The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Thread Tools Display Modes
Old 03-15-2007, 02:21 PM   #31
king_of_fools's Avatar
My Photos: (0)
new hard drive to run in hotter and colder temps ... sounds like a carpc HDD to me.
it runs at: -35ºC to 80ºC that is about -31ºF to 176ºF
http://gizmodo.com/gadgets/periphera...tly-244378.php
K
O
F
king_of_fools is offline   Reply With Quote
Sponsored Links
Old 05-05-2007, 11:12 AM   #32
My Photos: (0)
What if you were to just install fans on a case that's designed to be fanless? Wouldn't that theoretically provide more than enough cooling?
Hell, I bet one of these [url=http://www.thinkgeek.com/computing/accessories/5dee/]USB fans[/USB] would do the trick. I use 'em to cool down home theater components, because my Directv box has a USB port.
Of course, that still means you're really just blowing hot air around.
What if you ducted the AC to the trunk, but not directly into the case? Would that still cause condensation?
mrminty is offline   Reply With Quote
Old 05-08-2007, 01:50 PM   #33
My Photos: (1)
That would depend on what the internal temp for the trunk got to. Not to mention, the trunk is probably one of the hotest compartments on a midsummers day. The warming of that compartment will create some degree of moisture, it's just a matter of "how much".
kermitbuns is offline   Reply With Quote
Old 05-14-2007, 03:44 PM   #34
VmtSquad's CarPC Specs
VmtSquad's Avatar
Vehicle: 2004 / Acura / TL 6sp Dyanmic
My Photos: (102)
Cool and heat
I work in Networking with computers and I found this post really interesting since I working on my own carputer (04 TL). Unless you wan't to control the AC temperature that goes in the PC, you can just be sure to have a AIR FLOW in the PC's case.
What I mean by "AIR FLOW" is, even if it's WARM or COLD air it as to move in the case. The easy way to do so, is to install atleast 2 computer fans in your carputer case.
The first FAN as to push some air inside the case....
The second FAN as to pull out the air outside the case....
This will create an AIR FLOW in the computer's case and keep the hardware at a respectable temperature.
I live in Montreal, Québec. The temperature here is never the same, in winter it can get as low as -30C and during summer we usualy have some +30 really often. SO that's why temperature is a major problem for me. I'll let you guys know when I will run all my carputer tests.
VMTSQUAD
VmtSquad is offline   Reply With Quote
Old 05-16-2007, 06:34 PM   #35
Vehicle: 2005 Honda Civic
My Photos: (0)
Just thought I would add that I use my car PC all year round and it gets -40 celsius here a few times a winter every single year. I find everything will work and function normally except the hard drive won't spin unless it's above -15 or -10 somewhere, so ultimately it won't boot. But all other components seem to work.
Ampie Case
2.5" Hard Drive 80GB Toshiba 5400rpm
Kingston 512 MB DDR RAM PC3200
Xenarc 700TSV - VGA Monitor
VIA EPIA M10000 Mini-ITX Mainboard
M1-ATX 90 Watt - Smart Power Supply
2005 Honda Civic
Maheriano is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Hacking Your Steering Wheel Buttons to Control Your PC Bugbyte The FAQ Emporium 73 03-09-2008 06:14 PM
Lilliput works on home pc but not car PC!!!!!!!!!! lax4321 LCD/Display 13 02-24-2007 05:24 PM
Car pc works when engine off, but not on.. drewinstl Power Supplies 3 09-05-2005 06:07 PM
Installing car PC in 1996 Honda Civic PredatorCoder Newbie 8 08-18-2005 07:58 AM
PC car questions... please help. euclide Car Audio 7 05-25-2004 04:51 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
