The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Thread Tools Display Modes
Old 06-16-2005, 08:07 PM   #1
I see dead kittens
Quattro's Avatar
Vehicle: 1998 Audi A4
My Photos: (0)
FAQ Tutorial: Wire/Pin Mod for Mobile Athlon
(This possibly belongs in the FAQ section, I wasn't sure. Mods feel free to move it needed)
As you all know that the Mobile Athlon Processor runs at its default clock speed of 800 MHz on most motherboard that support the chip. This mod is used to make the motherboard recognize the processor at its correct speed.
How hard is the pin mod?
Is it reversible?
Do you have any pictures of the mod?
I've been asked these questions many times. And to answer them:
Very Simple
Yes
Yes (well now I do)
I was redoing the mod on my board and decided to take some pics (warnig: I'm not the best photographer) and write a small tutorial. Hope this helps the people who are considering the Asus A7N8X motherboard. So here goes.
Oh forgot the disclaimer, This mod is to be done at your own risk. I do not take any responsibly if anything goes wrong. It worked fine for me with out a problem, hopefully you won't have any either.
Tools/Supplies:
  • Thin wire, I used 20 awg speaker.
  • Tweezers
  • Wire cutter (optional) I used my teeth
  • Mobile Athlon compatible motherboard.
Process:
1) Go to this site and get your diagram for the wire mod.
http://www.ocinside.de/go_e.html?/ht...md_pinmod.html
Choose socket view and AMD Barton (Make this setting according to the chip you have, either Barton, T-Bred or Athlon XP). Leave the Vcore selection to the default, unless you want to mess around with it. For this example I choose 200 MHz for the FSB and 9.5 X FSB for the Multiplier selection. The multipler selection is based on the chip you are using. When you select the FSB and the multiplier the rating of the chip is displayed in the last box. This should be the same as the chip your are using. Of course you can over/under clock the chip to your liking.
So if you’re following along you should have this diagram.
2) Take your wire and pull out one strand from it, so you have one really thin piece of wire.
3) Cut a piece off the long wire so that is long enough just to fit in two holes. I cut the wire into 1/4" pieces. Here a picture of the size of the wire I used. Btw, that's a hard drive screw in the picture. (Just for your reference)
4) Take the small wire and curve it into a U shape, using the tweezers at this point helps.
5) Take the wire with the tweezers and position it on top of the holes it belongs in. It’s a little tricky at first, but after a couple of tries, the wire seems to fall in by itself.
Here are the pictures of the final product.
If there are any mistakes or if something is unclear, please let me know.
EDIT:
Those that are worried about doing the mod, I just like to add that I did a Prime95 torture test on my system after the mod. And after 3+ hours not one single problem or warning.
Keywords: wire mod, pin mod, Mobile Athlon, Asus A7N8X,
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Sponsored Links
Old 06-17-2005, 01:59 AM   #2
fuctup's Avatar
Vehicle: F4i
My Photos: (0)
what about throughbred<- probly mis-spelled] core mobile athlons? different pins right?
fuctup is offline   Reply With Quote
Old 06-17-2005, 05:16 AM   #3
alti's Avatar
Vehicle: 2002 Nissan Altima
My Photos: (0)
the site he linked above has t-bred selection
"Interactive Pin-Mod guide v1.2 for AMD Athlon XP, T-Bred and Barton CPUs"
Very cool writeup quattro!
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
alti is offline   Reply With Quote
Old 06-17-2005, 08:06 AM   #4
Frankino's Avatar
Vehicle: Peugeot 206 HDi 2003
My Photos: (0)
what about booting up at 800mhz and then force it to the clock you like by software? I always to it and it rocks, I force it to 600mhz 0.95v on general purpose and switch it to 1ghz 1.1v when I need more power
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
40gig 3.5" HDD
Sb Live 5.1 w/ KXProject Drivers
Opus 150w WTF
8" Lilliput TS LCD
40% installing (monitor ok, pc KO, audio KO)
damn car accident
Frankino is offline   Reply With Quote
Old 06-17-2005, 08:17 AM   #5
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
That is a perfect solution, but this particular mobo Asus A7N8X-VM doesn't work so well with software solution.
I crawling the web for some easier solution, but end up with wire mod is the only solution for this board (time may change).
