02-24-2006, 06:44 AM
#16
Vehicle: 2000 Pontiac SunFire
Ok, I just got a Athlon XP-m 2000+ T-bred (35w).
Here are the specs
Athlon XP-M 2000+ 1667 MHz 256 KB 266 MHz 12.5x 1.35 June 17, 2003 AXMD2000FJQ3C
But I can't set any of these in the interactive pin mod thing, 200mhz is as high as FSB goes, it wont go to a 1.35 volts, and the next up paired with 12.5x multiplier gets me 4400+!
Can anybody do this for me and tell me a suggested config?
2000 Sunfire build 100%, or is it ever really 100%?
02-24-2006, 06:52 AM
#17
Neither darque nor pervert
Vehicle: 2003 Toyota Tacoma X-Cab
Sure.
Socket view (so you know where to put the wires in the CPU socket)
AMD T-bred
1.475 Volt
5.25 x Systembus (10.5 x FSB)
133mhz FSB
FYI - I'm running an AthlonXPm 2400+ (35w) at 1.475v and it runs nicely.
My Worklog
02-24-2006, 07:00 AM
#18
Quote: Originally Posted by DarquePervert
Sure.
AMD T-bred
1.475 Volt
133mhz FSB
Sounds good, why is it rated so low? Using that config gives me a 1600+
02-24-2006, 07:39 AM
#19
D'oh!
My bad It should be 6.25 x Systembus (12.5 x FSB)
I was reading the processor rating incorrectly.
I added you to MSN, but have gotten no response as of yet.
My Worklog
05-02-2006, 11:31 PM
#20
is this will work with another kind of motherboard too ? thanks
05-03-2006, 01:02 AM
#21
I see dead kittens
Vehicle: 1998 Audi A4
this mod is not motherboard specific.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
05-03-2006, 07:20 AM
#22
I meant, If I don't have an Ausus A7N8X motherboard, and I have an Athlon XP M, can I do it ?
and btw, My AMD Athlon M is 2200, I don't know why it's only run like 600GHZ. thanks.
05-03-2006, 10:41 AM
#23
I see dead kittens
yes u can do it on a different motherboard.
Installed
05-04-2006, 05:40 AM
#24
I dont know why, probally, the wire I am using is too big or something, after I install the wires and everything. Then I can't put the Processor (CPU) back in the hole, hmmm.
05-05-2006, 10:55 AM
#25
MySQL Error
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
use a smallest wire you can find and yes, it is hard to put the CPU back. Becarefull not use to much force to put it back otherwise you risk to bend/break the pins.
05-06-2006, 12:50 PM
#26
wow, thank you very much, I just did it, and it worked great, thankssss
| Thread Tools |
| Display Modes |
Linear Mode
