Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 09-25-2006, 04:58 PM   #16
Raw Wave
shotgunefx's Avatar
shotgunefx is on a distinguished road
A PS/2 mouse works similar to a ps/2 keyboard, but sends a CTRL-M so that it knows it's a mouse IIRC.
Take a read at this thread
shotgunefx is offline   Reply With Quote
Old 09-25-2006, 05:00 PM   #17
LYHTSPD is on a distinguished road
Quote: Originally Posted by FC3S View Post
why would you need to fake the computer into thinking a mouse is plugged in?
what purpose would that serve...?
Oh, it is for a completly different application. Nothing at all to do with carPC.
LYHTSPD is offline   Reply With Quote
Old 10-16-2006, 07:07 PM   #18
Termina is an unknown quantity at this point
I've tried twisting the stripped wires from the keyboard around both ends of the resistor (1/4W, 10,000 ohm) but it doesn't work.
Does it actually NEED to be soddered? I've tried just putting it in the PS/2 slot of the motherboard, and it still doesn't work..
can anyone give me a link to the kind of resistors used here, so I can make sure I'm using the right kind?
Mine are Brown, Black, Orange and Gold (color stripes)
Termina is offline   Reply With Quote
Old 10-16-2006, 11:48 PM   #19
I honestly don't see how the OP's hardwire method will work with a PS/2 keyboard. From what I have read, a PS/2 keyboard with talk with the motherboad controller back and forth to and uses an initilization sequence to confirm the existince of each other. I am not sure that just using a resistor to drop the voltage across the +5v line will do anything (maybe for an AT style keyboard). My advice is to basically get an old PS/2 keyboard, tear the driver chip out of it and solder it the PS/2 cord. I had to do this with a mouse for my problem in my earlier post and it works like a charm.
Old 10-17-2006, 08:42 AM   #20
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Here is a 10k ohm resisitor:
Brown, black, orange, gold
Are you sure you have the right wires to the right pins? Did you use a multimeter to confirm you have the proper wires or did you guess?
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 10-17-2006, 05:11 PM   #21
I guessed; stripped all four wires, and kept trying randomly. =) I figured red would probably be the 5v, and tried diffrent wires hoping one would be ground (unless that one wire w/o plastic covering is the ground?)
Do the colors vary from keyboard to keyboard?
Does the side the wire touches of the resistor matter?
Thanks!
Old 10-17-2006, 09:31 PM   #22
Bugbyte's Avatar
The sides don't matter, but for heaven's sake, use a digital multimeter to be sure which wire is which.
Want to:
-Where is the iBug?
Old 10-17-2006, 11:40 PM   #23
Thanks!
The colors for PS/2 are not standardized from what I know. You should be able to use your multimeter and figure out which pin on the PS/2 cable is which colored wire, and then look at the OP's post to determine what it's function is.
Old 10-19-2006, 04:58 AM   #24
Knightofoldcode's Avatar
Knightofoldcode
Thanks!
While you were randomly tickling your computer, did you allow the PC to sit at the "keyboard not found" error, and just randomly try wire combinations? Because you have to reboot the computer after each random attempt.
No, red is probably not 5V+.
A simple resistor may or may not work with your computer/bios. On the old style AT keyboards, yes, 99% of the time it'll work. This method with the resistor may or may not work. I know for a fact it won't work on 99% of all server motherboards. However, desktop motherboards, and micro motherboards it's a %50/%50 chance it will work. Some motherboards are "smarter" than others, and actually talk to the keyboard, instead of sensing a voltage drop/lack of floating line.
There is a commercial solution. This is typically called a "dummy keyboard", there are many other types including, "dummy video", "dummy keyboard", "dummy mouse", etc. Search google, it's not easy to find on google, but you can find them. Here's a link for a intelligent dummy keyboard.
http://www.multibug.co.uk/keyboard_dummy.html
Knight.
This message transmitted with 100% recycled electrons.
Gravity doesn’t exist. The Earth sucks.
Make a man a fire, and he will be warm for the night.
Light the man on fire, and he will be warm for the rest of his life.
Knightofoldcode is offline   Reply With Quote
Old 10-19-2006, 09:08 AM   #25
Bugbyte's Avatar
Of course, if you are going to buy a keyboard dummy, for just a few dollars more, you can get an iPac interface that will turn switch presses into keyboard commands. That would also fool your keyboard.
Want to:
-Where is the iBug?
Old 10-20-2006, 05:28 AM   #26
Knightofoldcode
Very nice. I didn't even think of the iPac.
Knight.
FAQ: Attention Newbies! The quickest way to learn about Car PC's Bugbyte The FAQ Emporium 2 06-19-2005 04:18 AM
For Sale for all you aussies. Complete mp3 car pc Holden__V8 Classified Archive 20 04-09-2005 06:30 AM
mac keyboard with a PC? Machs_FueL General Hardware Discussion 9 01-11-2002 03:12 PM
no box pc??!! built into keyboard! RaZor General Hardware Discussion 5 12-08-2001 05:58 AM
Disabling BIOS keyboard error? Squeezer General Hardware Discussion 3 02-02-2001 09:29 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
