The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Thread Tools Display Modes
Old 07-12-2005, 10:14 PM   #16
kamikaze2112's CarPC Specs
kamikaze2112's Avatar
Vehicle: 99 Pontiac Sunfire
My Photos: (0)
Quote: Originally Posted by MatrixPC
Another possibility:
Some cars there is an option to buy one of the device sell at some audio places that convert those button to IR signal. The purpose of those device is when upgrading to after market HU, you are able to use those buttons to control the "new" HU like the factory one.
Now, with the IR signal available, you can wire up a simple IR sensor with Girder and you are good to go. There is also a hack to use Lilliput IR sensor to control PC (you just have to search for this thread)
What good about this compare to the one BugByte talking about? Well with this one, you can use other remote control you have laying around to control the PC at the same time as the sterring wheel buttons.
I've looked into that, but as far as i'm concerned, it's a little to much, especially if you can take that 1 wire from the resistor network and figure out how to wire that into the game or serial port. Then there's no need for extra hardware...
1999 Pontiac Sunfire
New CarPC on it's way! Check out my worklog for details ;)
kamikaze2112 is offline   Reply With Quote
Sponsored Links
Old 07-12-2005, 10:18 PM   #17
Super Duper Moderator
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (14)
Quote: Originally Posted by Peoples
link to one of these devices?
See option 2 in the first post. There's a link to one at Crutchfield.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 07-13-2005, 09:17 AM   #18
Pathos's Avatar
Vehicle: '93 Beretta
My Photos: (0)
Ipac and Mame are my friends..... the Ipac is ideal since it doesnt require drivers and software setup
Pathos is offline   Reply With Quote
Old 07-29-2005, 10:42 AM   #19
Snootch's Avatar
Vehicle: 2000 Pontiac Trans Am
My Photos: (0)
Can the IPAC be used to send three-key commands? I looked at the ultimarc website, but couldn't find an answer. I am wondering whether it could control volume, ff, rw, stop, mute, play, skip using Centrafuse which requires three-button presses (Ctrl+Alt+R, etc.)
WORKLOG
VIA SP-13000/512Mb GEIL PC2700/100Gb 2.5"HD/8" Lilliput TS/BU-353 GPS/Powermate/M2-ATX PS
Webpage
Snootch is offline   Reply With Quote
Old 10-14-2005, 12:09 AM   #20
Raw Wave
RoyN's Avatar
Vehicle: 1999 Range Rover 4.6HSE
My Photos: (0)
Snootch cant u customize the sequences in Centrafuse????? I would think you could...
Has anyone hacked a SWI-X or similar to convert the button presses into triggers for an ipac? I bought their minipac (works with spinners, trackballs and buttons) but I'm afraid I need a Swi-x for my car, and I dont want to add an IR if I can avoid it....one more point of falure, and I prefer things connected so I can see if they are "on"
Roy
2005 Range Rover 4.4
RoyN is offline   Reply With Quote
Sponsored Links
Old 10-17-2005, 07:48 PM   #21
lez
lez's CarPC Specs
lez's Avatar
Vehicle: XM 2.1 TD
My Photos: (0)
Am I missing something here, why _buy_ ipac when you can take an hammer to an old keyboard...........
remove the little circuit board, and solder wires to the chips keyscan pins etc.
May be a little trial and error and a few hours work, but I bet it would take a few hours to set something else up.
lez is offline   Reply With Quote
Old 10-17-2005, 08:13 PM   #22
ncamara's Avatar
Vehicle: 2003 Dodge Ram
My Photos: (0)
Or you could do de same with a USB joystick. It would probably save a little bit more space instead of using a keyboard. There are many programs out there that will let you use a joystick to perform different functions.
Installation Complete, pics soon
EPIA M10000 in Morex 3688 case
FrodoPlayer
CoPilot Live 8
Back from long hiatus, will be rebuilding soon
ncamara is offline   Reply With Quote
Old 10-17-2005, 11:16 PM   #23
Jarrod's CarPC Specs
Jarrod's Avatar
Vehicle: 2001 Holden VX S Commodore
My Photos: (0)
The circuit board in a keyboard is probably smaller than the one in a gamepad. They are quite small
I intend to use the keyboard method to make use of the steering wheel controls in my Holden VX. Just need to find out how to take the covers off the steering wheel case without wrecking it! (time to search some holden forums...or perhaps go look to see if its just a few screws!)
Jarrod - Holden VX S!
Jarrod is offline   Reply With Quote
Old 10-20-2005, 02:45 AM   #24
JasonWW's CarPC Specs
Vehicle: 99 Trans Am
My Photos: (0)
I've got a Trans Am with the radio buttons and it uses a single wire "voltage divider" type of connection. I'm also using a PAC SW1 (?) controller to let me control my aftermarket headunit. Now the way they work is you aim your wireless remote into the controller and press the button on the wheel and then press the button on the remote and the controller blinks to let you know that button is now programmed.
The key is that you have to already have a wireless remote that can control your radio or computer. Without a remote, you can't teach the controller.
