDABOY is offline   Reply With Quote
Old 11-25-2008, 02:59 PM   #6
MichaelPlace is on a distinguished road
Don't buy CF cards off ebay, ebays area all fake with slow speeds. Buy off a reputable website and use professional digital photographer speed cards, such as the Sandisk extreme range.
MichaelPlace is offline   Reply With Quote
is there a way to take a compact flash GPS to USB? mattress GPS 9 02-02-2005 10:05 PM
CF Card for Windows XP OS boot??? englsh General Hardware Discussion 18 07-26-2004 02:03 AM
Funny Thing... I was ordering a USB sound card when... Phat Justice Off Topic 13 05-02-2004 01:53 PM
booting from flash card faster than HD? ecolner Newbie 26 02-24-2004 02:36 PM
USB Sound Card with ASIO driver and volume control tbdombrosky General Hardware Discussion 0 02-04-2003 12:00 AM
