Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Closed Thread
Old 03-30-2006, 10:29 AM   #46
therob's Avatar
therob is on a distinguished road
What would be the dangers/problems with connecting the Opus power line to like a block distributer with 30A fuses instead of the 15-20 that is suggested?
The Ninja CarPC
Epia M10000
1GB Ram
160GB Desktop HDD
Slim Cd-rw/DVD Drive
7" Lilliput TS
Opus 150W
PCI Wifi (being replaced by USB)
Xbox 360
2 Headrest Audiobahn 5.6" lcd
2005 MKIV Jetta a.k.a. The Ninja
therob is offline
Old 03-30-2006, 08:29 PM   #47
tundra2000's Avatar
tundra2000 is on a distinguished road
is the ground distribution block really necessary? can i just find two different places on my chassis to ground it or will that cause problems? (can anyone suggest a place to get ahold of a ground distrib. block?)
also, can those IGN lines be put together like in the picture and then connected to the ignition?
tundra2000 is offline
Old 03-30-2006, 10:27 PM   #48
Eubey is on a distinguished road
everything i have read on troubleshooting bad sound or anything has always said ground at the same place...
Eubey is offline
Old 03-31-2006, 12:08 AM   #49
tundra2000's Avatar
thanks - im looking around, can i just use another power distro block just backwards?
example: just buy two of these or does the power one have to be fused, and the ground one not fused...?
Old 03-31-2006, 02:31 AM   #50
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
I don't see why that wouldn't work.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline
Old 04-01-2006, 01:05 AM   #51
BriansNSane is on a distinguished road
what connectors come with the opus power supply's? I'm wanting to get rid of this inverter maybe and go with a dc-dc solution.I'm using an AMD Board wich is an ATX of course!Will I have to buy the corresponding connector to go with it as well? What about hooking up hard drives and such,any 4 pin connectors in there? I guess I'm asking what all kind of wiring it comes with the opus?Its pretty pricey so I would hope it comes with wiring.
BriansNSane is offline
Old 04-15-2006, 07:57 AM   #52
ibitza is on a distinguished road
There are 3st. 4pins connections for your harddrive etc.
You can also read the manual...
(http://www.mp3car.com/products/SFX_D...uide-Rev_C.pdf)
ibitza is offline
Old 04-15-2006, 07:24 PM   #53
01black_ac's Avatar
01black_ac is on a distinguished road
If a fuse is being used inline right next to the battery, is it necessary for the power distro block to be fused, since the Opus has a fuse of its own as well, or can the power distro block be un-fused? I don't see the benefit of having 3 fuses on the line. I realize it adds another fault-point, but is it really necessary? Also, does having that additional fuse on the line add to resistance in any way?
'01
Hang on while I defragment my car...
the Acura ITX project
the Acura ITX skin for RoadRunner
project progress: 99%
01black_ac is offline
Old 04-16-2006, 01:10 AM   #54
Bugbyte's Avatar
Probably not. I won't hurt but you probably don't need it.
Every time you have some kind of connection and that current passes through a different type of material or gauge of wire, you will have some resistance added but it's negligable in this case. The main thing you want to watch out for is the length of the wire and the gauge. There's a voltage drop for a set distance over the wire due to the resistance and you don't want it to be too much. Use an appropriate gauge (I see a lot of people using 4 or 0 gauge, I used 8 but have a low power install) for the majority of the run and then connect it to the Opus' harness.
Want to:
-Where is the iBug?
Bugbyte is offline
Old 04-16-2006, 02:38 AM   #55
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
'01
Quote: Originally Posted by Evilbunny1114
if i am correct the opus 150 has a fuse in it already why would you need another 1 for the first setup option?
Quote: Originally Posted by Quattro
The fuse in the first option is to protect the wire not the Opus. The wire is what will cause a fire in your car.
your question has been answered a couple of times already.
