Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 02-02-2006, 01:56 PM   #16
TucsonPred's Avatar
I've used my PC in 3 different trucks all in summer, 120+ (155+ in car, I know from the digital read out of my alarm) with no problems. However I've run into an issue for anything under 55 degrees my system will not power up until i 'heat it' via the floor heater for a couple of minutes. The colder it is the warmer I need to make it before it'll boot. Now if i have it set to autopower on on DC loss (Epia power on options) it will attempt to boot and make a pop pop pop through my amp, oddly it only does this if trying to auto power on. I think it's my SB Live 24bit PCI card though ot my power supply/itps/dssc triade, possibly my ram, or my board but I don't think it's the Hard drive (WD laptop 80 gig with a FDB) as the popping begins before the video for the POST even kicks on so the board has not even gone into post yet. But if it's 60+ degrees it fires up every time. I usually am parked in the shade but when I have been sitting at Home Depot or what not it's hit 155 to 165 inside the truck but fired right up and ran fine. This is the 2nd year for this WD hard drive, before I was using a Seagate 80 gig 3.5 drive and it was hard mounted to the dash, it is running 100% fine in my wifes computer now.
2K SVT Lightning, Some things and the usual truck pc, now with slot load dvd rom and ECM Data logging.
05 Scion xA
TucsonPred is offline   Reply With Quote
Old 02-02-2006, 02:16 PM   #17
I used to have a similar problem where the screen wouldn't turn on on cold days unless I put the heat on for a while... but then after messing with some wiring I found out, it was the power source I tapped into and not the actual screen. I now have the screen powered directly from the battery and I don't have problems anymore....
DaPCWiz is offline   Reply With Quote
Old 09-02-2006, 01:42 PM   #18
treydogg's Avatar
well, as far at the heat, I live in Texas, and for the last month it has been 100+ strait, I have yet to have a problem with my pc.
AMD 64Bit XP 3800/1 gig ddr-400/8" lilliput TS/200 gig SATA drive/sprint megillin wireless/pharos 360GPS
"I swear to God officer, I use it for gps!"
http://www.treydogghour.com
treydogg is offline   Reply With Quote
Old 09-17-2006, 07:00 PM   #19
XtremeSteel's Avatar
I live in Yuma AZ. As far as I know, Yuma is usually THE hottest place in the US; we hit 122F in July. Iv had my carpc running all summer with no heat problems. I would see the CPU temp around 65C all the time and it never hickuped; xenarc ts or the pc.
Edit: my keyboard didnt fare to well thou. It warped slightly and now its bowed upward. But who cares, it was $10 for the wireless kb and mouse combo and Iv used it only once.
My PC: VIA MII10000 | 512MB DDR400 Corsair XMS | 80GB HDD | Creative SB Audigy 2ZS notebook | 7" Xenarc TS | M2-ATX | Custom Box |
95 Mustang (99-04 Saleen Style)
For Sale: Custom Panels
XtremeSteel is offline   Reply With Quote
Old 09-19-2006, 11:00 PM   #20
jasonsjwou's Avatar
Theoretically, all electronic circuitboards suffer from a thermal stress cycle fatique. As things get heat up and cool down, they expand and shrink. Circuit board expands and shrinks, and the components (especially those Surface Mounted IC's) expands and shrinks. Do this many times, soldier joints will break and the board will stop working. One of the reason why some critical electronics are left on all the time, even if it's not used, so they do not experience thermal stress cycles.
Thermal cycle is one of the toughest criteria that Vehicle electronic component manufacturers have to consider. Anybody can make Anything work on the bench. That's Easy. But will it work at 120C? Will it survive thermal cycle?
I have had two laptops (Serendipididly, both Compaq) fail in 2 years due to thermal cycle. Video Chip failed in one (X1000), and some bridge chip failed on the other (EVO something). Apparently, this is fairly common on Compaq laptops.
With this in mind, I have a question.
Most of us always tear things down and upgrade all the time, all too often. So who has the CarPC installed and used on daily basis for the longest time (without altering the setting) in this forum? We should make a poll on this.
jasonsjwou is offline   Reply With Quote
Old 11-01-2006, 06:40 AM   #21
Ecxellent FAQ Bugbyte! I made it here searching various things like dessicant, condensation, air conditioning...(much more). I think I have seen, by far most of what this forum has so far on the issue of heat/cooling. It is good to know that many people are having no problems operating their carpc's in very high temps. I have seen all of the posts warning of condensation, and now understand some of the cold climate related problems we face.
I am going to go against the better judgement of many here and use climate control, Mastero's aircon2 (thread) (soon to be released as of yet, I hope) and some automation to cool my rig. I have yet to read any bona-fide horror stories. Please, if someone knows of any please let me know. I plan to do some testing on the matter, a sceintific as possible (I understand the whole 'build specific' thing and I all I can say is I will do my best, if only for uATX people). I'm thinking some humidity sensors and MOBO + additional Temp sensors, some 24/7 action, some extreme climate, and some datalogging.
The plan is to have the carpc know when to start up the car to either heat or cool the computer compartment when temps get too high or too low (as well as the obvious charging needs). I think I'll be ready in time to do some winter testing (I'm not in the most ideal climate for that, deserts do get chilly), but definately stay tuned for summer.
I haven't posted my setup in my sig yet (still coming together on the bench), but it's a uATX mobo, AM2 sempron 3200 (I may even be persuaded to overclock, and undervolt for more data), DSATX P/S using onboard graphics, Audigy ZS2 platinum pro, additional average-setup periphs (HQCT, 60G FDB style hard drive), eclosed slot drive...blah, blah, soon an aircon2, and phidgets (I/O) on the way, all going in the computer 'case'.
