The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Thread Tools Display Modes
Old 07-21-2005, 04:30 AM   #1
mookie's Avatar
Vehicle: 2000 Toyota 4Runner
My Photos: (0)
FAQ: My Lilliput won't calibrate correctly.
If you're having a problem where your Lilliput (even if brand new) looks like this when you calibrate it:
Image stolen.. er borrowed.. from yamathegreat in this thread.
Then it looks like you need a new touchscreen overlay.
You may have some luck contacting whomever you bought the screen from and arranging a return, but if not the replacement panel can be found at DigitalWW... here.
They're a cinch to install. Carefully disassemble your Lilliput and remove the taped on touchscreen panel. Now remove the protective covering on the replacement panel and secure it on the screen with a little tape of your own. Hook its little connector up just like the old one was and reassemble your Lilli and you're good to go. Easy as that.
Edit: I'm sticking the word "calibration" in here so this thread will show up in searches
Progress: On hold while I pay off my new PowerBook :D
Part List:
VIA MII10000 - 512MB - 20Gig 2.5" - Rikaline 6010 - 7" Lilliput - CNX-P1260 - Alpine 4ch Amp - 4 Gauge wire and fused distrobution block.
mookie is offline   Reply With Quote
Sponsored Links
Old 07-21-2005, 04:58 AM   #2
djmickyg's Avatar
Vehicle: 2006 Ford XR6 Turbo Ute
My Photos: (2)
what lilliput has these issues?? the old or the new??
djmickyg is online now   Reply With Quote
Old 07-21-2005, 11:35 AM   #3
mookie's Avatar
My Photos: (0)
For me it was the old one (619). The newer (629) may or may not have the issue also, I do not know for sure.
Part List:
Old 07-21-2005, 01:49 PM   #4
Jesus Freak
antimatter's CarPC Specs
antimatter's Avatar
Vehicle: 2006 Mazda Mazdaspeed 6 GT
My Photos: (0)
For the most part the new ones have been relativly trouble free compared the massive amounts complaints and threads about the old ones. They sourced a different touchscreen overlay that holds up better to heat and is less prone for failure.
Disclaimer. This if not out of experience but from reading other peoples evaluations and posts
antimatter is offline   Reply With Quote
Old 08-05-2005, 12:07 AM   #5
Vehicle: 2004 Jetta GLS TDI (biodiesel)
My Photos: (0)
The Lilliput 619 has been through about 5 revisions in the past year and touchscreen are now more reliable then the Xenarc's. The 619 and the 629 Lilliputs both use the same internals they are not “older” or “newer” but rather different casings.
Zip-Lock is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 111 04-17-2008 12:36 AM
Can't calibrate lilliput touch screen _wd LCD/Display 10 02-14-2007 10:10 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 06:26 PM
Lilliput: Have to calibrate every 5 minute? Burat LCD/Display 17 03-01-2005 07:32 PM
Can´t calibrate lilliput 100% yokeren LCD/Display 7 01-18-2005 06:36 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