I haven't looked into Girder or had experience with a computer IR port, but it seems you would need a wireless remote to get the wheel buttons working. Are there any wireless computer remotes out there?
Anyone know about this?
JasonWW is offline   Reply With Quote
Old 10-26-2005, 06:06 AM   #25
Lando's Avatar
My Photos: (0)
My question is which Front ends (Media Engine, Frodo PLayer, Centrafuge ...) accept key command that would make the Ipac useful? If there are any , where can I find a list of the key commands?
Aut cum scuto, aut in scuto
Lando is offline   Reply With Quote
Old 10-28-2005, 07:27 AM   #26
Lando's Avatar
My Photos: (0)
Anyone, anyone
Old 01-07-2006, 02:47 AM   #27
My Photos: (0)
have you already use yung steering control with your mac mini?
Quote: Originally Posted by TxMazda3
bugbyte, have you tried to use this with your mac mini install? if so how'd it turn out?
chakd is offline   Reply With Quote
Old 01-07-2006, 10:28 AM   #28
Bugbyte's Avatar
My Photos: (14)
No. I have an additional problem - I don't have steering wheel controls! So I tend to use a Griffin Powermate to operate my Mini.
Old 02-20-2006, 09:11 PM   #29
My Photos: (0)
Well time has pased and I just wanted to update all you guys about getting your steering wheel buttons working. My car is a 99 Pontiac Trans Am and it used the single wire variable resistance design. The basics of operation should be same on any car that uses the single wire variable resistance buttons in the steering wheel.
So far I only use my carPC to play MP3's - GPS and XM will come later. So I mainly use the MP3 screen in Roadrunner. RR is what I use, but I'm sure other frontends will have Girder files available.
First the hardware. I recommend this little serial IR reciever:
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
It cost me about $15 total shipped from Germany. Took about 2 weeks to get, but that's no big deal.
Second is the PAC SWI-X steering wheel remote control. (edit, I found found out that my own device is the older SWI-2. I'm looking into the newer SWI-X to make sure it will work as well)
They run about $40-$60 and be found several places.
That's about all you need, besides any IR remote you happen to have. Credit card size is a good choice.
The SWI-2 (SWI-X should be similar) is a simple 3 wire hookup on our cars. You can program all 8 steering wheel buttons to do anything the remote can do. And the remote can do just about anything as you are going to use Girder 3.3 to control the PC.
If your already using Girder (not 4.0) to control your PC by remote, your already ahead of the game. Programming the SWI-X consists of pushing the learn button on the unit, pushing the remote button (aimed at the internal IR reciever in the SWI-2) and then hitting the steering wheel button you want it to match up to. Once all 8 are stored, they stay stored even with no battery power.
Once you have the steering wheel buttons ready to go you need to download Girder 3.3. It can be found on the web for free if you know where to look. You plug in the serial IR reciever I mentioned above into a serial port (you have one, right?). You add a certain plugin called IGORPLUG.DLL - SFH-56 to the girder plugin folder. Then go into the Girder settings and load that plugin and set the COM port. Then you load the RR command list which has all the button commands that RR uses. You choose one like (vol+) you hit the learn button and hit the volume up button on either of your remotes and the code will be saved. You can program whatever button you want. It's pretty quick, but there are lots of options such as adding a delay to certain buttons so that it doesn't get pressed twice by mistake, etc... I'm not on the advanced stuff yet, I'm just getting the hang of it. Girder is a big and complex program, but once you get the basics understood you can come back later and fine tune it.
Whatever IR reciever your using, serial or USB, you will need to get the Girder plugin in order for Girder to communicate with the device.
There is a pic below of how I have my buttons currently programmed. I like having the volume and mute/play/pause button on the left so that's one of my quirks. The 4 right side buttons are all about finding the songs. I can move one song or one page at a time up or down. Once I found what I'm looking for I hit the play button on the other side and the new song will start. It's pretty sweet. Since the remote will have more than 8 buttons you can program them to do all kinds of stuff, but the steering wheel buttons should be programed for the most commonly used controls.
If anyone needs details, let me know and I'll help you figure it out.
Jason
Old 02-21-2006, 09:46 PM   #30
Vehicle: 2000 Pontiac Sunfire GT Convertible
My Photos: (0)
what about all those who don't want an IR receiver going on... I should think that a phidget or a vellemen interface through analog would let you program it to respond to voltage input differences. If this has been said allready then I apologize as I admit I skimmed and didn't see the idea...
Anybody tried this?
dmcdlrn is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Using PC to control lighting. gguy General Hardware Discussion 7 10-16-2007 07:11 PM
cd changer control to control the pc babas151 General Hardware Discussion 6 10-25-2004 11:21 PM
Steering wheel controls Izik Input Devices 4 05-31-2004 09:46 AM
evaluate this in-dash tablet PC plan dimas Laptops, Tablets, UPMCs, etc. 10 11-15-2003 06:50 PM
pocket pc control? meyer64 Software & Software Development 5 09-28-2002 08:40 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
