Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 07-07-2005, 01:21 AM   #1
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
FAQ: Do-It-Yourself Startup/Shutdown Controllers
A startup/shutdown controller (SDC) is a device that automatically starts your computer (usually when the car is started or the key is turned to the ignition or accessory position) or shuts it down when the car is turned off. This prevents you from having to switch the system on using a manual switch or relay and also from having to select "shutdown" from your Start or Apple menu.
There are several purpose built commercial startup/shutdown controllers (SDC's) available. The mp3car.com store carries 3 types (here) and there are others available as well. In addition, most commercial power supplies and regulators include startup and shutdown features in their packages.
The reason you need a shutdown controller is that your PC may hang on shutdown, even after receiving the command to shut down (or hibernate). If this occurs, the PC will continue to run and may drain your battery. Most SDC's will shut power off after a certain amount of time (say, 45 seconds) to prevent this from occuring.
Commercial SDC's have a variety of features that often allow the user to specify how the sequence and timing of the startup/shutdown commands occur and they range in price from around $40-$70 USD.
There are other alternatives, however. Several members have come up with solutions to build your own SDC. Here are links to some of those threads:
1. Home made SDC
2. Ghetto SDC
3. Schematic based on UPS monitoring.
4. Controlling your PC from a key fob
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 07-14-2005, 02:05 PM   #2
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
zootjeff and the old timer mp3car community DIY SDC currently hosted by Moahdib
http://home.comcast.net/~acuratl2004/old/shutdown.htm
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 08-09-2005, 10:49 PM   #3
Bodgy's Avatar
Bodgy is on a distinguished road
http://www.mp3car.com/vbulletin/show...light=software
Shutdown control software, the prog by weekendowel is now pay-ware, but towards the end pages of the thread there is an lpt port based one I'm now using.
Bodgy is offline   Reply With Quote
Old 10-10-2005, 04:15 PM   #4
PhillySingle is on a distinguished road
Ok, here's a newb question....
...I understand how the startup/shutdown controller works. However, when it goes to shutdown the PC is it basically doing a "hard" shutdown? Same as holding down the power button on the PC vs Start / Shutdown?
Thanks,
Jay
PhillySingle is offline   Reply With Quote
Old 10-10-2005, 06:54 PM   #5
BoraXP's Avatar
BoraXP
A shutdown controller basicly sends a pusle to the power button headers.
As if you just pushed and released the power button.
With recent motherboards and windows together
the user gets to decide what he wants the power button to do.
Standy, shutdown or hibernate
BoraXP is offline   Reply With Quote
Old 10-12-2005, 02:00 PM   #6
vxcarpc's Avatar
vxcarpc is on a distinguished road
or you could pay 35 bucks for a wireless model already made.
CAR INFO HERE
"He who dies with the most toys, wins".
vxcarpc is offline   Reply With Quote
Old 10-28-2005, 09:08 AM   #7
Nicorolla's Avatar
Nicorolla is on a distinguished road
or you can do a search on this forum and you will find ALOT of homemade low cost shutdown controllers
this is one of my diagrams, for people using inverters and ordinary ps
http://www.mp3car.com/vbulletin/show...3&postcount=21
Nicorolla is offline   Reply With Quote
Old 01-05-2006, 01:49 PM   #8
jon_k is on a distinguished road
This would be my first post here. I'm a A+ Certified and an active MCDST. Though I've seen enough idiots who hold these certifications; so it doesn't mean much.
I think I can give helpful input to this discussion.
I don't see why you guys are doing crazy stuff like the huge schematic MATRIXPC posted; when all we want is for the computer to shut off when the car does.
We should just have the serial port monitor ACC voltage and in the absense of such voltage execute shutdown through the operating system. Why mess with relays, components and the power pin headers on the motherboard at all when this can be 100% software driven ensuring a safe and graceful shutdown all the time?
And why pay, when I'm giving you the SOURCE CODE to a probably working program at the bottom of this post?! Compile the program for your computer yourself!
Here's a simple C program that would do the trick in Linux. In Windows, you might have to use some weird API, and surely windows.h, primarly why I hate Windows. It's a pain in the *** to program in.
This program must be run in root. I haven't had a chance to compile and test this program yet on a serial port to see if it works, but it'll have to run under root (since it uses the shutdown command.)
To get the serial port going, just plug in a +3vDC - +12vDC ACC wire in to pin 8 of your serial port. This program will do the rest. (You may have to ground the ports ground to your car chassis, and this is for sure if you're using an inverter)
To compile and run this program just save this code in a file called controller.c -- and type gcc -o controller controller.c -- To start this program simply type ./controller and you're set!
You might want to change this program so after it detects the absense of ACC it will start a countdown (5 minutes?) and at the end of such a countdown have it check again for ACC. If ACC is STILL not present, THEN do the shutdown command. This would be useful if you stop at 7-11, shut the car off, go inside, and them come back out -- since 5 minutes of the PC running off the battery wouldn't drain it (and so when you came back with your Slurpee, you wouldn't have to start the machine back up)
I came up with this idea pretty much myself; and my philosophy is KISS.
