Quote: Originally Posted by
sux89
Oh and also couldn't you just use
this up in the front of the vehicle too? Then you could just use the existing factory wiring...no electrical noise from running audio lines all the way back. Correct me if I'm wrong...
I believe this topic needs to be touched on some more, sorry if this thread is 10 yrs old but its still something people do. for test reasons im going to use a cheapo mp3 player and i guess what i want to do is put it where the factory head unit goes. I have the aftermarket harness to install a new head unit and im wondering if i could just tap into that. now where im confused is the 5v that turns on the amp. Does the amp not turn on with an aftermarket stereo?
So im guessing things i will need would be, male headphone2rca left&right, Ground loop isolator and a 5volt regulator. out of the ground loop with rca left&right to the aftermarket harness and 5v to the aftermarket harness.
Where im lost. Where the 5v goes into the harness( i would have to research more)
Since its a mp3 player im loosing my front/back (surround sound) capabilities as to where i could have a dolby 5.1 sound card with front and rear outputs.
this is already starting out as a headache and im most certain a aftermarket amplifier would be easier BUT then again i would be splicing into the wiring .
I just feel this could be cheaper
I guess subwoofer output would be on the sound card to
seems like a headache but i thought i would put my 2 cents in.
final opinion Delete monsoon, replace with aftermarket amplifier.
