The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > The FAQ Emporium
Thread Tools Display Modes
Old 01-17-2006, 10:03 PM   #1
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
FAQ: How to add Sirius satellite recevier to your car PC
So you want satellite radio but you'd rather have Sirius instead of XM? Thanks to long time member -zip-, here's how you do it. You can read the source for this FAQ at his thread here.
You need two things to hook up and control Sirius radio from your car PC.
1. A Sirius receiver. Specifically, the Alpine Sirius Connect, SIR-ALP1
2. An interface for the receiver available from http://www.mp3car.com/store/product_...roducts_id=182 .
The interface connects to the serial port on your car PC. Current price is $59. A thread on this interface is here.
Instructions on installing the interface can be found at rush2112.net.
Opening up the Alpine unit reveals 2 circuit boards inside. Simply remove the board that is near the back and replace it with the interface you purchased. If the holes in the case do not match up exactly, dremel out the case as necessary and reassemble. Use the optical out from the interface board and plug it into your sound card. No TOS link input? You can also buy a TOS link adaptor for the SoundBlaster Live 5.1/Audigy/and Audigy 2 soundcard as long as they have an AUD_EXT or AD_EXT header on the card.
Connect the serial cable to your car PC and connect the red power wire to a 12 volt source and the ground wire to a ground.
3. Software to control the receiver from your car PC. The good news is that both options are free. Road Runner is the only car PC front end that controls the Sirius.
A standalone test program is available from rush2112.net.
That's all there is to it!
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is online now   Reply With Quote
Sponsored Links
Old 01-20-2006, 10:54 AM   #2
randomjohn's Avatar
Vehicle: 2003 Jetta 1.8T
My Photos: (0)
There are actually three wires that have to be hooked into the car power, one of which Mitch sends to you and you clip into the 4-port plug. You plug it in like this:
Using this handy clip he also provides:
Assuming he sent you a red wire (mine was actually blue), it goes:
Yellow - Constant 12V
Red - Accessory 12V
Black - Ground
Otherwise, great FAQ.
GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
Worklog: http://www.mp3car.com/vbulletin/showthread.php?t=65059
Now with pictures!
randomjohn is offline   Reply With Quote
Old 01-20-2006, 06:17 PM   #3
My Photos: (0)
would this work for laptop carputers?
fventura03 is offline   Reply With Quote
Old 01-20-2006, 10:07 PM   #4
Bugbyte's Avatar
My Photos: (19)
Old 12-13-2007, 06:56 PM   #5
VettePC's Avatar
My Photos: (0)
Sirius to PC USB Interface with Digital Optical Out
Since the above is dicontinued... guess this post is a mute point? Anyone know of a method to use the Sirius radios with USB or Serial? Also, wondering whats the difference between the XM radio and the Sirius as far as the output signals? Are they the same? Reason I ask is there is a post on how to make a cable to wire the XM direct box to your serial port... If the signals are the same format maybe this would be able to be modified to work on the Sirius DEI SCC1 universal tuner?
Just a thought...
VettePC is offline   Reply With Quote
Old 01-05-2008, 07:44 PM   #6
dmistry's CarPC Specs
Vehicle: 2007 Honda Accord LX
My Photos: (0)
My wife bought these 2 components from http://www.rush2112.net/ they seem to be the way to go.
My Accord 2007 install worklog
http://www.mp3car.com/vbulletin/work...e-install.html
dmistry is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
My first car PC malice4you Newbie 3 08-09-2005 12:41 AM
Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail! hd54321 Power Supplies 1 02-24-2005 12:42 PM
basic car pc idea Joseph Newbie 2 11-08-2004 02:04 PM
Car power supply (battery charger) from old pc supply stimps Power Supplies 8 08-24-2004 07:59 AM
New toys for the pc car gizmomkr General Hardware Discussion 10 02-06-2002 04:55 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
