Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Old 11-01-2005, 10:52 AM   #1
Takes it in the Rear
kevinlekiller's Avatar
kevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud of
FAQ: Fooling pc to think a keyboard is plugged in.
I was helping ooopseyesharted , and I told him that if you have no keyboard the computer might give an error. Anyways lets gon on with the tut. :
Theres 2 ways to get the computer to boot.
1) The soft method (might not always work).
2) The hard method (always works).
1) The soft method: (soft = software)
a) Go in your computer bios settings.
*(on most computers: press delete when you first boot the computer)
**(On computers such as dell , compaq , hp , etc... , its usualy one of the F keys).
b) Look for: "halt on keyboard error" Or something similar. - Set it to False ( or no).
If you have this option : "halt on all errors" or something similar - Set it to False (or no.)
If you have none of these options move to the hard method
..c) On some computers enabling Quick boot in the bios menu will bypass the keyboard check.
2) The hard method (hard = hardware)
For this mod you need a 10k ohm resistor (carbon film). (you can get them at radio shack).
AT style connector(older):
There are 3 ways you can do this:
1. get a old keyboard and cut the AT plug.
Strip the wires , with a tester check wich pins go with wich wires. We need the wires for pin 4 and 5(check the picture above).
Solder the resistor between the 2 wires you found.(solder the resistor in any direction it doesnt matter).
2. Insert the resistor on the motherboard connector between pins 4 and 5 and hot glue it in place.
Or 3. With a tester find were pins 4 and 5 lead on the motherboard. And solder the resistor there.
Ps2 style connector (newer):
1. get a ps2 keyboard and cut the ps2 plug.
Strip the wires , with a tester check wich pins go with wich wires. We need the wires for pin 3 and 4(check the picture above).
2. Insert the resistor on the motherboard connector between pins 3 and 4 and hot glue it in place.
Or 3. With a tester find were pins 3 and 4 lead on the motherboard. And solder the resistor there.
This concludes the tutorial.
Thanks to google for the info and pictures
Version 1.1
kevinlekiller is offline   Reply With Quote
Old 11-01-2005, 12:13 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a name known to allBugbyte is a name known to allBugbyte is a name known to allBugbyte is a name known to allBugbyte is a name known to allBugbyte is a name known to all
Thanks for the FAQ, Kevin. Added to the FAQ to the FAQ's.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 11-01-2005, 10:27 PM   #3
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
Or better yet if you going to waste a KB just open it and extract the PCB (brain) and forget about the buttons, housing etc, connect it like a regular KB (hide the brain somewhere in the car)
BTW finally I see that the monkey (kev) is giving back to the community. J/k
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 11-02-2005, 09:10 AM   #4
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
what about just bending the resistor into a U-shape and inserting it into the required pin receptacles on the motherboard and hot-glue-ing/taping it into place so it won't fall out?
then there's no need to waste a perfectly good keyboard.
tj!2k4 is offline   Reply With Quote
Old 11-02-2005, 09:16 AM   #5
EDITEd-------------
I miss read my own post , but its already there , its just I didnt write it well. Let me write it back.
Thanks.
Old 11-02-2005, 10:08 AM   #6
Para Laura
Well that idea is better than solder something to the mobo, but like here in miami KB are $3.00
Thanatos.
Nissan Aux-in MOD
Old 11-02-2005, 11:03 AM   #7
Thanatos.
Resistor - 5 cents.
Hotglue gun + hot glue 1 $
Installing it all - Priceless
Old 05-06-2006, 01:02 PM   #8
shinjetko is on a distinguished road
Version 1.1
hi,
can you please give me more detail, like step by step if you have a picture, it wil be awesome, sorry I am kinda noob. I'd like to do the hard method, since my computer doesn't has "halt on keyboard error" or something similar.
Can you tell me, what kind of stuff I need, and how I am gonna to do it, thanks for helping.
shinjetko is offline   Reply With Quote
Old 05-06-2006, 01:29 PM   #9
Raw Wave
tj!2k4's Avatar
Quote: Originally Posted by shinjetko
hi,
Call me crazy, but it would appear that the instructions clearly state what is required
and what needs to be done:
OR
OR
There were even pictures!
What is the problem??
No offense, but if you're having trouble following these instructions, maybe you need to look into a different hobby.
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
Old 05-20-2006, 05:34 PM   #10
You dont need a keyboard, you can buy an extension , or use a broken keyboard that dont work in a pc no more.
And the reason why you would use just the cable and not the whole keyboard(pcb) is to save space.
Old 05-21-2006, 12:09 AM   #11
Hi guys,
thank you for helping, I just want to make sure, what I do is right.
So, all I need is a connector (Ps2 style connector (newer)), then I need to use 10k resistor, to soldier between the wire of pin 3 and pin 4 for the keyboard connector right ? After that just plug in the other side of the keyboard on motherboard right ? thank you.
Old 05-21-2006, 11:43 AM   #12
Bugbyte's Avatar
Umm, right. But if you have to ask the same question three times to make sure that you have figured out how to bridge two wires with a resistor, I'd recommend that you not only don't do it, but seriously reconsider whether you're equipped to install a PC in your car.
There are lots more difficult and fuzzy things about installing a car PC than this three step, very clear tutorial.
Want to:
-Where is the iBug?
Old 09-25-2006, 02:15 PM   #13
LYHTSPD is an unknown quantity at this point
Would this also work with a ps2 mouse?
LYHTSPD is offline   Reply With Quote
Old 09-25-2006, 03:36 PM   #14
FC3S's Avatar
FC3S can only hope to improve
why would you need to fake the computer into thinking a mouse is plugged in?
what purpose would that serve...?
FC3S is offline   Reply With Quote
Old 09-25-2006, 03:44 PM   #15
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is just really niceDarquePervert is just really niceDarquePervert is just really niceDarquePervert is just really nice
No.
Quote: Originally Posted by Heather
Upon the advise of the mods, your inflammatory signature was deleted as well, under the same grounds for deleting the thread you started.
FAQ: Attention Newbies! The quickest way to learn about Car PC's Bugbyte The FAQ Emporium 2 06-19-2005 03:18 AM
For Sale for all you aussies. Complete mp3 car pc Holden__V8 Classified Archive 20 04-09-2005 05:30 AM
mac keyboard with a PC? Machs_FueL General Hardware Discussion 9 01-11-2002 02:12 PM
no box pc??!! built into keyboard! RaZor General Hardware Discussion 5 12-08-2001 04:58 AM
Disabling BIOS keyboard error? Squeezer General Hardware Discussion 3 02-02-2001 08:29 AM
Powered by vBulletin® Version 3.8.2
Content Relevant URLs by vBSEO 3.3.0