If your using a distro block then u definetly need it to be fused. If you just connecting the opus directly to the battery then you don't need to re-fuse the line again, but in that case u wouldn't need a distro block either. Since u mentioned using a distro block then I'm assuming that you connectin more then just the opus, if so then just follow the diagram.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline
Old 04-16-2006, 03:16 PM   #56
01black_ac's Avatar
What I'll be doing is running 10AWG from the battery, with a 10A fuse right next to the battery. The 10AWG will run from the battery to the trunk, where it will hit the distro block. From the distro block, the 10AWG will connect to the 2x16AWG of the Opus120. And the Opus120 has its own 15A fuse.
So you'd recommend a fused distro block for this?
Also, should I go with 8AWG wire instead of 10AWG?
'01
Old 04-17-2006, 01:40 AM   #57
I see dead kittens
Quattro's Avatar
Yes I recommend u use a fused distro block. The problem occurs when going to 16awg from a higer 10awg wire. If a short in the wire occured in the UNFUSED 16 guage wire it may catch fire or cause other damage long before the higher rated main fuse in the 10 guage wire blows. Anytime there is a stepdown in guage size the smaller wire should be fused at or near the stepdown.
depends, if your only connecting the opus then you'll be fine with the 10awg wire.
Installed
Quattro is offline
Old 04-17-2006, 07:33 PM   #58
elemeno0pee is on a distinguished road
I just got a 30A inline fuse for this setup, and then read that I should not use higher than a 20A... I read this whole thread but can't find the answer, and I just don't know what to search for to find out.
Someone else asked, but it wasn't answered, so I will ask again:
Why can't a 30A inline fuse be used? I don't know anything about electrical junk, but if I had to guess... I'd guess that it's because the fuse will not blow when it might need to?
elemeno0pee is offline
Old 04-17-2006, 07:53 PM   #59
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Correct.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
DarquePervert is offline
Old 04-19-2006, 03:52 PM   #60
Pepe's Avatar
Pepe
It's all about matching the correct fuse to the correct gauge of wire. You want to make sure you have a fuse that will blow at or before the wire reaches it's maximum recommended Ampere rating.
Here's a chart that show the wire gauge selection for 6V and 12V circuits over different lengths of wire. It also has wattage ratings, so you could just match the wattage of your PSU to the length of wire you need to run.
http://www.rbeelectronics.com/wtable.htm
(Third chart down)
These values are just recommendations, as you'll find lots of charts like that all over the net with different recommendations, but I've found this one to be the best IMO. But I always choose wire at least one gauge larger than what it shows, then select a fuse that's more than the current value your going to be drawing and at or below the rating of the wire.
So for example, if your computer is going to be pulling an average of 20A
@12V over a length of 20' of wire, the recommended gauge is 12. I would then use 10 gauge (slide down to the next lower gauge on that chart under your length), and add a 30A fuse.
Sure there will be people that say "I've ran this and this off that gauge wire for years with no problem...", but a little extra resistance in the wire can make a big difference, resulting in the possibility of your wiring catching fire.
99 Ford Ranger - Bagged and laying frame
Current Carputer project:
Done:
Custom mounted 7" LCD w/ TSK in radio bezel
Custom center console for relocated headunit
Via Epia M10000
GPS
MP3
OPUS PSU
DVD
Pepe is offline
Closed Thread
opus PSU too weak for me? gummybear Power Supplies 10 03-04-2005 01:46 PM
what would stop me from using opus 150W PLUS another PSU if that wasn't enough? Amax Power Supplies 5 02-28-2005 03:42 PM
86% Efficient AC-DC ATX supply auto_robotics Power Supplies 42 11-25-2004 03:16 AM
FS: 90W Opus DC-DC PSU and extras EBoundEE Classified Archive 6 06-28-2004 01:54 PM
Opus PSU for Casetronic C134 aethernaut Power Supplies 14 02-25-2004 01:19 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
