Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Closed Thread
Old 07-11-2005, 07:11 PM   #16
seanz0rz's Avatar
seanz0rz is on a distinguished road
for clarification, the yellow line is trigger only, it does not draw any signifficant power. you can run whatever size line you want, as long at its not smaller than what the opus comes with.
seanz0rz is offline
Old 07-23-2005, 11:39 AM   #17
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Thread cleaned to eliminate irrelevant posts.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline
Old 08-14-2005, 12:26 AM   #18
Raw Wave
justintime's Avatar
justintime is on a distinguished road
Someone should add to this FAQ, how to connect the 10g (suggested) red wire from wiring, to the Opus 14g red wire. Some say use a block distributor, others say solder, etc...
After posting the correct answer, someone please delete my post (this one!).
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline
Old 08-19-2005, 06:04 AM   #19
Viscouse's Avatar
Viscouse is on a distinguished road
Just to clarify this, the Ignition wire is a trigger / sense wire only. Meaning, it doesn't have to be any fancy wire. Any circuit inthe car with ignition switching can be used.
Read more in this thread.
You know you want to...Worklog
Enjoying v1.0 since it's operational. Aaaawww yeah.
Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
Viscouse is offline
Old 09-04-2005, 04:56 PM   #20
Moneyfink's Avatar
Moneyfink is on a distinguished road
what if i want my amp to turn off at the same time as the 0pus. How would you recommend that i connect the IGN line of my APM to the OUTPUT of the 0pus. Where can I tap in so that I won't have a major malfucntion with my 0pus. Can i connect my amp's ign to one of the 12 V leads going to my fan. That way if there is a voltage drop it is only in a minor component like a fan?
Now, if i do this my amp will stay on until my 0pus shuts off, that way i get 5 more seconds of music?
Tell me if im wrong
btw its an 0pus 150
My OLD carputer page
My NEW carPC
Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
Moneyfink is offline
Old 09-04-2005, 07:41 PM   #21
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
Tell me if im wrong
btw its an 0pus 150
Yes, you can connect it to the 12V of the fan or any other 12V lead. It won't hurt the opus. The amp just need the signal to turn on and off.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline
Old 09-10-2005, 12:41 PM   #22
Synth3t1c is on a distinguished road
on that last one, how is there no circuit being completed from the battery??
Synth3t1c is offline
Old 09-10-2005, 10:13 PM   #23
I see dead kittens
Quattro's Avatar
On the second picture, there is a distro block which is being used. All the grounds are being connected to that and then the main ground from the block is connected to the cars chassis. In the first pic the opus is connected back to the battery for the ground, the battery itself it actually connected to the cars chassis for the ground.
Installed
Quattro is offline
Old 09-11-2005, 12:46 PM   #24
Silentbob343 is on a distinguished road
The first pic also has a big "OR" showing that it can go to the battery "OR" ground to the car chassis.
Silentbob343 is offline
Old 09-11-2005, 12:49 PM   #25
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
yes
Quote:
There are two possibilities to connecting the wire to a ground area. You can either run another wire from the batteries negative terminal to the Opus or you can run a negative wire from the Opus and connect it to one of the car’s bolt close to the power supply.
tj!2k4 is offline
Old 09-11-2005, 04:53 PM   #26
I see dead kittens
Quattro's Avatar
yeah, the second picture doesn't have the "OR" because it is simpler to connect to the car chassis. You want the ground to be small as possible.
Installed
Quattro is offline
Old 09-28-2005, 06:26 PM   #27
Raw Wave
tj!2k4's Avatar
Opus 150 Connectors
Some images of the Opus 150 power connectors w/ part numbers, in case anyone else needs to order these for whatever reason. I got these from Mouser, but the Mfg P/N should be the same wherever you purchase them.
(I'll be replacing my Opus 150 w/ zootjeff's new 220w psu, and it would be a real pain to remove the Opus' wiring in my dash.. so I'll just use one of these connectors with the new psu.. problem solved. )
Thanks to zootjeff for locating the P/Ns for me.
tj!2k4 is offline
Old 12-25-2005, 02:05 PM   #28
rdiggidy is on a distinguished road
I had a question about wiring gauges for the diagram in this post and it was answered here, so I thought I'd post it for others:
Quote: Originally Posted by Quattro
If you going to be using a distro block like you said then I would suggest you use 4 gauge wire from the battery to the distro block. And from the distro block use 10 gauge wire to connect to the opus and probably 8 gauge wire for the amp (this will depend on the amp, look at your manual it will tell you what wire size to use).
rdiggidy is offline
Old 01-05-2006, 09:23 PM   #29
guruj is on a distinguished road
Hope i got this in the right place and no one chew the crap out of me.I read in one of the posts that as a rule of thumb if you need more than 200w of power you should use an inverter, Whay cant you just buy 2 or more dc-dc power supplies and run them in parallel to almost double the wattage output?
At work when we need a more powerfull power supply we usually just add another power supply of the same model and brand in parallel to double the output current.
Thanx
Guruj
guruj is offline
Old 01-06-2006, 12:04 AM   #30
Bugbyte's Avatar
You probably read that in my power supply FAQ. You can run them in parallel. Of course, that means that you have to buy two of them.
And I presume you're thinking you run the mobo on one PSU and the other stuff on the second PSU. That will work unless you can't split the power up between the two.
Also, there are some new PSU's out there like the DSATX that help with those higher power boards.
Want to:
-Where is the iBug?
Bugbyte is offline
Closed Thread
opus PSU too weak for me? gummybear Power Supplies 10 03-04-2005 01:46 PM
what would stop me from using opus 150W PLUS another PSU if that wasn't enough? Amax Power Supplies 5 02-28-2005 03:42 PM
86% Efficient AC-DC ATX supply auto_robotics Power Supplies 42 11-25-2004 03:16 AM
FS: 90W Opus DC-DC PSU and extras EBoundEE Classified Archive 6 06-28-2004 01:54 PM
Opus PSU for Casetronic C134 aethernaut Power Supplies 14 02-25-2004 01:19 AM