Code:
/*Copyright (C) 2006 Jonathan Kelley This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version. You should be able to grab a copy of the license at http://www.gnu.org/copyleft/gpl.html if not, write to the Free Software Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA. TO DUMB THIS LICENSE DOWN FOR THOSE WHO NEVER HEARD OF THE GNU/GPL LICENSE BEFORE; IT CONTAINS THESE 4 MAIN POINTS. 1) Not establish proprietary rights in the software (Once you write it, everyone gets to enjoy it; altough the software derrived from this code can be sold commercially); 2) Provide the source code (or access to the source code) along with the object code. (Basically, requires you to reveal or "open source" exactly how you make the software do what it does upon user request); 3) That any programs based off, or using this code must also be licensed by the GPL in full and include in the software notice that the code is subject to the GPL (So that everyone downstream can be warned); and 4) Accept the GPL code without warranties of any kind (You got it for free, so you cannot complain if it does not work). */ #include <sys/types.h> #include <sys/ioctl.h> #include <fcntl.h> #include <errno.h> #include <stdlib.h> #include <unistd.h> #include <stdio.h> #include <signal.h> #include <termios.h> /* Main program. */ int main(int argc, char **argv) { int fd; int status; int set_bits = 6; /* Open monitor device. */ if ((fd = open(argv[1], O_RDWR | O_NDELAY)) < 0) { fprintf(stderr, "ar-2: %s: %s\n", argv[1], strerror[errno]); exit(1); } int x = 0; for ( x = 0; x < 100000; x++ ) { ioctl(fd, TIOCMSET, &set_bits); ioctl(fd, TIOCMGET, &status); if (status & TIOCM_CTS) puts("ACC Voltage is present. Do nothing"); else puts("ACC Voltage has been lost! Start shutdown process."); system("shutdown -h now"); } close(fd); }
jon_k is offline   Reply With Quote
Old 01-05-2006, 03:08 PM   #9
Nicorolla's Avatar
don't take this the wrong way but there are already programs similar to yours and what you're suggesting is more (or just as) complicated as the other shutdown controler methods. Why not just use UPS software already part of XP? also you're missing a key element, power up. Either way, if you want a carPC you're going to have to get some wiring done with relays, fuses and grounds. I don't mean to shoot down your idea, i just think you still need to learn a bit more about car electronics and carPCs. It's a good thing that you're giving your share of knowlege.
BTW, i agree MatrixPC's idea is very complex but it's an brilliant schematic and could be very useful to someone that understands it. For the rest of us (not electrical engineers) there's plenty of solutions for shutdown controlers varying from cheap and complicated to simple and expensive.
Old 01-24-2006, 10:26 AM   #10
fgcox1 is on a distinguished road
Question Shutdown/Powerup controller
I'm way over my head here but how hard would it be to design a small circuit that when it senses power off, a small memory chip would send the Tsshutdn command via serial port (or USB?????) and if the Bios had the option, wake on ring?
Seems like a breadboard would be cheap enoug.
I know this might be simplistic and possibly covered before but I searched
on "Tsshutdn" and got no hits.
fgcox1 is offline   Reply With Quote
Old 05-19-2006, 09:54 PM   #11
Grimoire's Avatar
Grimoire is on a distinguished road
Ive looked on this site and couldnt find it, so If I'm posting an already done question, please lemme know and Ill delete....
Anyway,
Can you use this for a laptop? I would have to remove the battery and solder on the contacts for this from my opus? And speakin of opus, my laptop battery is 11.1V 4320mAh, which opus should I get? I dont know about this kind of electronics. I've also got a screen to consider and more than likely a few other add ons...Im thinking an 80 watt opus. But I dont know...
Pardon the n00bness...
Grimoire is offline   Reply With Quote
Old 05-19-2006, 10:16 PM   #12
WarDriver's Avatar
WarDriver is on a distinguished road
Quote: Originally Posted by Grimoire
Anyway,
If you are using a laptop...then you are making it too hard on yourself. Go with a remote switch. There are several examples on this site. Here was the simple, quick and cheap one I did....link.
W3bMa5t3r has a great auto laptop power on.
-WarDriver-
Server Administrator
Outdoor Nut
My DC to AC Inverter Mod
My Laptop Remote Switch
WarDriver is offline   Reply With Quote
Old 05-19-2006, 10:24 PM   #13
Grimoire's Avatar
Wow, Alright, I may be able to pull that one off. Didnt see that thread, Ill read it. Thanks.
Old 06-10-2006, 05:29 PM   #14
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
Hey mate, I never saw this before. Thanks for the props
The latest modules I'm shipping out are sweet if I do say so myself. lol I actually built myself one of the newer ones. Though, I'm already looking at ways to improve it.
speaking of which, I have 2 I need to go build and send out as soon as I get off work. Thanks again Peace...
W3bMa5t3r is offline   Reply With Quote
Old 06-10-2006, 05:55 PM   #15
WarDriver's Avatar
No problem.
-WarDriver-
Outdoor Nut
FAQ: Power Supplies Explained (Part 1) Bugbyte The FAQ Emporium 14 06-10-2007 08:45 AM
Attention Newbies! A FAQ to the FAQs Bugbyte The FAQ Emporium 4 06-16-2006 12:17 AM
FAQ: Attention Newbies! The quickest way to learn about Car PC's Bugbyte The FAQ Emporium 2 06-19-2005 04:18 AM
Still confused on DC/DC, Shutdown controllers, and STR... couple Qs please. pooshda Power Supplies 18 02-25-2003 03:29 PM
Mother of All FAQs. MIT Carputer FAQ. chorattil General Hardware Discussion 1 02-15-2003 02:34 PM
