The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Thread Tools Display Modes
Old 06-20-2005, 08:21 PM   #1
Super Duper Moderator
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (14)
FAQ: Cooling Your System
Worried about cooling your PC? This is a hot topic (pun intended) among our members. Some of the higher power consumption processors such as the Pentium 4 run very hot and require lots of cooling. Others have installed their computers in tight spots (i.e. behind the dash or in the glove compartment) or in areas where heat can be trapped such as the spare tire well.
CPU's have *max temps* in the 70-95 degrees centigrade range (~160-200F). In general, the fan and heatsink that comes with your computer often works just fine. In some cases, aftermarket heatsinks or fans/thermal grease can help. In extreme cases, other measures must be taken.
Here's some links to posts by members about ideas for cooling their PC.
1. Peltier cooling (dielectric)
2. Submerging in vegetable oil
3. Water cooling
4. Cooling the CPU using the car's A/C system
WizardPC's ghetto cooling test
*Note that using your A/C system to cool your CPU faces two issues. First, the A/C in the summer is your heat in the winter. You'll need a way to keep the heat from blowing inside the computer if you tap in to your A/C. Second, after turning of your car, the CPU will be cooler than the outside air, inviting condensation to form on the system.
If you have other cooling tips or links, add them to this thread!
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Sponsored Links
Old 07-06-2005, 12:27 PM   #2
Cheekz185's CarPC Specs
Vehicle: 2002 Mitsubishi Galant
My Photos: (0)
Just got some feedback from VIA, Im a little afraid of what the heat can do to my mobo in my trunk:
Quote: Originally Posted by VIA
All of our boards have been verified to run at temperature from 0 to 50 degree Celsius (32 to 122 F). Since you are using fan with your system, that should be sufficient to get your system to run in New York.
Temperature was measured in the case, and is referred to the ambient temperature. The actual CPU temperature might be higher than the ambient temperature.
Actually, Motherboard Monitor does not correctly measure our EPIA’s temperature. So, we do not really recommend it for reference temperature reading.
So with MBM5 it tells me my cpu goes really high when i play mp3's dvd etc. My CPU readings can go up to like 145 degrees farenheit. But according to VIA they said it all boils down to the temperature inside of the case i guess.
The strange thing is, my CPU temp can jump up/down at least 15degrees in like seconds. It is weird. I highly doubt it can get cooled or heated that quick...
Any feedback would be appreciated!
Cheekz185 is offline   Reply With Quote
Old 07-06-2005, 03:05 PM   #3
Raw Wave
Laidback's Avatar
Vehicle: Jeep GC
My Photos: (0)
Erm, they also say that MBM5 *DOESN'T* measure the EPIA temps correctly...
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 10-03-2005, 04:09 PM   #4
Vehicle: Vauxhall Astra Mk4 1.6i
My Photos: (0)
check this overheating. when removing fan/heatsink test
http://www.pantherproducts.co.uk/web...PU_Cooling.zip
World705 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
New EWF + MinLogon and CF instructions SFiorito WinNT Based 244 05-06-2008 12:18 PM
System Cooling Juliemac General Hardware Discussion 7 05-12-2005 09:05 PM
FS: Carputer system w/o monitor Toups Classified Archive 7 04-21-2004 12:43 PM
FS: Carputer system w/o monitor (Boots in 15 sec) Toups Classified Archive 0 04-01-2004 11:01 AM
linux system owners with web site please post Jake General MP3Car Discussion 13 10-23-2002 08:39 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
