The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Thread Tools Display Modes
Old 07-12-2005, 04:05 PM   #1
My Photos: (0)
FAQ: How to fix your OPUS 150W
ok now that you know how to hook it up.. http://www.mp3car.com/vbulletin/showthread.php?t=53523 ..
your OPUS 150 may still not work... why? You're shorting a circuit!
How do you know if this may be your problem:
1) you double checked all your wiring
2) you made sure the power switch was in its correct polarity
3) you made sure your BIOS settings were correct
4) you pulled out some hair
5) after starting the ingnition the green LED on the OPUS will light up, signaling there is enough power, BUT the mobo doesnt turn on.. AND the fan on the OPUS doesnt turn on!
If this is true you most likely have a short circuit in your OPUS... To confirm that this is your problem take off the screws on your OPUS and remove the top casing with the fan still attached. Now, try turning on the ignition... If it works then your OPUS was suffering from a short circuit.
How to fix:
1) Check the coil right behind the 8 pin connector
2) You will find that it rubs against the cover of your OPUS, this is your short
3) To fix this, simply take some electrical tape and cover up the portion of the case that rubs against the coil.
That should do it!
Not the best pic but you get the idea:
Tred is offline   Reply With Quote
Sponsored Links
Old 10-22-2005, 09:00 AM   #2
vairu's Avatar
Vehicle: 2006 Scion xB
My Photos: (0)
your my hero!
Now i can put my fan and the top piece back on
vairu is offline   Reply With Quote
Old 10-23-2005, 02:18 AM   #3
My Photos: (0)
glad it helped someone
Old 10-24-2005, 08:31 PM   #4
SuperFastCVT's CarPC Specs
Vehicle: 2002 Audi A4
My Photos: (0)
could this also be the cause of an opus 150 not turning off ever? (until battery dies)
SuperFastCVT is offline   Reply With Quote
Old 10-25-2005, 06:22 PM   #5
crsseyednsmilin's Avatar
Vehicle: 2005.5 VW Jetta 2.5L
My Photos: (0)
Problem: Opus 150 would automatically hard power down after about 20+ mins of use, even with a good 12volts running to it.
Solution: Hook up the friggin Ignition "Option". Without the ignition wiring hooked up the Opus always thought my car was off and turned off automatically so as not to kill the battery. Theres probably a way around that but it bothered me for a long time and hopefully it helps other newbs answer an opus problem of their own.
2005.5 VW Jetta 2.5L, 1957 VW Beetle Custom
Previously Owned: 2000 VW Beetle TDI, 1982 VW Vanagon Westfalia, 1971 VW Super Beetle
My VW Jetta mk5 Carputer
frodoplayer.com
mk5 OEM NAV Skin - Frodo - In Progress
crsseyednsmilin is offline   Reply With Quote
Old 10-26-2005, 12:48 AM   #6
My Photos: (0)
you need to have all the wires hooked up. if the Opus doesnt shut down then its not likely that the problem is due to a short from the case. Either way, you could take 2 minutes to put some tape over that section to see what happens. If that doesnt work, it most probably because the Opus is not getting the signal to shut off/on. Do yourself a huge favor and invest in a multimeter. This will help you troubleshoot, allowing you to make sure each wire is sending out the correct voltage at the right time.
Sponsored Links
vB code is On
Trackbacks are Off
5V on USB header question w/ Opus 150W beckkl Power Supplies 6 10-25-2004 09:18 PM
Opus 150W Power Supply Comparison Troy McClure Power Supplies 8 10-20-2004 07:01 PM
OPUS 150w keeps killing my battery. Need help! EuroFan Power Supplies 19 10-20-2004 07:04 AM
For Sale: New in box 150W Opus moltensilver Classified Archive 3 05-13-2004 10:57 AM
OPUS 150W Behaviour on PC error Jamez_Warner Power Supplies 1 05-09-2004 02:31 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
