The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Thread Tools Display Modes
Old 07-29-2005, 03:33 AM   #1
Frankino's Avatar
Vehicle: Peugeot 206 HDi 2003
My Photos: (0)
FAQ: M1-ATX DC-DC PSU, how to avoid problems
A couple of hints, some valid for every DC-DC:
1) never connect or disconnect the +12 cable without having it disconnected from the battery, Faston connection can be poor and you'll get an huge spike connecting it manually
2) disconnect it from the battery when changing the timer jumpers
3) NEVER wire your amp remote wires to the two pins on the M1, just use the positive one, if you need to groung it (some amps need it) place a fan or a resistor in serie to avoid short circuit. If you do not do it, short circuit WILL appen and WILL damage your M1 for sure (on mine the shutdown logig stopped to work after a bad amp wiring)
4) remember it's a COMBINED 90w, using a calculator never gives you the assurance it will work for you, take care of the 12v load (2A max)
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
40gig 3.5" HDD
Sb Live 5.1 w/ KXProject Drivers
Opus 150w WTF
8" Lilliput TS LCD
40% installing (monitor ok, pc KO, audio KO)
damn car accident
Frankino is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
AT / FULL ATX PSU FOR SALE Mastero Classified Archive 2 01-09-2002 12:54 PM
dc dc psu for a micro atx case y0manda Power Supplies 0 12-23-2001 06:04 PM
85 dollar DC to DC ATX PSU citrus3000psi Power Supplies 4 07-21-2001 06:56 PM
Must have for those using Aztec Laptop DC PSU DodgeMp3Enabled Classified Archive 0 03-02-2001 09:18 AM
Has anyone tried modifying a 110v atx PSU to 12v DC? HappyPuppy General Hardware Discussion 15 11-12-2000 10:03 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