Lemme know if this interests anyone even a little, or if you have any ideas to make the tests more complete or scientific. I'll start a new thread on the plan within this month, and update with a link here when I do so.
I love this stuff. Heat transfer, PV/T, saturation curves, who would have thought I'd be using this stuff in a computer 'case'. (ok, maybe heat transfer)
h3rk is offline   Reply With Quote
Old 11-03-2006, 09:23 AM   #22
afterdigital's Avatar
the LCD not initially working at first in the winter makes sense. This occurs to me every morning i get in my car. Thanks for the heads up. I began worrying that there was something wrong.
Only thing is now i am considering getting a remote start - $200 bucks ouch.
CTS 05, Mobile Information Center...
P4 - 2.8ghz
1GB Ram
320GB HD
8" TouchScreen
Digital FX
Finished Project
Car Hacking
WorkBlog
Video
afterdigital is offline   Reply With Quote
Old 11-03-2006, 09:50 AM   #23
Laptop, Tablets, UMPC Moderator
turbocad6's Avatar
just a bit on the ac cooling issue....
the problem is NOT by cooling the pc with the ac.... this WILL WORK FINE......
that's not the problem.... cooling the hot pc components wil have NO ill effects....
the problem comes when that ac goes away.... turn off the ac, park the car... now the computer components are below ambient, which will rise quickly on a hot day.... THIS is where the condensation comes in, & let me tell you, it can get bad enough that the components wil actually be WET..... like taking a can of coke out of the fridge & placing it on a table on a warm day... it will become WET rather quickly with condensation.....
restart the car a bit later, everything is damp.... can you say short circiut....
ac cooling will only work if you can control the temperature rise after the fact, & you really can't..... in a house where it's running all the time, no problem... in a car, if you have the pc chilled, then get stuck in bumper to bumper traffic, turn off the ac & open the windows.... the pc WILL short out.... this is not a hypothossis, this is a FACT.... I have tested this method & know first hand.... don't do it, not a good design...
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is online now   Reply With Quote
Old 11-03-2006, 10:13 AM   #24
uhh, so don't turn the AC on?
P4 - 2.8ghz
1GB Ram
320GB HD
8" TouchScreen
Digital FX
Finished Project
Car Hacking
WorkBlog
Video
Old 11-03-2006, 10:46 AM   #25
turbocad6's Avatar
no, don't duct ac cold air directly to the pc for cooling
Old 11-04-2006, 04:05 PM   #26
thanks for the recommendation. i was actually thinkin about doing exactly that. now i know not to...
thanks
P4 - 2.8ghz
1GB Ram
320GB HD
8" TouchScreen
Digital FX
Finished Project
Car Hacking
WorkBlog
Video
Old 11-04-2006, 11:49 PM   #27
Thanks for sharing the empirical information, turbocad6. That is very useful. I would have surely fried some stuff.
What if the computer had a climate controller that never allowed the cooling air to get too cold (by using its own heater/temp control door)? It can use RH sensor & temp sensors to select, from mapped data, a temperature that is closer to ambient; close enough to preclude condensation. Then the metal components of the computer will not 'chill'. I know there is an abundance of dew-point and related data that would be helpful. This system would benefit from being sealed when not being cooled by its fancy climate control (but that would be tough). And timing the puter to remain on longer than the cooling system, long enough for temps to rise above ambient (or until triggered by sensors/ setpoints), would negate ill effects of the chilled components with warm damp air (to that of at least more normal arrrangements).
Old 11-05-2006, 12:43 PM   #28
what i'm thinking is install a fan or two in the pc area sealed to a long enough tube which can direct the air within to blow out to the cabin of the car.
P4 - 2.8ghz
1GB Ram
320GB HD
8" TouchScreen
Digital FX
Finished Project
Car Hacking
WorkBlog
Video
Old 11-05-2006, 01:33 PM   #29
turbocad6's Avatar
the idea is not to bring the metal temps too far below ambient air temp... if you measure the temperature of the air coming out of an ac vent on max in a good system, yyou'll see a temperature of 35-40 deg f.... if you do a good job of using the ac, you can get metal temps down in the 45 deg range.... when the cooling goes away, & the air temp around the metal hit 90+ on a hot day is where the problems come....
ac can be used if you control the flow... IE; a temp sensor that controls a blower.... temps over threashold A, fan on, but, whwen temp goes below B, fan off... this can be really effective....
an alternative may be to usejust a slight amount of air... not enough to cool very efectively, but enough to just lower case temps a bit....
Old 11-07-2006, 12:13 PM   #30
weekendowel's Avatar
I live in Sweden and we get temperatures as low as -25 C (-13 F) and I actually had to make a small electronic circiut to press the reset button on my PC every 5 minutes if it didn't recieve an acknowledge from the comport, that means if the PC got stuck on the "Boot drive failure" it automatically reseted until it got so warm it was able to start which in most cases only required one reboot.
weekendowel is offline   Reply With Quote
FAQ: Hacking Your Steering Wheel Buttons to Control Your PC Bugbyte The FAQ Emporium 73 03-09-2008 06:14 PM
Lilliput works on home pc but not car PC!!!!!!!!!! lax4321 LCD/Display 13 02-24-2007 05:24 PM
Car pc works when engine off, but not on.. drewinstl Power Supplies 3 09-05-2005 06:07 PM
Installing car PC in 1996 Honda Civic PredatorCoder Newbie 8 08-18-2005 07:58 AM
PC car questions... please help. euclide Car Audio 7 05-25-2004 04:51 AM