Nice write up Quattro
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 06-17-2005, 08:49 AM   #6
Rub One Out
Motoko's Avatar
Vehicle: 2002 Seat Ibiza Ranking: Master Orgasmo Wearing: The Hoff Thong Likes: Chocolate Cakes and Unicorns
My Photos: (0)
Yup thanks to Quattro I got my XP-M modded to and it works.
CarPC status: iPod, 3,456,217 songs so **** you
Motoko is offline   Reply With Quote
Old 06-17-2005, 09:45 AM   #7
I see dead kittens
Quattro's Avatar
My Photos: (0)
No problem on the write up. I hope people will see that its a really easy mod and that they don't have to be worried too much.
Installed
Old 06-17-2005, 11:12 AM   #8
tarpitblue's Avatar
Vehicle: 02 Nissan Altima
My Photos: (0)
Quick question. Where did u get the 9.5x from? Is this based to give u the 1900MHz speed to match your chip? I ask because I'm looking to get the XP-M 2200+, so I assume I would go with the 11.0x to get the 2200. Seems logical but I have been wrong before (it was 1986....nevermind). Seriously nice find and write up. Thanks for the efforts.
tarpitblue is offline   Reply With Quote
Old 06-17-2005, 01:09 PM   #9
I see dead kittens
Quattro's Avatar
My Photos: (0)
Yes the Multiplier selection is based on your processors speed. (will edit first post)
So if you have a Mobile 2200+ you would make the multiplier 9 if your using 200 FSB. It all depends on what you want the processor to run at. If you using it for your desktop, then mobile athlons make great overclocker chips. If your using it for your car you can underclock it help cut down on the amount of power used.
Installed
Old 06-17-2005, 01:20 PM   #10
fuctup's Avatar
Vehicle: F4i
My Photos: (0)
http://crystalmark.info/soft/CrystalCPUID4.html software control for your unlocked mobile athlon, just thought i'd ad this to the thread, its helpful to let you know your chips original multiplier
::edit::
incase anyone wonders, go all the way to the bottom its the last link to download, the page may be confusing because its in chinese or whatever
Sponsored Links
Old 06-17-2005, 01:36 PM   #11
Jesus Freak
antimatter's CarPC Specs
antimatter's Avatar
Vehicle: 2006 Mazda Mazdaspeed 6 GT
My Photos: (0)
Cool Good work!!1
antimatter is offline   Reply With Quote
Old 07-14-2005, 04:55 AM   #12
Vehicle: 1992 Buick Skylark
My Photos: (0)
Well, because usually a hardware mod is better and more stable than a software mod.
I've got a 2200+ in this computer (regular desktop) and I unlocked it by jumping some (L5 ? Been a while) pin because my mobo doesn't unlock the multipliers.
I'd put more faith in a hardware mod personally.
1992 Buick Skylark - 3.3L V6
Alpine CDA-9805 Headunit
Alpine SPS-690A Rear 6x9 Speakers
Alpine Alpine SPS-460A Front 4x6 Speakers
Crossfire VR1000d
Crossfire BMF W15D x2
100 Amp Alternator
Montana MECA M2 and DB2 Points Leader
MSIGuy is offline   Reply With Quote
Old 08-19-2005, 08:33 AM   #13
Vehicle: 106 GTi
My Photos: (0)
i did the pin mod, and something blew :'(
dont know what it was...i hope t wasnt the processor...
GeeJay is offline   Reply With Quote
Old 10-29-2005, 03:38 AM   #14
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
And was it?
lez is offline   Reply With Quote
Old 10-29-2005, 08:39 AM   #15
Super Moderator
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
My pin mod worked perfectly using a SHuttle SN41G2 and an AthlonXP-M 2400+ 35w.
There is nowhere I can see to force it down to 1.35v, so I went with the lowest available, which is 1.475v. It runs perfectly.
I also pilled the thin strands of wire from a floppy drive cable I cut up.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Installing XM Radio on Your Carputer, a Tutorial Bugbyte The FAQ Emporium 8 03-14-2008 12:36 AM
OEM GPS mod. Writeup + Pics IntellaWorks Hardware Development 67 07-04-2006 02:59 AM
tutorial, or help file, faq? theheel PowerVoice 6 11-21-2004 01:39 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
