The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Thread Tools Display Modes
Old 06-18-2005, 11:04 AM   #1
ret
ret's CarPC Specs
Vehicle: 1995/Honda/Civic EJ1 Coupe
My Photos: (0)
Wiring Diagram (with Amplifier)
NEW!!!
1st Diagram without Shutdown Controller
2nd Diagram with Shutdown Controller
ret is offline   Reply With Quote
Sponsored Links
Old 06-18-2005, 04:22 PM   #2
d_sellers1's Avatar
Vehicle: 2000 Ford Taurus & 2001 Ford Focus ZX3
My Photos: (0)
Looks good. It should be noted that if you use a powersupply such as the OPUS, you'll have a main cable going to the battery, a wire to the ignition, and the contacter would be replaced with the wire from the OPUS.
It's also important to note the IDE>USB adapter. Even though you are using a USB2.0 hub, when you put 1.1 devices on the hub, it causes all the devices attached to it to run at USB1.1 speeds. This may not be perferable since USB1.1 operates at 12MB/s while USB2.0 operates at 480MB/s. Recommend, in this case, that it gets its own USB cable going to the motherboard.
Also, if popping noises are heard for the speakers during powerup, the use of some sort of delay timer or circuit may be needed. Search the board for options (I've posted in some of them.)
Attached is my propsed wiring that I plan on using. (You'll see that my DVD and touchscreen are on the same hub. This is a mistake during drawing and I just have not taken the time to change it.)
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
Last edited by d_sellers1 : 06-18-2005 at 04:31 PM. Reason: Added speaker pop info and wiring diagram
d_sellers1 is offline   Reply With Quote
Old 06-19-2005, 12:22 PM   #3
My Photos: (0)
Newbie here.
Shouldn't there be a fuse on the battery's 12V line out? If so. how big should it be?
Thanks.
b8bboi is offline   Reply With Quote
Old 06-20-2005, 12:24 AM   #4
emdzey01's Avatar
Vehicle: BMW e39, Acura NSX up next
My Photos: (0)
i hope you get it.
Brushed Metal for Centrafuse 1.4
Brushed Aluminum for Centrafuse 1.4
xenarc 700ts | via epia-m10k | audigy2 nx | holux gm-210 | usb wifi | 40gb 2.5" | slot-load dvd-cdrw | morex 3688 | opus 150w | centrafuse, iguidance
emdzey01 is offline   Reply With Quote
Old 03-01-2006, 10:25 AM   #5
Vehicle: 2007 Nissan 350Z Nismo (Temper\Solar Orange)
My Photos: (0)
Now that's probably one of the best and easiest pictures to understand.... also I have the same pc case at home
SimonD is offline   Reply With Quote
Old 04-05-2006, 12:57 AM   #6
My Photos: (0)
What is in the back, in the center?
squared80 is offline   Reply With Quote
Old 04-09-2006, 01:06 AM   #7
My Photos: (0)
Volume control or maybe a mixer?
ligergtt is offline   Reply With Quote
Old 04-09-2006, 01:09 AM   #8
ramy_zohair's CarPC Specs
ramy_zohair's Avatar
Vehicle: 2002 Mitsubishi Magna
My Photos: (0)
The one at the bottom is the creative usb soundcard feeding audio to the amplifier above it.
Final Touches
Car: 2002 Mitsubishi Magna EI
CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
ramy_zohair is offline   Reply With Quote
Old 04-09-2006, 01:59 AM   #9
My Photos: (0)
I dont get how the PC is powered. Is that a spare battery? And are you running it through an invertor or something?
Old 04-09-2006, 05:06 AM   #10
My Photos: (0)
BMWs have their batteries in the trunk. since he has the IGN line into the PC it looks like he has some DC PS with a startup/shutdown controller.
Final Touches
Sponsored Links
Old 06-06-2007, 05:23 PM   #11
My Photos: (0)
Is there any ways that the amp's "remote" can be connected to the computer or LCD screen instead of the ignition?
Say sometimes I drive with no music and I don't need the amp to be turned on.
tomazws is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
emerson 8100 wiring diagram??? etrik General Hardware Discussion 2 02-11-2007 12:40 PM
Wiring diagram suggestions VR4Spyderman Power Supplies 8 03-18-2005 04:34 AM
'95 windstar amplifier wiring question Vchat20 Car Audio 1 03-04-2005 07:13 PM
Does anyone have a complete wiring diagram? jamminjohn Newbie 4 02-10-2005 05:40 PM
datalux 4x20 red lcd wiring diagram? etrik LCD/Display 0 12-07-2001 03:35 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
